  4. SSL Certificate for Multi System Reactor via LetsEncrypt
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
2 Posts 2 Posters 828 Views 2 Watching
  • W Offline
    W Offline
    wokwon
    Details of runtime environment:
    • Reactor (Multi-hub) stable-22055-9b40e12
    • Running as a service on Windows Server 2022 Std 21H2
    • Connecting to HASS (HASSOS)
    • Is a migration WIP from OpenLuup/Reactor
    A complete description of your objective:
    • Using LetsEncrypt, application "certifyTheWeb", retrieve and apply SSL certificate to Multi System Reactor
    A description of your approach/solution/implementation so far:
    • Reviewed Config files, can't seen mention of certificate files in there
    Actual Question:
    • How do I apply a certificate to whatever web server Reactor uses? I'm familiar with managing certificates on IIS and Apache but Reactor doesn't use either of these and I have not been able to locat ethe config file that Reactor uses for this.
    • Which config file needs editing to apply a certificate?
    • Does it use the computer certificate store or it's own store (e.g. pem files)
    The reason I want to achieve this, other than the general goodness of having everything I can in TLS is that I have Reactor as an IFRAME in my HASS console and as HASS is HTTPS and Reactor is HTTP then the iframe refuses to open.
    Search for "certificate" or "ssl" did not reveal anything relevant in this forum.
      How To: HTTPS - Reactor - Multi-Hub Automation
        163.0k
