  4. Build 21313 question
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
7 Posts 4 Posters 786 Views 4 Watching
    I am curious what this means ?
    "New system capability button to express state of a single button or contact closure."
    • Black CatB Offline
      Black CatB Offline
      Black Cat
      My guess is that it replaces the slider ON/OFF with a Push Button.
      aka Zedrally
        @cw-kid There is a new capability button that expresses common functionality for buttons and contact closures in MQTT, Home Assistant, and Hubitat. Think products like the Shelly Button, but could also be used for many other scene controllers.
        Also, can you please improve on the topic title here?
        Black CatB 1 Reply Last reply
          Black CatB Offline
          Black CatB Offline
          Black Cat
          You mean like this?
          Mimics a Momentary Push Button?
          aka Zedrally
            It has nothing to do with visuals or UI. It's all about data and capability.
              Black CatB Offline
              Black Cat
              The image shows the capability of the switch, which is momentary contact.
              Obviously something is being lost in translation as you don't see what I'm asking and I don't understand what your question is when translated.
              So the topic requires improvement as per your request.
              aka Zedrally
              • Black CatB Black Cat
                @black-cat The improvement being requested is to put some meat on the bones of the thread topic. "Build 21313 question" - way too vague. Updating to something along the lines of "Build 21313: new system capability button questions" so readers know what the thread is about and whether it is something they would read or offer input on is where Patrick was pointing the OP to (hence the link to the pinned post about Best Practices.)
                Hope that helps!
                *Hubitat C-7 2.4.3.177
                Core 2026.1.1
                MSR: latest-26011-c621bbc7
                • Next Release?
