zwavejs
51 Posts 10 Posters 22.8k Views 10 Watching
    RogerO
    I am running MSR in docker. I deleted MSR and installed the zwavejs version pointing to the MSR data directories. Didn't loose a thing.
    • V Offline
      V Offline
      #28
      Finally got there... MSR-zwavejs installation (docker) went very well, no issues there. It was a different story with HASS. I am running an unsupported version of Home Assistant Supervised on a raspberry pi (bulleyes). I had to get rid of the zwave2mqtt addon and install it by itself (still with docker). Then I had to re-install the zwavejs integration. Home assistant documentation for zwave has a procedure to migrate the integratio to a new server without losing any devices. That helped alot.
      @toggledbits, you should be seeing some data going you way. If not let me know. I will also complete my transition from vera to zwavejs in the following days. So more devices will eventually show up.
      • S sender
        Question: I know reactor by name. Do I need it? I have 80 zwavjes devices and a fully loaded homeassistant (+20 integrations)
        @sender said in Who are my Home Assistant + ZWave-JS users?:
        If you're not a current Reactor user and familiar with it, this isn't the situation in which to learn. I'll remove you from the test list.
        S 1 Reply Last reply
          I will have my first update to post later today with some fixes and a lot of new device support (thanks to those of you running so far -- lots of data, good stuff!).
          • V Offline
            V Offline
            #31
            @toggledbits Since we are at the beginning of this, should we put a header like "ZWAVE-JS" at the begining of the title for every new post related to Zwave-JS just to flag the topic? Or do we keep on going into this thread for all issues, questions, etc...?
            How would you like us to proceed?
              #32
              I think that's a great idea. Actually, you can use tags in posts... maybe that's even better?
                Build 22049 for zwavejs now posted. Some bug fixes, and a lot of device mapping.
                • E Offline
                  E Offline
                  eonnet
                  Hello, i'm running zwavejs2mqtt addon on Home Assistant and the addon don't allow to connect to the addon via IP address. Is there a solution for this or i'm out of luck?
                  I'm running my Reactor on a docker on Unraid, and home assistant os as a VM on the unraid, i can't install docker zwavejs2mqtt because for some unknown reason my zwave stick loses a connection with the docker after couple of days and cant find the solution for that.
                  cheers
                    sender
                    @toggledbits why not answer my question? Do I need msr? What's in it (extra) for me?
                    • S sender
                      @sender If you're happy with whatever you are using for automations, you may not need Reactor. If you're struggling with Node-Red or find HA's native automations too limiting or clunky, then Reactor may be an alternative you find agreeable.
                        Build 22050:
                        • Continued improvements in attribute mapping for devices (locks are entirely new in this release).
                        • Z-Wave device polling see docs
                          Build 22051:
                          • Fix node/entity-specific interval on polling
                          • More device updates and action enhancements
                            Build 22052:
                            • Fix startup synchronization issue causing problems for polling when connection reset/restarts.
                            • E Offline
                              E Offline
                              eonnet
                              Hello, i managed to connect the HA add on to reactor. The first thing i noticed is that mappings for fan on ZXT-600 and ZXT-120 IR extender for AC are incorrect, on reactor are as follows: 0-off, 1 - auto, 2 - continuous, 3 - periodic, 4 - low, 5 - medium, 6 - high, in zwavejs web console are 0 - Auto low, 1- Low, 3 - High, 5 - Medium
                              V toggledbitsT 2 Replies Last reply
                              • E eonnet
                                V Offline
                                V Offline
                                @eonnet said in Who are my Home Assistant + ZWave-JS users?:
                                As I mentionned earlier in this thread, I also had issues with the zwavejs2mqtt HA addon. The only option I found was to remove the addon and install it stand alone but still in Docker.
                                I am just curious to know your setup and how you manage to make it work still using the HA addon.
                                E 1 Reply Last reply
                                  #42
                                  Expect LOTS of device mappings to be off, or very generic. Not all devices follow the Z-Wave spec recommendations, particularly legacy Z-Wave devices, and even some first-generation Plus devices. I imagine this is why the Gen 2 specs are a good bit tighter. Regardless, every oddity and exception has to be handled as what it is, which is why I collect data from the interface. I literally sit and spend hours picking through your devices. On every new release, check those devices that previously didn't seem right. If, after a release or two, things still look or behave oddly, do let me know (specific data, please; if you say "X doesn't work" and nothing else, I will ignore it).
                                  • V vezinpi
                                    E Offline
                                    E Offline
                                    eonnet
                                    @vezinpi in addon settings add 3000 port to the host.
                                    And than you can access the zwavejs2mqtt addon via ws://ip:3000
                                    • V Offline
                                      V Offline
                                      @eonnet are you using the supervised version with HAAS os ?
                                      • V vezinpi
                                        E Offline
                                        E Offline
                                        eonnet
                                        @vezinpi yes hassos
                                        • V Offline
                                          V Offline
                                          Many thanks
                                            155.6k
