  4. Is it possible to send notification via Gotify from "Notify" action?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
6 Posts 3 Posters 1.2k Views 3 Watching
    Alan_F
    I am running Gotify in a Docker container on my RPi4 and using the Gotify Android app for self-hosted notifications.
    I can send notifications from MSR using an http POST, but I'd like to be able to use the Notify action in MSR as it would be cleaner. I looked at the notifications.yaml file but I don't understand enough to know if it's possible to set up Gotify there or if it requires integration to MSR first.
    To notify using Gotify, I send a http POST with a header of "Content-Type: application/json"
    The request URL is: http://GotifyIP:port/message?token=TokEnStRinGfRomGoTiFy
    The request body is:
    { "title":"Alert Title Here", "message": "Message Here", "priority": priority_integer }
    (valid priorities are 0 to 9)
    So the variables for Gotify are:
    Server IP:port
    Token
    Title
    Message
    Priority
    Is it possible to set this up through the Notify action via notifications.yaml?
      Since that's not an officially-supported notifier, you'd have to use an HTTP Request action. If you'd like to write the Notify subclass as a third-party plugin, I can help you do that, if you're pretty fluent in JavaScript.
      A therealdbT 2 Replies Last reply
        Alan_F
        I'm not sure that I qualify as 'pretty fluent' in JavaScript. I use a little of it in Node-Red functions, but I often have to search for examples and use them as a template rather than being able to write JavaScript from a blank sheet. I'm willing to give it a shot if pointing me in the right direction won't use up too much of your time.
          @toggledbits said in Is it possible to send notification via Gotify from "Notify" action?:
          I'm interested, for my own notification subsystem, running via HTTP/MQTT.
          To be honest, I'll probably write a very generic system, to programmatically call a configurable endpoint, specified in the configuration. Something like (pseudo-config):
          - Url: http://localhost:5000/notification/toast
          - Method: GET
          - Params:
            - text
            - silent
            - chatid
          and just substitute them in the notify action, as you'll already doing - I guess - with the different notification systems.
            Yeah, that seems an obvious alternative to doing subclass after subclass for a bunch of less-used methods that run on web endpoints. The big issue is always doing an adequate job of the UI, which may not be an issue you have, but it reliably ends up being a large percentage of my time on almost everything. The config and the entire handling are complicated a bit more by simple things like "priority", where there's now a type to be honored in the payload JSON (POST body), and a range of numeric values that correspond to some human/text form (low, medium, high, junk, urgent, etc.). These are details that end up soaking time, and while the Engine's notification class already has a way of managing and exchanging this data with the UI, that format is not meant for end-user configuration/entry.
              @toggledbits yeah, accounting the different kind of styles is hard, but I think this is a specific use case for advanced scenarios, so I’ll trade it for a less advanced ui.
                883
                2.0k
                3.7k
                3.3k
                921
