  4. MQTT - add rules support ?
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
11 Posts 5 Posters 2.4k Views 5 Watching
  • X Offline
    X Offline
    xAPPO
    wrote on last edited by xAPPO
    I'm thinking that a useful feature in MQTT would be a topic entry for each rule within Reactor and their current state set or reset updating in real time.
    reactor/rules/myRule1  = reset
    reactor/rules/myRule2  = set
    Additionally a topic available that could trigger the rule from MQTT.
    reactor/rules/myRule1/trigger  = set
    I would have to think about whether this would trigger the rule always or only if other triggers are also satisfied or an option for either. I would like to avoid manually adding the MQTT payload value as a trigger into each and every rule to achieve this. Maybe I should look at this from Reactions perspective.
    What do you think ?
    New to Reactor but Im assuming an event is available to MQTT code that would advise when rules set and reset and a call available to trigger them manually, perhaps bypassing triggers ?
      I like the idea of publishing telemetry for rules. Unfortunately, the trigger state of a rule is (currently) not settable by anything other than the condition state that drives the triggers, and I think this is a vital consistency in the system, so I don't see that changing.
        Alan_F
        Would it be an acceptable workaround to add the capability to set an expression to the value of an incoming MQTT payload? That way one could set up a rule set that goes true if:
        Group 1: AND
           My condition 1
           My condition 2
        OR
        Group 2
           My expression changes from A to B
        So for a slightly more detailed example:
        My expression is named MQTT_Action_Switch1. It is set to the value of the payload of MQTT Topic "MSR/Action/Switch1"
        I make this rule:
        Group 1: AND
           Time is after 0800
           Motion sensor changes to true
        OR
        Group 2
           Expression MQTT_Action_Switch1 == true
        Set Action:
           Turn on switch1
           Set expression MQTT_Action_Switch1 == false
        So this rule goes true after 0800 when motion is sensed OR when the MQTT topic is received with a payload of True. It is self-resetting when set by MQTT, because the rule's set action resets the expression to false. Alternately if I leave off the last action, this rule would remain true until reset by something else setting MQTT_Action_Switch1 to false.
          I already expressed the desire to have mqtt messages as triggers. This is more flexible imho and gives us the ability to capture a message and parse in one or more expressions.
            Question: what should the topics for rules and global variables look like:
            reactor/mqtt/expr-somevariablename/value
            reactor/mqtt/expressions/somevariablename/value
            other?
            reactor/mqtt/rules/rule-948j23rj29/state
            reactor/mqtt/rule-398429223uf2/state
            other?
              other?
              other?
              @toggledbits I prefer these:
              reactor/mqtt/rules
              because it's easier to subscribe with filters. The beauty of MQTT message structure is that it's hierarchical.
                Alan_F
                My original thought was that there would be a syntax in the expression definition that would allow an expression to be set to any MQTT topic. So "my_expression" = "^{{MQTT/topic/subtopic/etc/etc}}" where ^{{...}} is the syntax for an MQTT topic just like ${{...}} is the syntax for an expression anywhere in MSR... picking the ^ symbol at random just as an example.
                This would allow the capturing of topics that may already be defined. For example I use Teslamate to pull data from the Tesla API related to my cars. It stores the data in a psql database and also publishes everything to MQTT, with topics like "teslamate/cars/1/plugged_in" and a payload of true or false. If I could set an expression to ^{{teslamate/cars/1/plugged_in}} (meaning the payload value of that topic) then I would be able to create rules that would react when this changed to true or false.
                If I have to format the topics in a certain way to get MSR to recognize them, then I can't use it for anything in MQTT where I don't control the topics.
                I get that this wouldn't work for directly calling rule actions. For that one would have to format the topic to what MSR is looking for, like reactor/mqtt/rules/...
                  I’m ok to use an entity as trigger via mqtt. Something like we’re doing now for entities, but to intercept messages using wildcard.
                  Then, pushing the value to an expression is an easy task.
                  Right now I’m mostly using my own bridge to accomplish this via virtual devices, but I’ll be more than happy to further streamline this thing.
                  • A Alan_F
                    CrilleC Online
                    CrilleC Online
                    @alan_f You could create your own MQTT Entity that could be used for trigger.
                    Just define the topics in local_mqtt_devices.yaml. You can change capability to Switch or any other that you prefer, this example is a Binary Sensor.
                    teslamate_sensor:
                      type: BinarySensor
                      capabilities: ['binary_sensor']
                      primary_attribute: binary_sensor.state
                      events:
                        "teslamate/cars/%topic%/plugged_in":
                          "binary_sensor.state":
                            expr: 'bool(payload)'
                    and use that template for your MQTT entity in reactor.yaml.
                    "teslamate":
                      topic: "1"
                      uses_template: teslamate_sensor
                    Your entity will now change state when something publishes true or false to the topics defined in your template.
                      @Alan_F The response by @Crille is correct... I was in mid-authoring of a similar post. You don't even need to make a template for it. Templates just make it easy to re-use topic/handling cross many entities, but if your topic is a one-off, you can do it all in line without a template as well:
                          entities:
                            teslamate_sensor:
                              type: BinarySensor
                              events:
                                "teslamate/cars/1/plugged_in":
                      And here's the silly example I was writing, showing how you can capture a JSON payload (or any part of it):
                            entities:
                              my_received_data:
                                name: "Some Topic I Watch"
                                capabilities:
                                  - "value_sensor"
                                events:
                                  "foo/bar/what/ever":
                                    "value_sensor.value":
                                      json_payload: true
                                      expr: payload
                      In this case, the expression at the end just captures the entire payload, but you could also write payload.somemember.deepermember to pick just one value from within the passed object (if it is an object).
                        Alan_F
                        @Crille Thanks! I was a bit confused when I first read that section of the MQTT documentation but your example using the topics from my own system helped clear it up for me.
                        I made a slight change to the template to make it "teslamate/cars/%topic%" which allows me to re-use it for multiple binary entities for both cars by using for example "topic: "1/locked" and "topic: 2/locked" for two entities in reactor.yaml.
                        I also hit a snag where trying to directly copy:
                            entities:
                              teslamate_sensor:
                                type: BinarySensor
                        caused Reactor not to start with a yaml formatting error, but referring to the documentation I changed it to:
                            entities:
                              teslamate_sensor:
                                type: BinarySensor
                                capabilities:
                                  - binary_sensor
                        moving the capability down one line with a leading "-" and it works.
                        Now I just have to find the time to write all the rules that are possible with the car information available in MSR... 👍
                          131.2k
