Reactor not starting on latest 21294
Just updated to latest 21294, ran usual update, It appears to start ok in console, but will not load in browser. The NODE_path looks correct but the console log show the below error.
log
NODE_PATH /data/data/com.termux/files/home/reactor: [latest-21294]2021-10-23T15:55:41.542Z <app:null> Reactor latest-21294-c13ea5d starting on v14.15.4 [latest-21294]2021-10-23T15:55:41.546Z <app:INFO> Process ID 14540; platform android/arm #1 SMP PREEMPT Wed Jan 16 09:21:08 CST 2019; locale en_US.UTF-8 [latest-21294]2021-10-23T15:55:41.547Z <app:INFO> Basedir /data/data/com.termux/files/home/reactor; data in /data/data/com.termux/files/home/reactor/storage [latest-21294]2021-10-23T15:55:41.548Z <app:INFO> NODE_PATH /data/data/com.termux/files/home/reactor: /data/data/com.termux/files/home/reactor/app.js:231 throw new Error(a0_0x4c6635(0xd9) + process[a0_0x4c6635(0xdb)][a0_0x4c6635(0x107)] + '\x20does\x20not\x20point\x20to\x20the\x20Reactor\x20install\x20directory'); ^ Error: Environment NODE_PATH=/data/data/com.termux/files/home/reactor: does not point to the Reactor install directory at Object.<anonymous> (/data/data/com.termux/files/home/reactor/app.js:231:15) at Module._compile (internal/modules/cjs/loader.js:1063:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10) at Module.load (internal/modules/cjs/loader.js:928:32) at Function.Module._load (internal/modules/cjs/loader.js:769:14) at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12) at internal/main/run_main_module.js:17:47 NODE_PATH /data/data/com.termux/files/home/reactor: [latest-21294]2021-10-23T15:55:41.796Z <app:null> Reactor latest-21294-c13ea5d starting on v14.15.4 [latest-21294]2021-10-23T15:55:41.800Z <app:INFO> Process ID 14547; platform android/arm #1 SMP PREEMPT Wed Jan 16 09:21:08 CST 2019; locale en_US.UTF-8 [latest-21294]2021-10-23T15:55:41.801Z <app:INFO> Basedir /data/data/com.termux/files/home/reactor; data in /data/data/com.termux/files/home/reactor/storage [latest-21294]2021-10-23T15:55:41.801Z <app:INFO> NODE_PATH /data/data/com.termux/files/home/reactor: /data/data/com.termux/files/home/reactor/app.js:231 throw new Error(a0_0x4c6635(0xd9) + process[a0_0x4c6635(0xdb)][a0_0x4c6635(0x107)] + '\x20does\x20not\x20point\x20to\x20the\x20Reactor\x20install\x20directory'); ^ ```===group ```java===
That suggests that
server/lib/Logger.jscannot be found under the directory given. Make sure your unzip and copy of the files from the distribution is complete.Edit: looking more carefully at it, it appears that the ':' at the end of the path in
NODE_PATHis not from the messages, but is actually in the path. That's an error. -
server/lib/Logger.jsis there in the reactor folder
I can start reactor withNODE_PATH=$(pwd) node app.jsand see it in browser
but usingnohup ./app.sh &i can not open reactor in browserapp,sh
#!/bin/bash WD="." if [ "$1" == "-C" ]; then WD=${2:-.} shift 2 fi WD=`realpath "${WD}"` cd $WD || exit 1 export NODE_PATH="${WD}:${NODE_PATH}" rm -f app.stop while [ ! -f app.stop ]; do node app.js $* >> logs/console.log 2>&1 [ $? -eq 127 ] && break; sleep 5 done exit 0is the : in line 11 the error?
I've had
app.shon my deprecation list for some time, so I don't use it or test with it. I may review that choice. -
Stay with what you've got. Clearly, we're not ready for
app.shto go away. I've improved the checks on NODE_PATH in the startup to prevent the error caused by the path separator and empty path, so the stock (unmodified)app.shshould work fine now. That change is in build 21297 just released. -
