  4. Rule to detect failed devices on an Ezlo hub?
8 Posts 3 Posters 1.7k Views 3 Watching
    Hi
    Does anyone have an expression to detect failed devices on an Ezlo hub?
    This is how we did it for a Vera hub here.
      This is a currently failed device on my Ezlo Plus
      battery_power.level=1
      battery_power.since=1648664932056
      humidity_sensor.units="%"
      humidity_sensor.value=65.9700012207031
      x_ezlo_device.battery_powered=true
      x_ezlo_device.category="humidity"
      x_ezlo_device.manufacturer="CentraLite"
      x_ezlo_device.model="3310-G"
      x_ezlo_device.parent=""
      x_ezlo_device.reachable=false
      x_ezlo_device.ready=true
      x_ezlo_device.room="61f08bdc123e431284c13fbc"
      x_ezlo_device.status="idle"
      x_ezlo_device.subcategory=""
      x_ezlo_device.type_id="CentraLite_3310-G"
      x_ezlo_item.battery=100
      x_ezlo_item.humidity=65.9700012207031
      x_ezlo_object.id="61f0bbbf123e4312a1900a18"
      Capabilities: battery_power, humidity_sensor, x_ezlo_device, x_ezlo_item, x_ezlo_object
      Actions: x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check
      Its a Zigbee device if that makes any difference.
      CrilleC 1 Reply Last reply
      • cw-kidC cw-kid
        @cw-kid I'm doing it like this. There may be better ways but this works for me.
        I have a dynamic group for unreachable devices.
         - id: groups
           name: Dynamic Group Controller
           enable: true
           implementation: DynamicGroupController
           config:
             groups:
               "UnreachableEzloDevices":
                 name: Ezlo Devices Not Responding
                   - include_controller: ezlo
                   - include_capability: x_ezlo_device
                 filter_expression: entity.attributes.x_ezlo_device.reachable != true
        Then a global expression for the devices.
        In the rule I have this setup.
        The global variable prevEzloDevicesNotResponding is set to keep track of number of devices that are unreachable.
        The local variable Send is used to only send a notification if the number of unreachable devices is increasing or is back to zero, since after a reboot of the controller, all Zigbee devices is marked as unreachable until physically power toggled and I don't need a notification of a decreased array every time a device is reachable again until they all are.
        Hope this gives you some ideas.
        • CrilleC Crille
           - id: groups
             enable: true
             config:
               groups:
          @crille
          Thanks for the detailed information.
          However after adding the group in to my reactor.yaml file MSR no longer starts or runs.
          My controller is called Ezlo_Plus
          I've tried both "Ezlo_Plus" and "ezlo_plus"
          - id: groups
              enable: true
              config:
                groups:
                      - include_controller: Ezlo_Plus
          Does it matter where abouts in the reactor.yaml file you add this code? I just added it in the Controllers section after my last "enabled" controller .
            Alternatively doing it the "old" way without using a Dynamic Group these two expressions seem to work and are correctly returning the names of the two currently failed devices on my Ezlo Plus Controller:
            FailedEzlo:
            each id in matchEntities( { capability: 'x_ezlo_device' } ):
                         ( getEntity(id)?.attributes.x_ezlo_device.reachable ) !=true ? id : null
            FailedNamesEzlo:
            join( each id in FailedEzlo: getEntity(id)?.name ?? id, ", " )
            • cw-kidC cw-kid
              @crille
              - id: groups
                  enable: true
                  config:
                    groups:
              @cw-kid The indentation of the groups controller was off in my post. I've corrected it. Please try again with correct indentation and your Reactor should start.
              The groups controller is in the right place in your config and include_controller should be the id of the Ezlo Plus controller.
              • CrilleC Crille
                @crille
                Great thanks I will try it again.
                I've not used Dynamic Groups before either, so you are giving me a good tutorial !
                  Any time you edit a config file and then Reactor doesn't start, you've likely corrupted the file. There's a troubleshooting section for startup in the documentation that will help you look at the logs (yes, once again, go look at the logs), and there are tools like https://yamlchecker.com that will also help you find errors, and there's this handy YAML editor https://onlineyamltools.com/edit-yaml
                  Edit: I wanted to add here that I routinely break my config files, so as fluent as I consider myself to be with YAML (begrudgingly, I'll admit), it's just touchy and mistakes are easy to make. I am working on a graphical editor for settings in the background, but it's a huge undertaking and a bit of an "all or nothing" deal, so it's got a long road ahead of it (or, really, I do).
