  4. Plugin - InfluxDB 2- RequestTimedOutError: Request timed out
2 Posts 2 Posters 1.7k Views 2 Watching
  • N Offline
    N Offline
    Hi, I don't know from which MSR version I have this error in the log:
    [latest-22080]2022-03-27T14:24:44.195Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1
    [latest-22080]2022-03-27T14:24:44.569Z <NotifyPushover:5:NotifyPushover.js:239> [NotifyPushover]NotifyPushover successful endpoint exchange (message sent)
    [latest-22080]2022-03-27T14:24:48.793Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:48.832Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:48.863Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:48.893Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:48.924Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:48.967Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:49.000Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:49.027Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:49.060Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:49.093Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:49.271Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    [latest-22080]2022-03-27T14:24:49.727Z <InfluxFeed:ERR> [InfluxFeed]InfluxFeed#influx write failed (data lost): [b]RequestTimedOutError: Request timed out
    MSR is running in synology docker with the latest-22080-ae7212f
    I can access to influxdb 2 like before with no changes on bucket and token.
    my setup in yaml is:
    plugins:
      - id: influx
        name: InfluxDB 2.0 Feed
        enabled: true
        implementation: InfluxFeed
        config:
          influx_url: "http://10.0.4.71:8086"
          influx_token: XKKoCcQHVDF8p7-RkNQXLkJhe6neB48V7sNAG39HX4bOTcDA0Bv4B2SVtaUfHb_rdvVvUpbDDbaNEBeS1ISacQ==
          influx_org: myhome
          influx_bucket: test
    I use influx_url and before it worked.
    from portainer log, I see:
    WARN: Write to InfluxDB failed (attempt: 1). b [RequestTimedOutError]: Request timed out
        at ClientRequest.<anonymous> (/opt/reactor/node_modules/@influxdata/influxdb-client/dist/index.js:16:4115)
        at ClientRequest.emit (node:events:520:28)
        at ClientRequest.emit (node:domain:475:12)
        at Socket.emitRequestTimeout (node:_http_client:758:9)
        at Object.onceWrapper (node:events:639:28)
        at Socket.emit (node:events:532:35)
        at Socket.emit (node:domain:475:12)
        at Socket._onTimeout (node:net:501:8)
        at listOnTimeout (node:internal/timers:559:17)
        at processTimers (node:internal/timers:502:7)
    any advice to resolve this error?
    -Docker on Synology NAS
    -HASS Docker 2026.8.1
    -ZWaveJS-UI 11.22.3
    -Update 16/08/2026
      That error means that the Influx client library used by InfluxFeed is unable to connect to your InfluxDB server and service.
      You are sort of indicating that you changed something. It would be good to know what. If you've been shuffling containers around, or recreated/upgraded any containers, you've likely not gotten the network setup right for one or both containers and they can't see each other, or at least, the Reactor container cannot access the InfluxDB container.
        157.6k
