  4. MSR feature requests
1 Posts 1 Posters 505 Views 1 Watching
    RogerO
    Patrick,
    Couple of things to add to your feature request. If you would prefer I put them in MantisBT I can do that.
    1: ability to disable a reaction at the action level. Can get cumbersome when creating reactions to try different options when you have to create the action from scratch if you delete it.
    2: Think this was discussed once but not sure where. When hovering over the entity would be nice if you could have the window expand to allow you to reed the entire entry. Or pop up like a tooltip (not sure what the actual name is)
    3: Allow the entity selection dialog box to be dragged around the screen.
    4: Create a Home Assistant Integration so it can be deployed on the same hardware as HAOS (could significantly expand your user base).
