zwavejs
51 Posts 10 Posters 22.8k Views 10 Watching
  • E Offline
    E Offline
    eonnet
    Hello, i'm running zwavejs2mqtt addon on Home Assistant and the addon don't allow to connect to the addon via IP address. Is there a solution for this or i'm out of luck?
    I'm running my Reactor on a docker on Unraid, and home assistant os as a VM on the unraid, i can't install docker zwavejs2mqtt because for some unknown reason my zwave stick loses a connection with the docker after couple of days and cant find the solution for that.
    cheers
      @sender said in Who are my Home Assistant + ZWave-JS users?:
      Question: I know reactor by name. Do I need it? I have 80 zwavjes devices and a fully loaded homeassistant (+20 integrations)
      If you're not a current Reactor user and familiar with it, this isn't the situation in which to learn. I'll remove you from the test list.
      sender
      @toggledbits why not answer my question? Do I need msr? What's in it (extra) for me?
      • S sender
        @sender If you're happy with whatever you are using for automations, you may not need Reactor. If you're struggling with Node-Red or find HA's native automations too limiting or clunky, then Reactor may be an alternative you find agreeable.
          Build 22050:
          • Continued improvements in attribute mapping for devices (locks are entirely new in this release).
          • Z-Wave device polling see docs
            Build 22051:
            • Fix node/entity-specific interval on polling
            • More device updates and action enhancements
              Build 22052:
              • Fix startup synchronization issue causing problems for polling when connection reset/restarts.
              • E Offline
                E Offline
                eonnet
                Hello, i managed to connect the HA add on to reactor. The first thing i noticed is that mappings for fan on ZXT-600 and ZXT-120 IR extender for AC are incorrect, on reactor are as follows: 0-off, 1 - auto, 2 - continuous, 3 - periodic, 4 - low, 5 - medium, 6 - high, in zwavejs web console are 0 - Auto low, 1- Low, 3 - High, 5 - Medium
                V toggledbitsT 2 Replies Last reply
                • E eonnet
                  V Offline
                  V Offline
                  @eonnet said in Who are my Home Assistant + ZWave-JS users?:
                  As I mentionned earlier in this thread, I also had issues with the zwavejs2mqtt HA addon. The only option I found was to remove the addon and install it stand alone but still in Docker.
                  I am just curious to know your setup and how you manage to make it work still using the HA addon.
                  E 1 Reply Last reply
                    #42
                    Expect LOTS of device mappings to be off, or very generic. Not all devices follow the Z-Wave spec recommendations, particularly legacy Z-Wave devices, and even some first-generation Plus devices. I imagine this is why the Gen 2 specs are a good bit tighter. Regardless, every oddity and exception has to be handled as what it is, which is why I collect data from the interface. I literally sit and spend hours picking through your devices. On every new release, check those devices that previously didn't seem right. If, after a release or two, things still look or behave oddly, do let me know (specific data, please; if you say "X doesn't work" and nothing else, I will ignore it).
                    • V vezinpi
                      E Offline
                      E Offline
                      eonnet
                      @vezinpi in addon settings add 3000 port to the host.
                      And than you can access the zwavejs2mqtt addon via ws://ip:3000
                      • V Offline
                        V Offline
                        @eonnet are you using the supervised version with HAAS os ?
                        • V vezinpi
                          E Offline
                          E Offline
                          eonnet
                          @vezinpi yes hassos
                          • V Offline
                            V Offline
                            Many thanks
                            • E eonnet
                              #47
                              Reactor has its own set of values for its capabilities. These are mapped (or not) into the ZWave standard values supported by the command class, and/or what the device actually supports. Reactor's list is not limited by what the device does, although choosing values the device doesn't support usually won't do anything (or cause a default to be chosen, device-dependent); this has always been true for all devices on all controllers in Reactor.
                              EDIT: I see where you are getting the numbers, and that's actually a bug (an ancient one, at that) in the Reaction editor, nothing to do with ZWaveController specifically. That is now fixed both for general release 22053 and zwavejs build 22053.
                                #48
                                Build 22053:
                                • Fixes in sync with general release build 22053 -- see BREAKING CHANGE notice there
                                • More small device tweaks
                                • The default for capturing the zwave-js logs is now false in config (i.e. it won't capture zwavejs log entries by default now).
                                  Build 22054:
                                  • Continued device improvements (lots of work on Aeotec devices among others)
                                    Build 22058:
                                    • And more device improvements.
                                    • New "Rename" and "Delete" buttons for entities (in Entities list).
                                    Please note that the Rename button may not modify the on-device name if the device does not support the Node Naming and Location command class. This is probably not terribly importent, as the zwave-js and Reactor device/entity databases keep track of user-set names as well. The Delete button does not exclude a Z-Wave device, it merely removes the device from Reactor's device list. If the device is still in the hub (i.e. its still a valid Z-Wave device), the entity will reappear on the next inventory of the Z-Wave controller. The purpose of this feature is primarily to help in the removal of dead devices (i.e. those excluded from the controller by the user).
                                      Build 22067
                                      • A few more device tweaks;
                                      • Performance improvements;
                                      • Update mechanism for data files, so that I can post device updates without having to publish a build.
                                      This version is fully in sync with fixes and improvements in latest release 22067.
                                        155.6k
