reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
[Solved] suninfo.period "night" and rule trigger for sunset are at different times
Posters
729
Views
Watching
I'm just curious, what's the difference between
suninfo.periodchanging from "day" to "night" vs "after sunset" with no offset?
suninfo.periodchanges to "night" 7 minutes and 33 seconds before "after sunset" is triggered in my latest-22149 bare metal setup. -
Night in Reactor begins when the sun's true elevation is at or below the horizon. Sunset is a different time due to refraction. The sun appears higher "at sunset" (perceived) than it actually is. The graphic here helps illustrate.
