  4. Constraints under triggers or under constraints, what is the difference?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 3 Posters 968 Views 3 Watching
    Andr
    Need to ask, have thougth about this since the move from Rector to MSR I think.
    What is the difference between putting constraints under trigger groups, like this
    Compared to this similar rule, but the time limits is under contraints instead?
    I think the Constraints parts in manual is still to be done because I can only find in the chapter menu, but it is not mentioned anywhere else.
    F 1 Reply Last reply
    • A Andr
      @andr My understanding is that there is no difference - it's just like flavors; do what you prefer. Use the one that makes most sense for you.
      /Fanan
      • F Fanan
        /Fanan
        @fanan there's a big difference.
        Rule with two conditions: switch turned on, time between sunrise and sunset.
        If both are triggers, any time both become true, the rule sets. So, if the switch is on but it's 2am, not set. When sunrise arrives, rule sets.
        If sunrise/sunset is a constraint, the rule only sets when the switch changes state to on between sunrise and sunset. If the switch is on at 2am, not set. When sunrise comes and goes, the rule remains not set.
          163.0k
