Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
Build 21360
- PR 0000282: DynamicGroupController: fix an error that could cause preloading of entities to fail (started in 21356).
- Updated lexpjs to 21360 to correctly handle assignment to object/array members.
Build 21365
- HassController: Add
fire_event
action on system device, to fire any event. - Deprecation warning when starting on nodejs version < 16 (still runs, just a notice).
- HubitatController: Enforce strict ordering on initial mode and HSM queries.
- HassController: Bless Hass version to 2021.12.7
- Docs: Add startup troubleshooting page to Troubleshooting section.
Build 22001
- PR 0000284: Rule Editor: Add function to clone condition or group
- PR 0000287: Date comparison error in "between" that spans year (MDHM form); resets incorrectly at 01-01T00:00 Fix end check for next edge
Happy New Year!
Build 22002
This version has only an EzloController fix, so those of you that don't use Ezlo hubs can skip this version.
- EzloController: Fix fast update attribute issue (hopefully). I can't fully test because my device selection is limited, but it works for what I have.
Build 22004
- PR 0000289: Fix detection of loops in expressions, and add more aggressive checks for some conditions previously missed; make sure self-referencing expressions are not considered loops.
- EzloController: Update connection error recovery; cloud auth and token requests are now only done when the controller specifically denies the current token, or when too many connection retries occur. Implement retry decay, to further reduce queries to Ezlo's cloud. Overall, this makes EzloController more resilient in the face of Internet and Ezlo cloud outages.
- Update the little-used (that may be about to change) encrypted status packager to work in docker containers.
Build 22021
Bare-metal install: you must run
npm i --no-save --omit dev
in your Reactor install directory to install new dependencies.- UI: Make it possible to bypass the About page at startup.
- UI: Status page now has movable, resizable widgets. A couple of new widgets have been introduced as well.
- HubitatController: Fix
volume.set
action (media players) - Support for
usermedia
directory insideconfig
; if present at startup, the built-in HTTP server will serve files from this directory (meant primarily for media/audio files, but will serve most common file types). This allows the user to serve files from the Reactor installation without the need to separately install Apache or another web server. - HassController: Bless Hass to 2021.12.10
- Engine: predicates have been refactored to tidy up the code and remove some duplication of functionality created when reaction group contraints were introduced.
- Clean up the
reactor_inet_check.sh
script (intools
). - Docker: the OS base for x64 generic and armv7l (RPi) is now Alpine version 3.14 (was 3.12);
Build 22022
Bare-metal users: you must remove any existing
package-lock.json
file from your Reactor install directory, and then runnpm i --no-save --omit dev
to update package dependencies. You will get a vulnerability warning; see this post. DO NOT runnpm audit fix
— it will break your Reactor install.Docker users on Raspbian Buster (Raspberry Pi): you must install a patch to run the Reactor image in a container. See the install instructions for the steps to install the patch.
Engine: New and very experimental Repeat While action group, repeats as long as its conditions are met. The group must have at least one condition or it will not run at all. The repeat will stop if either (a) the conditions result in false, or (b) if it's in a rule-based reaction, the contra-reaction is started by a change of rule state. It is quite possible to make reaction groups that never stop, so be careful with your logic here.This feature was not included.- UI: Fix "Recently Changed Entities" not updating dynamically.
- UI: Fix an error in the new widget text on the Status panel.
- The
node-fetch
package requirement has been updated to version 2.6.7 or higher (in the 2.x release path). This version is patched against CVE-2022-0235 according to the package author. Bare-metal users will need to remove any existingpackage-lock.json
file in their Reactor install directory, and then runnpm install --no-save --omit dev
— it will break your Reactor install. - Docs: Update package install instructions for bare-metal installs, and in the Troubleshooting section.
- Docs: Update docker container installation instructions for users of Raspbian Buster (only) with additional steps to install
libseccomp2
patch required to run the image.
Build 22023
package-lock.json
to update package dependencies. The previously reported vulnerability warning should no longer be present.Docker users on Raspbian Buster (Raspberry Pi): Reactor images since 22021 require that you install an OS patch to run the Reactor image in a container. See the install instructions for the steps to install it.
- PR 0000296: Fixed rule throttling caused by constraints subscribing for events when they should not.
- PR 0000297: Duplicate report for 0000296.
- PR 0000298: Global expressions not updating correctly, not triggering rules correctly.
- Engine: New and very experimental Repeat While action (a form of group), repeats as long as its conditions are met. The group must have at least one condition or it will not run at all. The repeat will stop if either (a) the conditions result in false or null, or (b) if it's in a rule-based reaction, the contra-reaction is started by a change of rule state. It is quite possible to make reaction groups that never stop, so be careful with your logic here.
Build 22025
Bare-metal users: updating package dependencies when updating Reactor is recommended. To update packages, you must first remove any existing
package-lock.json
.**Docker users on Raspbian Buster (Raspberry Pi): Reactor images since 22021 require that you install an OS patch to run the Reactor image in a container. See the install instructions for the steps to install it.
- VeraController: allow arrays for
filter_entity
andaccept_entity
to be consistent with other similar applications. - Fix an issue with setting a Rule's timebase before evaluation that may affect some rule-based expressions. Likely related to PR 0000301.
Build 22028
package-lock.json
- PR 0000301: Fix excess sensitivity to apparently unrelated devices in some conditions. I'm leaving this PR open; I think I know why this happened, and for my system it's working great, but I want to make sure I've covered all the bases, and because the fix was pretty aggressive, didn't inject anything new.
- Fix exception trying to subscribe to non-Observer in Variable Value condition.
- Logger: Allow
maxsize: 0
in log stream configuration for no log rotation at all. - Fix condition value seen on Date/Time conditions in rule status display (cosmetic).
- HubitatController: implement Reactor
energy_sensor
capability; replacesx_hubitat_energymeter
, which is now deprecated.
MQTTController Build 22029 -- download
Please run the install script after unpacking the update.
- Echo function now publishes rule states and global variables. Please see the docs for more information.
Build 22044
- PR 0000306: Certain condition options not being saved for rule-based constraints.
- PR 0000305: Copying rule expression can renumber expression in source rule.
- PR 0000302: Reaction delay "from start" working same as "from this point".
- InfluxDB: Support for more extensive control of written measurements, including name and type modification; see docs
- Reactions: Fix an issue where missing device in a rule reaction does not flag trouble on the rule.
- Three new capabilities:
valve
,scene_activation
andbattery_maintenance
. These will be fully integrated with eligible Controllers and Entities in a future release. - Reactions: An error in a special form on the Comment action is fixed (simple notification).
- Expressions: New expression
case
statement; see docs - Expressions: Fix sort in
median()
function. - Expressions: An error in the
fileRead()
function has been fixed.
Build 22049
NOTE: Bare-metal users should run
npm i --no-save --omit-dev
to update packages for this release.- Update lexpjs for new
pad()
function - PR 0000307: Nested group would repeat interior actions outside group (reaction UI)
- Update to latest minor revisions of jquery-ui, bootstrap, popper. This now silences the long-endured warning when doing
Build 22053
BREAKING CHANGE/FIX This version contains what may be a breaking change for some users. Some actions offer lists of predefined values (e.g.
media_source.set
offershdmi1
,hdmi2
, etc.). A bug in the Reaction editor was causing a numeric index value to be stored instead of the string value (i.e. it would store 0 rather thanhdmi1
). The bug is now fixed, but any action like this previously created/edited may have had an invalid value stored in the rule or reaction to which it belongs, and this cannot be reliably automatically fixed, it generally requires user review. Most likely, these actions didn't work well for you anyway, because the erroneous numeric value would likely have given invalid results/behaviors/errors when attempted, and we just haven't noticed until now (they are fairly rarely-used actions, on the whole). The specific actions affected are:av_repeat.set_repeat
,muting.set
,media_source.set
,hvac_control.set_mode
,hvac_blower_unit.set_mode
,hvac_blower_swing.set_mode
,hvac_humidifier.set_moded
,hvac_dehumidifier.set_mode
,zwave_device.set_config
. Hopefully this list helps you narrow down what, if any, of your rules/reactions may be affected. Just take the rule/reaction into the editor, fix the new correct value and save.- PR 0000308: Fix issue where delay action with substitition in delay may self-replace evaluated value in stored object.
- UI: Autogrow fields get more room for datalist controls.
- UI: Fix issue with some value lists incorrectly showing and storing index values rather than actual listed value; see BREAKING notice above.
- Bless Hass to 2022.2.9
Build 22067
Bare-metal Users: Please run
when installing this update.- PR 0000309: Exception while evaluating global reaction predicate (conditional group).
- HubitatController: Attempt to eliminate additional query to fetch full device data when a device-change event is received from the hub. Please see the documentation for cautions.
- UI will now highlight deprecated capabilities, attributes and actions when used.
- Bless Hass to 2022.3.3
Just an FYI for everyone, I'll be on holiday from tomorrow March 10 through March 19, and I'm leaving the laptop on the shelf at home for this one. I can answer emails and forum posts, but I won't likely be checking more than once a day, and I won't doing builds or any bug fixing while away. See you all on the other side!
Build 22069
Note: Only users of Hubitat hubs need to upgrade to this version, and then only if you previously upgraded to 22067.
- HubitatController: Fix a possible loss of attribute change across restarts of the hub (that is, when a value changes during a Hubitat restart but Reactor is not restarted).
Build 22080
- PR 0000311: Vera Scene controller entities missing attributes in new and exisitng rules
- PR 0000310: Dependent global variable may not update after editing parent.
- HubitatController: Because the HE events websocket passes all values as strings, the new fast-update process introduced in 22067 would change (for example) a previously-numeric attribute value to a string when updated by the hub. While this doesn't generally bother conditions or expressions, the type change affects InfluxFeed because InfluxDB cannot digest the type change. The data type declared by the hub during inventory is now stored and used to remap the events feed values to keep the data types consistent on the attributes. It must be noted, however, that the data types of extension attributes (
x_hubname_...
) are driven by the hub, and are therefore not guaranteed by Reactor (types are guaranteed for Reactor-defined capabilities, e.g.dimming
,value_sensor
, etc.). Users exporting extension attributes into InfluxDB are advised to always use explicit type setting for those attributes in their InfluxFeed configuration. This advisory has been added to the documentation for InfluxFeed. - HubitatController: An inconsistency in the (HE) attribute names between their MediaPlayer and MusicPlayer capabilities with respect to transport state is now handled correctly, so that Reactor's native
av_transport.state
attribute shows a correct value regardless of which the device uses. - SystemController: Will now issue system alerts unconditionally when disk space becomes critical (unless disk space monitoring has been disabled by user configuration), in addition to the (previously available) values and flags on the
reactor_system>system
(Reactor System) entity. It's also probably a good idea to add notifications (i.e. in your own rules) for such conditions raised by the system entity, if the user is not regularly looking at the Reactor UI. See the documentation for SystemController. - SystemController: A
dst
(boolean) attribute has been added to thereactor_system>sun
(Sun Information) entity; it will be true when Daylight Saving Time is in effect, false otherwise. - HassController: Fix
cover
capability handling on non-positionable covers (e.g. garage doors). - Dashboard: New display for cover entities.
Build 22118 (latest and zwavejs) — PLEASE READ ALL ADVISORIES BELOW
NODEJS VERSION REQUIREMENT: As previously announced, nodejs versions below 16 are no longer supported as of 2022-Mar-31. Bare-metal users (only) will need to upgrade their nodejs to version 16 (the current LTS version) or higher. Bare-metal RPi users can use the install script to do this. Docker image users needn't concern themselves; the image is built with an approved version of nodejs.
NOTE: This release includes changes to package dependencies. Bare-metal users please run
to resolve.IMPORTANT: This update includes some significant enhancements for entity tracking. On your first startup after upgrading, you will get a lot of alerts about new devices being discovered (i.e. existing devices are being noted as new) as the enhanced tracking learns what is "normal" for your system. This is expected behavior for this version on its first startup. Just clear the alerts and go on about your day. After that, you should only receive notices when new devices are added to a hub, or new hubs are configured in Reactor.
Remember to hard-refresh all browsers after upgrading and restarting.
- PR 0000316: Variable Value condition with substitution in operand may replace expression with value in saved rule.
- PR 0000315: Improve alert message when a Rule-based reaction fails.
- PR 0000314: Fix "self-subscribe" exceptions logged after creating new Rule with local expressions and a Variable Value condition (exceptions clear after restart of Reactor).
- PR 0000312: Expressions
getEntity()
helper not listing or updating attributes correctly (fixed). - Raspberry Pi Install Script: Support for 64-bit installation on Raspbian Bullseye.
- Raspberry Pi Install Script: Can now be used to upgrade nodejs with a local (user-specific) install.
- UI: Faster core startup brings up the UI more quickly, and does not wait for controller startups, so a delay in a controller becoming ready (e.g. its associated hub is offline) will no longer delay the UI being available.
- UI: You can now add an SSL/TLS certificate and have the UI and API served over HTTPS (see How-To in documentation).
- New actions in
sys_system
capability to tell a Controller instance to purge unused entities (i.e. that no longer exist on the hub but are still present in Reactor), delete an entity (from Reactor only, not from the hub/mesh/etc.), and rename an entity (in Reactor, not at the hub/mesh/etc.). - UI/Entity Picker: You can now move the entity picker by dragging its title bar.
- UI/Entity Picker: The name search field will now also match on entity IDs.
- UI/Reaction editor: Changing from a group or while to another reaction type while editing would leave the conditions behind (they should be removed); fixed.
- Expressions: lexpjs updated, adds
yday
(day of year),isoweek
(ISO-8601 week number) anddst
(boolean) todateparts()
function result. - Status: Controller Status widget now sorts down/failed controllers first.
- Docs: Added How-Tos for serving media files from Reactor's built-in web server and set up HTTPS for the UI.
- HassController: Bless Hass version 2022.4.7.
REMINDER: If you need to post an issue related to this (or any) version, please follow the posting guidelines.
Build 22123 (latest and zwavejs)
This version primarily addresses a formatting problem in error messages when certain conditions (triggers and constraints) take an error (e.g. an Entity Attribute condition references an entity that no longer exists). This is cosmetic/display only and has no operational impact, but I thought it important to make a new release for the fix because of the difficulty of troubleshooting conditions with the broken messages.
If you are upgrading to this version from any version earlier than 22118, please read the release notes for 22118 in the prior post above.
