  4. [SOLVED] FetchError: network timeout for API calls
3 Posts 2 Posters 1.6k Views 2 Watching
    I've been running into an issue with a couple APIs wherein they return the error FetchError: network timeout....
    A retry resolves but my ask here is around how I can monitor within MSR and trigger (at least) a notification if not a retry after a short delay.
      I would try increasing the request timeout, which defaults to 15 seconds. Some APIs can be pretty sluggish.
      Set http_request_action_timeout in the engine section of your reactor.yaml file to something larger than 15000 (the units are milliseconds).
        engine:
          enabled: true
          http_request_action_timeout: 60000  # milliseconds
          engine:
            enabled: true
        @toggledbits I'm guessing the default is somewhere in the code and adding the http_request_action_timeout entry to the config overrides? I only ask because I had no entry like that in my reactor.yaml file.
        In any case - I've added this line and bounced MSR. Will monitor. Thanks very much for this guidance!
          153.0k
