  4. Plugin InfluxFeed - Selecting Capabilities for Export - how to
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
Hi. First off this is an unsupported version of HS 2026.5.2 so happy to be told it's that. Currently running latest-26130-3d2a489a on a Debian Buster bare metal VM. I've been working on moving away from OpenLuup completely and up until now have been using some virtual switches t manage things like 'Is there anyone home' I have a binary sensor in HA that provides the same thing binary_sensor.someone_home which appears in MSR as hass>binary_sensor_someone_home HA shows on or off. MSR shows true or false All fine. The odd thing happened after an update of HA and a restart. From HA 13:07:04 it turned off 13:07:11 it turned on However that does not appear to have been reflected in MSR which turned all the heating and so on off as it is supposed to do, and I got all my notifications as I should. Here's a huge log section (sorry) as I wanted to show how MSR identifies that HA is up and running at 12:07:08 (Zulu) but triggers the 'There's no one here' at 12:07:17 some 6 seconds after HA updated to on. Checking in the interface MSR said the status was 'False' while HA stated 'On' rule-mkwk2fwa.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwk2fwa","rules",{"id":1,"serial":4,"triggers":5,"constraints":21,"expressions":24,"name":25,"react_set":26,"react_reset":88,"ruleset":91},16,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":20},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18,19],null,"not_home",25351,{"type":6,"id":22,"op":8,"conditions":23},"cons",[],{},"Rachel is on the move",{"id":27,"actions":28,"rule":1,"editor_version":87,"set":61},"rule-mkwk2fwa:S",[29,35,62,83],{"id":30,"type":31,"data":32},"24kv27go","setvar",{"var":33,"value":34},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":36,"type":6,"actions":37,"constraints":46},"rule-mkwk2fwa:S-24kv7qgg",[38],{"id":39,"type":12,"data":40},"24kv4y1v",{"entity":41,"action":42,"args":43},"hass>system","x_hass_system.call_service",{"service":44,"data":45},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":47,"name":48,"type":6,"op":8,"conditions":49,"editor_version":20},"rule-mkwk2fwa:S-24kv7qgg-cons","Group Constraints Copy",[50,55],{"id":51,"type":52,"data":53},"cond24kv89zv","comment",{"comment":54},"Should speak only when I'm home",{"id":56,"type":12,"data":57},"cond24kv7qgh",{"entity":58,"attribute":59,"op":60,"value":61},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":63,"type":6,"actions":64,"constraints":72},"rule-mkwk2fwa:S-24kv2lon",[65],{"id":66,"type":67,"data":68},"28xz6paf","notify",{"method":69,"message":70,"profile":71},"Telegram","Rachel has left the ${{g_rachel_last_area}} zone and is in transit","default",{"id":73,"name":48,"type":6,"op":8,"conditions":74,"editor_version":20},"rule-mkwk2fwa:S-24kv2lon-cons",[75,79],{"id":76,"type":52,"data":77},"cond24kvlpae",{"comment":78},"Should telegram while I am away",{"id":80,"type":12,"data":81},"cond24kvkyz7",{"entity":58,"attribute":59,"op":60,"value":82},false,{"id":84,"type":52,"data":85},"24kv7hvk",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwk2fwa:R",[],"rs-l5sdq41x",2,1779017869959] rule-mkwk2fwa.json:{"id":"rule-mkwk2fwa","container":"rules","value":{"id":"rule-mkwk2fwa","serial":16,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":[null,"not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel is on the move","react_set":{"id":"rule-mkwk2fwa:S","actions":[{"id":"24kv27go","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwk2fwa:S-24kv7qgg","type":"group","actions":[{"id":"24kv4y1v","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv7qgg-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwk2fwa:S-24kv2lon","type":"group","actions":[{"id":"28xz6paf","type":"notify","data":{"method":"Telegram","message":"Rachel has left the ${{g_rachel_last_area}} zone and is in transit","profile":"default"}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv2lon-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvlpae","type":"comment","data":{"comment":"Should telegram while I am away"}},{"id":"cond24kvkyz7","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kv7hvk","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwk2fwa","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwk2fwa:R","actions":[],"rule":"rule-mkwk2fwa","set":false},"ruleset":"rs-l5sdq41x"},"serial":2,"tss":1779017869959,"tsc":1779017869959} rule-mkwlg11o.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwlg11o","rules",{"id":1,"serial":4,"triggers":5,"constraints":20,"expressions":23,"name":24,"react_set":25,"react_reset":88,"ruleset":91},5,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":19},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18],"not_home",25351,{"type":6,"id":21,"op":8,"conditions":22},"cons",[],{},"Rachel has arrived",{"id":26,"actions":27,"rule":1,"editor_version":87,"set":65},"rule-mkwlg11o:S",[28,33,39,66,83],{"id":29,"type":30,"data":31},"24kvboht","script",{"expr":32},"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state",{"id":34,"type":35,"data":36},"24kvbohu","setvar",{"var":37,"value":38},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":40,"type":6,"actions":41,"constraints":50},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv",[42],{"id":43,"type":12,"data":44},"24kvbohw",{"entity":45,"action":46,"args":47},"hass>system","x_hass_system.call_service",{"service":48,"data":49},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":51,"name":52,"type":6,"op":8,"conditions":53,"editor_version":19},"24kvbohv-cons","Group Constraints Copy",[54,59],{"id":55,"type":56,"data":57},"cond24kv89zv","comment",{"comment":58},"Should speak only when I'm home",{"id":60,"type":12,"data":61},"cond24kv7qgh",{"entity":62,"attribute":63,"op":64,"value":65},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":67,"type":6,"actions":68,"constraints":76},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx",[69],{"id":70,"type":71,"data":72},"24kvbohy","notify",{"method":73,"message":74,"profile":75},"Telegram","Rachel has arrived in the ${{g_rachel_last_area}} zone.","default",{"id":77,"name":52,"type":6,"op":8,"conditions":78,"editor_version":19},"24kvbohx-cons",[79],{"id":80,"type":12,"data":81},"cond24kvmzfp",{"entity":62,"attribute":63,"op":64,"value":82},false,{"id":84,"type":56,"data":85},"24kvbohz",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwlg11o:R",[],"rs-l5sdq41x",1,1770023368433] rule-mkwlg11o.json:{"id":"rule-mkwlg11o","container":"rules","value":{"id":"rule-mkwlg11o","serial":5,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":["not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel has arrived","react_set":{"id":"rule-mkwlg11o:S","actions":[{"id":"24kvboht","type":"script","data":{"expr":"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state"}},{"id":"24kvbohu","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv","type":"group","actions":[{"id":"24kvbohw","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"24kvbohv-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx","type":"group","actions":[{"id":"24kvbohy","type":"notify","data":{"method":"Telegram","message":"Rachel has arrived in the ${{g_rachel_last_area}} zone.","profile":"default"}}],"constraints":{"id":"24kvbohx-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvmzfp","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kvbohz","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwlg11o","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwlg11o:R","actions":[],"rule":"rule-mkwlg11o","set":false},"ruleset":"rs-l5sdq41x"},"serial":1,"tss":1770023368433,"tsc":1770023368433} catman@openluup:~/reactor/storage/rules$ exit logout Connection to 192.168.70.249 closed. catman@ChrisMBP2021 ~ % ./NotVera ** WARNING: connection is not using a post-quantum key exchange algorithm. ** This session may be vulnerable to "store now, decrypt later" attacks. ** The server may need to be upgraded. See https://openssh.com/pq.html Linux openluup 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon May 18 12:13:38 2026 from 192.168.70.69 cdcatman@openluup:~$ cd reactor/lo locales/ logs/ catman@openluup:~$ cd reactor/logs/ catman@openluup:~/reactor/logs$ ls console.log hass_config.json hass_services-2025-11-1.json hass_services-2026-1-0.json hass_services-2026-5-2.json reactor.log reactor.log.4 vera-user_data-initial.json device_32 hass_device_registry.json hass_services-2025-11-2.json hass_services-2026-1-1.json hass_services.json reactor.log.1 reactor.log.5 e hass_entity_registry.json hass_services-2025-11-3.json hass_services-2026-4-2.json hass_sources.json reactor.log.2 unhandled.json hass_area_registry.json hass_integrations.json hass_services-2025-7-2.json hass_services-2026-4-4.json hass_states.json reactor.log.3 vera-status-initial.json catman@openluup:~/reactor/logs$ less reactor.log catman@openluup:~/reactor/logs$ tail reactor.log [latest-26130]2026-05-19T12:20:08.296Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:03.391Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:08.729Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:21:08.734Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:22:03.501Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:22:08.614Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:22:08.624Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:23:03.590Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:23:08.503Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:23:08.506Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] catman@openluup:~/reactor/logs$ less reactor.log [latest-26130]2026-05-19T12:07:17.946Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9yjy9z/trig [latest-26130]2026-05-19T12:07:17.947Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.961Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9ylxw3/trig [latest-26130]2026-05-19T12:07:17.962Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.995Z <Engine:INFO> Enqueueing "Heating Control Mode is Home<RESET>" (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:17.996Z <Engine:INFO> Enqueueing "House Mode is Home<RESET>" (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Play / Pause<SET>" (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Vol+<SET>" (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:17.998Z <Engine:INFO> Enqueueing "Cyrus Stream Vol-<SET>" (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.000Z <Engine:NOTICE> Starting reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:18.000Z <Engine:INFO> Engine#1 perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } by reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) step 1 [latest-26130]2026-05-19T12:07:18.000Z <HassController:INFO> HassController#hass perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass service homeassistant.turn_off target data is { } (empty), assuming default entity target [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass: sending payload for power_switch.off on Entity#hass>input_boolean_heating_mode action: { "type": "call_service", "service_data": { }, "domain": "homeassistant", "service": "turn_off", "target": { "entity_id": "input_boolean.heating_mode" } } [latest-26130]2026-05-19T12:07:18.017Z <Engine:NOTICE> Starting reaction House Mode is Home<RESET> (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:18.018Z <Engine:INFO> House Mode is Home<RESET> all actions completed. [latest-26130]2026-05-19T12:07:18.074Z <Engine:NOTICE> Starting reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:18.076Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } by reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) step 1 [latest-26130]2026-05-19T12:07:18.076Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } [latest-26130]2026-05-19T12:07:18.077Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.090Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:18.091Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } by reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) step 1 [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.093Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.093Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } by reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) step 1 [latest-26130]2026-05-19T12:07:18.094Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } [latest-26130]2026-05-19T12:07:18.111Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.113Z <Rule:INFO> Rule#rule-l5sdqazh reaction rule-l5sdqazh:R completed This is hardly the end of the world as HA restarting is rare and I simply hit refresh on the entity in MSR but is this some kind of race condition or something that needs addressing? Hoping I've given enough data to make it sensible C
11 Posts 2 Posters 1.8k Views 2 Watching
  • N Offline
    N Offline
    hi, I'm trying to modify reator.yaml as illustrated in docs but no luck to change something, I continue to see only default capabilities/attributes.
    How can I understand better the problem?
    Example OWM:
    I want to add wx.feels_like and wx.pressure
    is it correct? if yes, there are no changes in db fields
      select_capabilities:
           x_ezlo_item: true
           wx:
                - feels_like
                - pressure
                - electric_meter_kwh
                - electric_meter_watt
    If I want to add these parameter?
    • x_ezlo_item.electric_meter_kwh
    • x_ezlo_item.electric_meter_watt
    After I did the changes, I let to start influxdb first and then MSR.
    Also creating new bucket, I don't see any changes.
    Synology - Docker
    Influxdb 2.1.1
    Reactor (Multi-hub) latest-21342-ead7ca9
    -Reactor (Multi-hub) 26011-c621bbc7
    -Docker on Synology NAS
    -Ezlo firmware version 2.0.59.2471.8
    -HASS Docker 2026.4.1
    -ZWaveJSUI 15.22.1
    -Update 01/04/2026
      Can you show your entire config for InfluxDB plugin? The indenting of your example would be incorrect to start, so I'd like to see the whole thing and make sure you're starting from something that has a chance at being functional. This doesn't look right on its face, but being a subset of the entire, it's hard to be sure.
      • N Offline
        N Offline
        Hi, this is the config
        plugins:
          - id: influx
            # See the docs under Standard Plugins for configuration details.
            implementation: InfluxFeed
            enabled: true
              # influx_url - URL to access InfluxDB server (default: http://localhost:8086)
              influx_url: "http://10.0.4.71:8086"
              # ----- For InfluxDB 2.0+ ONLY -----
              # influx_token - Token from InfluxDB 2.0 UI (required)
              influx_token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
              # influx_org - Organization ID (required)
              influx_org: myhome
              # influx_bucket - Bucket name to which points are written (required)
              influx_bucket: reactor
              # ----- Optional (all versions) -----
              # influx_retention_policy - Retention policy (optional). If not specified,
              #                           the retention policy of the bucket/database
              #                           will be used.
              #influx_retention_policy: ""
              # ----- Filtering (all versions) -----
              # select_capabilities - Capabilities that should be exported in addition
              #                       to the defaults. These are key/value pairs. If the
              #                       value is false, the capability is not exported (so
              #                       you can override the default). If the value is an
              #                       object, it may contain an "attributes" key with an
              #                       array value containing the names of attributes to
              #                       be exported (other attributes in the capability
              #                       are ignored).
                light_sensor: true
                power_sensor: true
                dimming: false
                x_ezlo_item: true
              #  zwave_network: false  # do not export this capability
               wx:                   # export wx capability, but only named attributes
                    - temperature
                    - humidity
                    - feels_like
        -ZWaveJSUI 15.22.1
        -Update 01/04/2026
          OK. Your indenting is wonky and there's another error that's probably causing problems parsing the entire config. You should use a tool like https://yamlchecker.com on any changes you make (paste the entire config file) until you get used to the idiosyncrasies of YAML, and then any time you run into problems. There are also probably messages in the log file about problems reading the file, too, so be sure and always check there when something is not working as expected.
          Specifically, on line 42, you can't have object keys in this position, because line 41 defines a value (true) for x_ezlo_item. Using true says you want everything from that capability; it's a short-cut. If you mean to limit the set of attributes for x_ezlo_item, then the value there must be an object for which attributes is a key. So that would correctly look like this (other lines redacted for clarity):
                  x_ezlo_item:
          Your wx line (47) is not correctly indented, nor is the comment line before it, so that's going to be trouble as well. It should look like this in all:
          plugins:
            - id: influx
              enabled: true
                influx_org: myhome
                #                           will be used.
                #                       are ignored).
                  light_sensor: true
                  power_sensor: true
                  dimming: false
                  x_ezlo_item:
                  #zwave_network: false  # do not export this capability
                      - temperature
                      - humidity
                      - feels_like
          Unfortunately, I realize YAML is a nuisance, but JSON would be worse, I loathe XML and its progeny, and the Microsoft-ish INI format isn't really up to the task either. I begrudgingly chose YAML because there's little that's better, and a lot of tools and documentation for it. Eventually, there will be a GUI for this kind of configuration, but that's a good way off yet.
          • N Offline
            N Offline
            I corrected the file
            Valid YAML!
            Still no changes in influxdb
            I created a new bucket and new api tokens, when I go in "Explore" --> Filter Measurement -->Filter
            I see only default data:
            dimming is there
            no wx.feels_like
            and no x_ezlo_item
            also I stopped both container and I started first influxdb and then MSR, where I can check now?
            -ZWaveJSUI 15.22.1
            -Update 01/04/2026
              It will only log things when things change. So make sure you are making things happen.
              Also, what version of InfluxDB are you using?
              And check the log file, particularly the messages output at startup.
              • N Offline
                N Offline
                Is is version InfluxDB 2.1.1
                a lot of Warm from Ezlo
                [latest-21342]2021-12-11T22:44:11.586Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.599Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.615Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.633Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.637Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.637Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.637Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.638Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.639Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.639Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.640Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.640Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.641Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.641Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.642Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.642Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.643Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.643Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.644Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.644Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.648Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.649Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.649Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.649Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.657Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.657Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.658Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.658Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.659Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.660Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.660Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.660Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.663Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.663Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.663Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.664Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.665Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.666Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.666Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.666Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.667Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.668Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.668Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.669Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.670Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.670Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.671Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.671Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.693Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=door_lock cap keypad
                [latest-21342]2021-12-11T22:44:11.727Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 971ms
                [latest-21342]2021-12-11T22:44:11.728Z <EzloController:NOTICE> Controller EzloController#ezlo is now online.
                [latest-21342]2021-12-11T22:44:11.730Z <DynamicGroupController:ERR> DynamicGroupController#groups selector criterion invalid type, expecting object, got string (battery_power)
                [latest-21342]2021-12-11T22:44:11.731Z <DynamicGroupController:ERR> DynamicGroupController#groups error in selection for Group#groups>low_battery: Error: Invalid selector
                [latest-21342]2021-12-11T22:44:11.731Z <DynamicGroupController:CRIT> Error: Invalid selector
                    at DynamicGroupController._select (/opt/reactor/server/lib/DynamicGroupController.js:314:23)
                    at DynamicGroupController._update_group (/opt/reactor/server/lib/DynamicGroupController.js:219:44)
                    at /opt/reactor/server/lib/DynamicGroupController.js:298:38
                    at DynamicGroupController._update (/opt/reactor/server/lib/DynamicGroupController.js:295:82)
                    at /opt/reactor/server/lib/DynamicGroupController.js:174:42
                [latest-21342]2021-12-11T22:44:11.732Z <app:NOTICE> Starting HTTP server and API...
                [latest-21342]2021-12-11T22:44:11.737Z <app:NOTICE> Starting Reaction Engine...
                [latest-21342]2021-12-11T22:44:11.737Z <Engine:INFO> Reaction Engine starting
                [latest-21342]2021-12-11T22:44:11.738Z <Engine:INFO> Checking rule sets...
                [latest-21342]2021-12-11T22:44:11.747Z <Engine:INFO> Checking rules...
                [latest-21342]2021-12-11T22:44:11.748Z <Engine:INFO> Data check complete; no corrections.
                -ZWaveJSUI 15.22.1
                -Update 01/04/2026
                  Well, we're looking for InfluxDB messages at the moment. Anything?
                  • N Offline
                    N Offline
                    wrote on last edited by noelab
                    About InfluxDb I don't see any warn at startup
                    [latest-21342]2021-12-11T23:21:26.561Z <app:null> Reactor latest-21342-ead7ca9 starting on v16.11.1
                    [latest-21342]2021-12-11T23:21:26.562Z <app:INFO> Process ID 1; platform linux/x64 #42218 SMP Mon Oct 18 19:16:55 CST 2021; locale (undefined)
                    [latest-21342]2021-12-11T23:21:26.563Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
                    [latest-21342]2021-12-11T23:21:26.563Z <app:INFO> NODE_PATH=/opt/reactor
                    [latest-21342]2021-12-11T23:21:26.566Z <app:INFO> Configured locale (undefined); selected locale(s) en-US.UTF-8
                    [latest-21342]2021-12-11T23:21:26.588Z <app:INFO> Loaded locale en-US
                    [latest-21342]2021-12-11T23:21:26.597Z <Capabilities:null> Module Capabilities v21333
                    [latest-21342]2021-12-11T23:21:26.639Z <Plugin:null> Module Plugin v21186
                    [latest-21342]2021-12-11T23:21:26.644Z <TimerBroker:null> Module TimerBroker v21333
                    [latest-21342]2021-12-11T23:21:26.646Z <default:INFO> Module Entity v21334
                    [latest-21342]2021-12-11T23:21:26.650Z <Controller:null> Module Controller v21333
                    [latest-21342]2021-12-11T23:21:26.650Z <default:null> Module Structure v21338
                    [latest-21342]2021-12-11T23:21:26.658Z <default:null> Module Ruleset v21096
                    [latest-21342]2021-12-11T23:21:26.659Z <default:null> Module Rulesets v21096
                    [latest-21342]2021-12-11T23:21:26.667Z <GlobalExpression:null> Module GlobalExpression v21333
                    [latest-21342]2021-12-11T23:21:26.679Z <default:null> Module Rule v21337
                    [latest-21342]2021-12-11T23:21:26.683Z <GlobalReaction:null> Module GlobalReaction v21333
                    [latest-21342]2021-12-11T23:21:26.684Z <AlertManager:null> Module AlertManager v21333
                    [latest-21342]2021-12-11T23:21:26.685Z <default:null> Module Engine v21342
                    [latest-21342]2021-12-11T23:21:26.685Z <default:null> Module httpapi v21333
                    [latest-21342]2021-12-11T23:21:26.687Z <default:null> Module httpproxy v21333
                    [latest-21342]2021-12-11T23:21:26.702Z <default:null> Module wsapi v21334
                    [latest-21342]2021-12-11T23:21:26.703Z <app:NOTICE> Starting Structure...
                    [latest-21342]2021-12-11T23:21:26.740Z <InfluxFeed:null> Module InfluxFeed v21333
                    [latest-21342]2021-12-11T23:21:26.742Z <Structure:INFO> Structure#1 starting plugin influx (InfluxFeed)
                    [latest-21342]2021-12-11T23:21:26.743Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
                    [latest-21342]2021-12-11T23:21:26.752Z <VeraController:null> Module VeraController v21334
                    [latest-21342]2021-12-11T23:21:26.757Z <Structure:INFO> Structure#1 loading controller interface ezlo (EzloController)
                    [latest-21342]2021-12-11T23:21:26.769Z <EzloController:null> Module EzloController v21324
                    [latest-21342]2021-12-11T23:21:26.772Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000", "serial": "90000464" }
                    [latest-21342]2021-12-11T23:21:26.772Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
                    [latest-21342]2021-12-11T23:21:26.773Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                    [latest-21342]2021-12-11T23:21:26.777Z <DynamicGroupController:null> Module DynamicGroupController v21334
                    [latest-21342]2021-12-11T23:21:26.779Z <Structure:INFO> Structure#1 loading controller interface weather (OWMWeatherController)
                    [latest-21342]2021-12-11T23:21:26.783Z <OWMWeatherController:null> Module OWMWeatherController v21313
                    [latest-21342]2021-12-11T23:21:26.785Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                    [latest-21342]2021-12-11T23:21:26.788Z <SystemController:null> Module SystemController v21342
                    [latest-21342]2021-12-11T23:21:26.790Z <Structure:INFO> Starting controller VeraController#vera
                    [latest-21342]2021-12-11T23:21:26.790Z <VeraController:NOTICE> VeraController#vera starting
                    [latest-21342]2021-12-11T23:21:26.835Z <VeraController:INFO> VeraController#vera loaded mapping ver 21301 rev 1 format 1 notice
                    [latest-21342]2021-12-11T23:21:26.837Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
                    [latest-21342]2021-12-11T23:21:26.837Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
                    [latest-21342]2021-12-11T23:21:26.838Z <VeraController:INFO> VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state
                    [latest-21342]2021-12-11T23:21:26.850Z <Structure:INFO> Starting controller EzloController#ezlo
                    [latest-21342]2021-12-11T23:21:26.863Z <EzloController:INFO> EzloController#ezlo device mapping data loaded; checking...
                    [latest-21342]2021-12-11T23:21:26.866Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                    [latest-21342]2021-12-11T23:21:26.867Z <Structure:INFO> Starting controller DynamicGroupController#groups
                    [latest-21342]2021-12-11T23:21:26.869Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
                    [latest-21342]2021-12-11T23:21:26.870Z <Structure:INFO> Starting controller OWMWeatherController#weather
                    [latest-21342]2021-12-11T23:21:26.896Z <Structure:INFO> Starting controller SystemController#reactor_system
                    [latest-21342]2021-12-11T23:21:26.897Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
                    [latest-21342]2021-12-11T23:21:26.921Z <EzloController:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                    [latest-21342]2021-12-11T23:21:26.922Z <EzloController:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                    [latest-21342]2021-12-11T23:21:26.928Z <app:INFO> Structure running; pausing for controllers' initial ready
                    [latest-21342]2021-12-11T23:21:27.062Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://10.0.4.119:17000)
                    [latest-21342]2021-12-11T23:21:27.062Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub...
                    [latest-21342]2021-12-11T23:21:27.114Z <EzloController:INFO> EzloController#ezlo hub "90000464" is h2.1 (undefined) firmware "2.0.21.1785.1"
                    [latest-21342]2021-12-11T23:21:27.151Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
                    [latest-21342]2021-12-11T23:21:27.152Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
                    [latest-21342]2021-12-11T23:21:27.396Z <VeraController:NOTICE> Controller VeraController#vera is now online.
                    -ZWaveJSUI 15.22.1
                    -Update 01/04/2026
                      OK. Thanks for uploading the logs and data. It looks like I made an error in the parsing of attribute lists. But, I think there's an easy workaround for you until I get a fix out... just change select_capabilities to default_capabilities. No other changes needed, I think.
                      • N Offline
                        N Offline
                        Thanks to you!
                        The fix is working.
                        Now I can truck energy consuption on Influxdb. The idea is to try to make in MSR what in HA is doing with utility_meter, Trend and Lovelace UI togheter. Maybe in future we will see a standard MSR energy plugin too.
                        Utility Meter
                        Utility Meter
                        Instructions on how to integrate the Utility Meter into Home Assistant.
                        Trend
                        Trend
                        Instructions on how to integrate Trend binary sensors into Home Assistant.
                        -ZWaveJSUI 15.22.1
                        -Update 01/04/2026
                          124.1k
