  4. `npm install --no-save --omit dev` gives vulnerability warning (node-fetch)
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 3 Posters 1.6k Views 3 Watching
    The node-fetch package, which is used by Reactor for several purposes, was reported to have a security vulnerability, and when you update packages (as is required for the recent 22021 release), you get a warning about it.
    NIST currently reports that all versions of node-fetch prior to 3.1.1 are vulnerable, but since the 2.x and 3.x release paths are incompatible, I cannot easily or quickly update Reactor to use 3.1.1. Further, the author of the package now reports that version 2.6.7 is patched against the vulnerability. It may take some time before NIST lists this fact on their web site and npm's audit info is also updated. His patch was made a week ago, so it's clearly not an instantaneous process.
    If you do npm ls in your Reactor install directory (bare metal users only), you will see what version you currently have installed.
    DO NOT run npm audit fix as recommended by npm. This will just break your Reactor installation by installing the incompatible 3.1.1 version. If you do this, you can undo it by running npm install --no-save --omit dev again. If that doesn't do it, delete your entire node_modules subdirectory and any package-lock.json file in the Reactor install directory, and run the command again.
    wmarcolinW 1 Reply Last reply
        Good news. Following instructions when installing 22022 no longer gives a vulnerability warning for me, Ubuntu bare metal.
        npm i --no-save --omit dev
        up to date, audited 90 packages in 566ms
        12 packages are looking for funding
          run `npm fund` for details
        found 0 vulnerabilities
        npm ls
        reactor-multi-system@1.0.3-22022
        ├── @influxdata/influxdb-client@1.22.0
        ├── @mdi/font@5.9.55
        ├── body-parser@1.19.1
        ├── bootstrap-icons@1.5.0
        ├── bootstrap@4.6.0
        ├── cookie@0.4.1
        ├── digest-fetch@1.2.1
        ├── diskusage-ng@1.0.2
        ├── express@4.17.2
        ├── feather-icons@4.28.0
        ├── font-awesome@4.7.0
        ├── gridstack@5.0.0
        ├── jquery-ui-dist@1.12.1
        ├── jquery@3.6.0
        ├── js-yaml@3.14.1
        ├── node-fetch@2.6.7
        ├── nodemailer@6.7.2
        ├── qs@6.10.3
        ├── serve-static@1.14.2
        ├── uuid@8.3.2
        └── ws@7.5.6
          163.1k
