Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
zwavejs
51 Posts 10 Posters 23.8k Views 10 Watching
  • 3 Offline
    3 Offline
    Had some issues with Aqara motion sensors falling off my Hubitat after a few hours. (Yes, the manufacturer is not supported on HE.) But this led me down a path to stand up HA in my docker. Which then led me down another path of getting the zwavejs2mqtt docker running and integrated. So I may be down for this.
    Am I assuming that MSR will become my JS provider and I could possibly shutdown the zwavejs2mqtt docker?
    • R RogerO
      @toggledbits Any info on what and when this is coming?
      @rogero I got bogged down trying to get newer scene controllers to work, and I think I've got it now. Really nice, actually (using a Zooz ZEN32 for testing). Heck, I even got an ancient Everwave SC-7 working great, and it just wasn't reliable on Vera at all. The effort being put into Z-Wave JS really shows.
      @3rdstng said in Who are my Home Assistant + ZWave-JS users?:
      You'll either need to keep zwavejs2mqtt or install and run the zwave-js-server. I'm not doing a direct interface (i.e. library direct to serial port) just yet, but that's coming. The management tools of zwavejs2mqtt are pretty nice, so that's a good incentive to keep it.
        RogerO
        Excellent, I have a few of those installed and the Blueprints I found for them are not super dependable.
          RogerO
          @toggledbits Next you will be saying your Leviton scene controllers are working perfectly.
          • R RogerO
            @rogero I've had those going good for a while on Vera, using a plugin I wrote but never published (a few people got it, though... were you one of them?). I don't expect much trouble from them on Z-WaveJS. Also testing Hank 4-button and Remotec ZRC-90.
              RogerO
              Yes, I was one of the people you shared it with. It did work very well. Replaced them with the ZEN32's but at my age I cannot remember what 4 pushes of the bottom left button does, etc. Need to tape a legend to the wall. Look forward to having them running in MSR.
                Haven't forgotten you all... I've been working furiously at putting this together, including a new build system (because I'll be doing this release on a separate track, not in latest). I'm trying to get something out this weekend for a first look.
                Do any/all/none of you all use Discord?
                  RogerO
                  I do not.
                  • V Offline
                    V Offline
                    I don't, but I could if that's the way you want to communicate.
                    • V vezinpi
                      apocalypsehobby
                      @vezinpi said in Who are my Home Assistant + ZWave-JS users?:
                      Same
                        Just trying to gauge what people use. Doesn't seem like a path with enough support in this community, and that's fine; it's not my favorite, either.
                          #23
                          OK, I just PM'd the 9 of you that stepped up. If you replied on this post but didn't get a PM from me, let me know.
                          Some things to know about the test...
                          First and most important to Docker users, it runs on a different image from the mainstream latest, so you'll need to create a new container.
                          For all participants, the test code is bi-directionally compatible with the mainstream latest release path, so you'll be able to move back and forth between them if you need to. I think you'll be fine staying on the zwavejs track, and it will keep pace with other development throughout. Always make a backup of your config, of course, just in case, but you should be able to use the same config freely with any current version (the non-Zwave versions will complain about the controller not being available, though, and then move along).
                          I have a meager variety of devices to test with (lots of devices but limited in breadth of type and manufacturer), so I expect a lot of exceptions and oddities with the various devices out there. Don't panic. We know from all of our other Z-Wave platforms that manufacturers have leeway to do things within the spec, and they take it, and that complicates onboarding devices. Everyone goes through this. We won't be an exception.
                          I have to say, I'm really excited about this. ZWave-JS is really nice. First and foremost, it seems completely unbothered by device errors and mesh problems; it doesn't crash, delay, or do other things that other (ahem) platforms can't seem to get right. That alone makes it worth the effort. It's got a lot of support and the developers are really active. I have high hopes.
                          Discussion here is fine. Seems like the easiest way to go. Remember to be as complete as possible in your descriptions of issues, including device details, logs, etc. This version will create its own zwavejs.log, so that's a good place to start (and removes the noise of all the other subsystems).
                          There is data collection. The form you are asked to complete in the PM declares this as well, and you are asked to agree to it. It sends me a copy of your Z-WaveJS device inventory on startup, which will help (a lot) with device support. It does not send logs; that we'll have to do as needed. Happy to answer any questions on this, of course.
                            RogerO
                            @toggledbits Will you post a list of the devices you see in the initial survey from the nine participants? I have half my system on Vera and would move over any devices I have that are not on your list.
                            • K Offline
                              K Offline
                              kellyjelly32
                              Really appreciate the effort. My Vera with all the non-migrated Z-Wave is currently not reachable (holiday home). Can't migrate the devices to HA without being there. End of March I might be there to do it. Still need to find a way to get MSR to run. There is no easy way to run it on the same hardware my HA is running on (I run HA OS on bare metal). Or have I missed a MSR addon for HA?
                                sender
                                Question: I know reactor by name. Do I need it? I have 80 zwavjes devices and a fully loaded homeassistant (+20 integrations)
                                  RogerO
                                  I am running MSR in docker. I deleted MSR and installed the zwavejs version pointing to the MSR data directories. Didn't loose a thing.
                                  • V Offline
                                    V Offline
                                    #28
                                    Finally got there... MSR-zwavejs installation (docker) went very well, no issues there. It was a different story with HASS. I am running an unsupported version of Home Assistant Supervised on a raspberry pi (bulleyes). I had to get rid of the zwave2mqtt addon and install it by itself (still with docker). Then I had to re-install the zwavejs integration. Home assistant documentation for zwave has a procedure to migrate the integratio to a new server without losing any devices. That helped alot.
                                    @toggledbits, you should be seeing some data going you way. If not let me know. I will also complete my transition from vera to zwavejs in the following days. So more devices will eventually show up.
                                    • S sender
                                      @sender said in Who are my Home Assistant + ZWave-JS users?:
                                      If you're not a current Reactor user and familiar with it, this isn't the situation in which to learn. I'll remove you from the test list.
                                      S 1 Reply Last reply
                                        I will have my first update to post later today with some fixes and a lot of new device support (thanks to those of you running so far -- lots of data, good stuff!).
                                        • V Offline
                                          V Offline
                                          #31
                                          @toggledbits Since we are at the beginning of this, should we put a header like "ZWAVE-JS" at the begining of the title for every new post related to Zwave-JS just to flag the topic? Or do we keep on going into this thread for all issues, questions, etc...?
                                          How would you like us to proceed?
                                            165.6k
