  4. Plugin InfluxFeed - Selecting Capabilities for Export - how to
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
11 Posts 2 Posters 1.2k Views 2 Watching
  • N Offline
    N Offline
    hi, I'm trying to modify reator.yaml as illustrated in docs but no luck to change something, I continue to see only default capabilities/attributes.
    How can I understand better the problem?
    Example OWM:
    I want to add wx.feels_like and wx.pressure
    is it correct? if yes, there are no changes in db fields
      select_capabilities:
           x_ezlo_item: true
           wx:
                - feels_like
                - pressure
                - electric_meter_kwh
                - electric_meter_watt
    If I want to add these parameter?
    • x_ezlo_item.electric_meter_kwh
    • x_ezlo_item.electric_meter_watt
    After I did the changes, I let to start influxdb first and then MSR.
    Also creating new bucket, I don't see any changes.
    Synology - Docker
    Influxdb 2.1.1
    Reactor (Multi-hub) latest-21342-ead7ca9
    -Reactor (Multi-hub) 25082-3c348de6
    -Docker on Synology NAS
    -Ezlo firmware version 2.0.59.2471.8
    -HASS Docker 2025.2.5
    -ZWaveJSUI 10.1.3
    -Update 30/03/2025
      Can you show your entire config for InfluxDB plugin? The indenting of your example would be incorrect to start, so I'd like to see the whole thing and make sure you're starting from something that has a chance at being functional. This doesn't look right on its face, but being a subset of the entire, it's hard to be sure.
      • N Offline
        N Offline
        Hi, this is the config
        plugins:
          - id: influx
            # See the docs under Standard Plugins for configuration details.
            implementation: InfluxFeed
            enabled: true
              # influx_url - URL to access InfluxDB server (default: http://localhost:8086)
              influx_url: "http://10.0.4.71:8086"
              # ----- For InfluxDB 2.0+ ONLY -----
              # influx_token - Token from InfluxDB 2.0 UI (required)
              influx_token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
              # influx_org - Organization ID (required)
              influx_org: myhome
              # influx_bucket - Bucket name to which points are written (required)
              influx_bucket: reactor
              # ----- Optional (all versions) -----
              # influx_retention_policy - Retention policy (optional). If not specified,
              #                           the retention policy of the bucket/database
              #                           will be used.
              #influx_retention_policy: ""
              # ----- Filtering (all versions) -----
              # select_capabilities - Capabilities that should be exported in addition
              #                       to the defaults. These are key/value pairs. If the
              #                       value is false, the capability is not exported (so
              #                       you can override the default). If the value is an
              #                       object, it may contain an "attributes" key with an
              #                       array value containing the names of attributes to
              #                       be exported (other attributes in the capability
              #                       are ignored).
                light_sensor: true
                power_sensor: true
                dimming: false
                x_ezlo_item: true
              #  zwave_network: false  # do not export this capability
               wx:                   # export wx capability, but only named attributes
                    - temperature
                    - humidity
                    - feels_like
        -ZWaveJSUI 10.1.3
        -Update 30/03/2025
          OK. Your indenting is wonky and there's another error that's probably causing problems parsing the entire config. You should use a tool like https://yamlchecker.com on any changes you make (paste the entire config file) until you get used to the idiosyncrasies of YAML, and then any time you run into problems. There are also probably messages in the log file about problems reading the file, too, so be sure and always check there when something is not working as expected.
          Specifically, on line 42, you can't have object keys in this position, because line 41 defines a value (true) for x_ezlo_item. Using true says you want everything from that capability; it's a short-cut. If you mean to limit the set of attributes for x_ezlo_item, then the value there must be an object for which attributes is a key. So that would correctly look like this (other lines redacted for clarity):
                  x_ezlo_item:
          Your wx line (47) is not correctly indented, nor is the comment line before it, so that's going to be trouble as well. It should look like this in all:
          plugins:
            - id: influx
              enabled: true
                influx_org: myhome
                #                           will be used.
                #                       are ignored).
                  light_sensor: true
                  power_sensor: true
                  dimming: false
                  x_ezlo_item:
                  #zwave_network: false  # do not export this capability
                      - temperature
                      - humidity
                      - feels_like
          Unfortunately, I realize YAML is a nuisance, but JSON would be worse, I loathe XML and its progeny, and the Microsoft-ish INI format isn't really up to the task either. I begrudgingly chose YAML because there's little that's better, and a lot of tools and documentation for it. Eventually, there will be a GUI for this kind of configuration, but that's a good way off yet.
          • N Offline
            N Offline
            I corrected the file
            Valid YAML!
            Still no changes in influxdb
            I created a new bucket and new api tokens, when I go in "Explore" --> Filter Measurement -->Filter
            I see only default data:
            dimming is there
            no wx.feels_like
            and no x_ezlo_item
            also I stopped both container and I started first influxdb and then MSR, where I can check now?
            -ZWaveJSUI 10.1.3
            -Update 30/03/2025
              It will only log things when things change. So make sure you are making things happen.
              Also, what version of InfluxDB are you using?
              And check the log file, particularly the messages output at startup.
              • N Offline
                N Offline
                Is is version InfluxDB 2.1.1
                a lot of Warm from Ezlo
                [latest-21342]2021-12-11T22:44:11.586Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.599Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.615Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.633Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.637Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.637Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.637Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.638Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.639Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.639Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.640Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.640Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.641Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.641Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.642Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.642Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.643Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.643Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.644Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.644Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.648Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.649Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.649Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.649Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.657Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.657Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.658Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.658Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.659Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.660Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.660Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.660Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.663Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.663Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.663Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.664Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.665Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.666Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.666Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.666Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.667Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.668Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.668Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.669Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.670Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.670Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.671Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.671Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.693Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=door_lock cap keypad
                [latest-21342]2021-12-11T22:44:11.727Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 971ms
                [latest-21342]2021-12-11T22:44:11.728Z <EzloController:NOTICE> Controller EzloController#ezlo is now online.
                [latest-21342]2021-12-11T22:44:11.730Z <DynamicGroupController:ERR> DynamicGroupController#groups selector criterion invalid type, expecting object, got string (battery_power)
                [latest-21342]2021-12-11T22:44:11.731Z <DynamicGroupController:ERR> DynamicGroupController#groups error in selection for Group#groups>low_battery: Error: Invalid selector
                [latest-21342]2021-12-11T22:44:11.731Z <DynamicGroupController:CRIT> Error: Invalid selector
                    at DynamicGroupController._select (/opt/reactor/server/lib/DynamicGroupController.js:314:23)
                    at DynamicGroupController._update_group (/opt/reactor/server/lib/DynamicGroupController.js:219:44)
                    at /opt/reactor/server/lib/DynamicGroupController.js:298:38
                    at DynamicGroupController._update (/opt/reactor/server/lib/DynamicGroupController.js:295:82)
                    at /opt/reactor/server/lib/DynamicGroupController.js:174:42
                [latest-21342]2021-12-11T22:44:11.732Z <app:NOTICE> Starting HTTP server and API...
                [latest-21342]2021-12-11T22:44:11.737Z <app:NOTICE> Starting Reaction Engine...
                [latest-21342]2021-12-11T22:44:11.737Z <Engine:INFO> Reaction Engine starting
                [latest-21342]2021-12-11T22:44:11.738Z <Engine:INFO> Checking rule sets...
                [latest-21342]2021-12-11T22:44:11.747Z <Engine:INFO> Checking rules...
                [latest-21342]2021-12-11T22:44:11.748Z <Engine:INFO> Data check complete; no corrections.
                -ZWaveJSUI 10.1.3
                -Update 30/03/2025
                  Well, we're looking for InfluxDB messages at the moment. Anything?
                  • N Offline
                    N Offline
                    wrote on last edited by noelab
                    About InfluxDb I don't see any warn at startup
                    [latest-21342]2021-12-11T23:21:26.561Z <app:null> Reactor latest-21342-ead7ca9 starting on v16.11.1
                    [latest-21342]2021-12-11T23:21:26.562Z <app:INFO> Process ID 1; platform linux/x64 #42218 SMP Mon Oct 18 19:16:55 CST 2021; locale (undefined)
                    [latest-21342]2021-12-11T23:21:26.563Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
                    [latest-21342]2021-12-11T23:21:26.563Z <app:INFO> NODE_PATH=/opt/reactor
                    [latest-21342]2021-12-11T23:21:26.566Z <app:INFO> Configured locale (undefined); selected locale(s) en-US.UTF-8
                    [latest-21342]2021-12-11T23:21:26.588Z <app:INFO> Loaded locale en-US
                    [latest-21342]2021-12-11T23:21:26.597Z <Capabilities:null> Module Capabilities v21333
                    [latest-21342]2021-12-11T23:21:26.639Z <Plugin:null> Module Plugin v21186
                    [latest-21342]2021-12-11T23:21:26.644Z <TimerBroker:null> Module TimerBroker v21333
                    [latest-21342]2021-12-11T23:21:26.646Z <default:INFO> Module Entity v21334
                    [latest-21342]2021-12-11T23:21:26.650Z <Controller:null> Module Controller v21333
                    [latest-21342]2021-12-11T23:21:26.650Z <default:null> Module Structure v21338
                    [latest-21342]2021-12-11T23:21:26.658Z <default:null> Module Ruleset v21096
                    [latest-21342]2021-12-11T23:21:26.659Z <default:null> Module Rulesets v21096
                    [latest-21342]2021-12-11T23:21:26.667Z <GlobalExpression:null> Module GlobalExpression v21333
                    [latest-21342]2021-12-11T23:21:26.679Z <default:null> Module Rule v21337
                    [latest-21342]2021-12-11T23:21:26.683Z <GlobalReaction:null> Module GlobalReaction v21333
                    [latest-21342]2021-12-11T23:21:26.684Z <AlertManager:null> Module AlertManager v21333
                    [latest-21342]2021-12-11T23:21:26.685Z <default:null> Module Engine v21342
                    [latest-21342]2021-12-11T23:21:26.685Z <default:null> Module httpapi v21333
                    [latest-21342]2021-12-11T23:21:26.687Z <default:null> Module httpproxy v21333
                    [latest-21342]2021-12-11T23:21:26.702Z <default:null> Module wsapi v21334
                    [latest-21342]2021-12-11T23:21:26.703Z <app:NOTICE> Starting Structure...
                    [latest-21342]2021-12-11T23:21:26.740Z <InfluxFeed:null> Module InfluxFeed v21333
                    [latest-21342]2021-12-11T23:21:26.742Z <Structure:INFO> Structure#1 starting plugin influx (InfluxFeed)
                    [latest-21342]2021-12-11T23:21:26.743Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
                    [latest-21342]2021-12-11T23:21:26.752Z <VeraController:null> Module VeraController v21334
                    [latest-21342]2021-12-11T23:21:26.757Z <Structure:INFO> Structure#1 loading controller interface ezlo (EzloController)
                    [latest-21342]2021-12-11T23:21:26.769Z <EzloController:null> Module EzloController v21324
                    [latest-21342]2021-12-11T23:21:26.772Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000", "serial": "90000464" }
                    [latest-21342]2021-12-11T23:21:26.772Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
                    [latest-21342]2021-12-11T23:21:26.773Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                    [latest-21342]2021-12-11T23:21:26.777Z <DynamicGroupController:null> Module DynamicGroupController v21334
                    [latest-21342]2021-12-11T23:21:26.779Z <Structure:INFO> Structure#1 loading controller interface weather (OWMWeatherController)
                    [latest-21342]2021-12-11T23:21:26.783Z <OWMWeatherController:null> Module OWMWeatherController v21313
                    [latest-21342]2021-12-11T23:21:26.785Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                    [latest-21342]2021-12-11T23:21:26.788Z <SystemController:null> Module SystemController v21342
                    [latest-21342]2021-12-11T23:21:26.790Z <Structure:INFO> Starting controller VeraController#vera
                    [latest-21342]2021-12-11T23:21:26.790Z <VeraController:NOTICE> VeraController#vera starting
                    [latest-21342]2021-12-11T23:21:26.835Z <VeraController:INFO> VeraController#vera loaded mapping ver 21301 rev 1 format 1 notice
                    [latest-21342]2021-12-11T23:21:26.837Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
                    [latest-21342]2021-12-11T23:21:26.837Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
                    [latest-21342]2021-12-11T23:21:26.838Z <VeraController:INFO> VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state
                    [latest-21342]2021-12-11T23:21:26.850Z <Structure:INFO> Starting controller EzloController#ezlo
                    [latest-21342]2021-12-11T23:21:26.863Z <EzloController:INFO> EzloController#ezlo device mapping data loaded; checking...
                    [latest-21342]2021-12-11T23:21:26.866Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                    [latest-21342]2021-12-11T23:21:26.867Z <Structure:INFO> Starting controller DynamicGroupController#groups
                    [latest-21342]2021-12-11T23:21:26.869Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
                    [latest-21342]2021-12-11T23:21:26.870Z <Structure:INFO> Starting controller OWMWeatherController#weather
                    [latest-21342]2021-12-11T23:21:26.896Z <Structure:INFO> Starting controller SystemController#reactor_system
                    [latest-21342]2021-12-11T23:21:26.897Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
                    [latest-21342]2021-12-11T23:21:26.921Z <EzloController:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                    [latest-21342]2021-12-11T23:21:26.922Z <EzloController:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                    [latest-21342]2021-12-11T23:21:26.928Z <app:INFO> Structure running; pausing for controllers' initial ready
                    [latest-21342]2021-12-11T23:21:27.062Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://10.0.4.119:17000)
                    [latest-21342]2021-12-11T23:21:27.062Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub...
                    [latest-21342]2021-12-11T23:21:27.114Z <EzloController:INFO> EzloController#ezlo hub "90000464" is h2.1 (undefined) firmware "2.0.21.1785.1"
                    [latest-21342]2021-12-11T23:21:27.151Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
                    [latest-21342]2021-12-11T23:21:27.152Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
                    [latest-21342]2021-12-11T23:21:27.396Z <VeraController:NOTICE> Controller VeraController#vera is now online.
                    -ZWaveJSUI 10.1.3
                    -Update 30/03/2025
                      OK. Thanks for uploading the logs and data. It looks like I made an error in the parsing of attribute lists. But, I think there's an easy workaround for you until I get a fix out... just change select_capabilities to default_capabilities. No other changes needed, I think.
                      • N Offline
                        N Offline
                        Thanks to you!
                        The fix is working.
                        Now I can truck energy consuption on Influxdb. The idea is to try to make in MSR what in HA is doing with utility_meter, Trend and Lovelace UI togheter. Maybe in future we will see a standard MSR energy plugin too.
                        Utility Meter
                        Utility Meter
                        Instructions on how to integrate the Utility Meter into Home Assistant.
                        Trend
                        Trend
                        Instructions on how to integrate Trend binary sensors into Home Assistant.
                        -ZWaveJSUI 10.1.3
                        -Update 30/03/2025
                          330
                        • Self test
                        • Possible feature request 2?
