  4. [Solved] Which version of npm should we be running for reactor-latest-22118-0f0772c.tar.gz
8 Posts 3 Posters 1.2k Views 3 Watching
    I've borked my install of reactor-latest-22118-0f0772c.tar.gz for some reason and am retracing steps. Running npm i --no-save --omit dev prompted to update npm and I did (current version now 8.6.0). Currently, attempts to load via browser/s (Brave and Safari) result in "This site can’t be reached192.168.1.xxx refused to connect." I am still able to SSH into the RPi.
    I haven't panicked yet but did just pull my config and storage directories - I believe I read where that's enough for a back-up if a clean install ends up being needed.
    So the question of the day: which version of nmp should we be running on for the latest Reactor?
      npm version doesn't really matter, at least not in my experience. Sounds like your Reactor isn't starting up.
      Troubleshooting Startup - Reactor - Multi-Hub Automation
      G 2 Replies Last reply
          @toggledbits Hmmm, attempts to run Reactor manually are resulting in unhappiness. Have you seen issue, @toggledbits, with nodejs versioning? This is what I get when doing a node app.js from the install directory.
          Is it advisable to update as indicated?
            @gwp1 said in Which version of npm should we be running for reactor-latest-22118-0f0772c.tar.gz:
            It's mandatory.
            The easiest thing to do is re-run the install script. Start from step 3 of the RPi bare metal install instructions
              It's mandatory.
              @toggledbits Yep, pretty mandatory. As soon as the rpi-install script completed the house was filled with alerts and whatnot.
              I'm definitely confused as to how this blew up - thanks for the guidance as always, sir.
                Versions of nodejs below 16 were deprecated back in November, and I continued support through the end of March. This is the first release since then, and it contains a hard-stop test (as you saw) for a supported version. I added some detail about that to my release announcement in case others find themselves in the same boat.
                  About to do an entire kerrnel upgrade to get to nodejs 16. Still worries me 😉
                    154.3k
