zwavejs
51 Posts 10 Posters 22.8k Views 10 Watching
  • E Offline
    E Offline
    eonnet
    Hello, i managed to connect the HA add on to reactor. The first thing i noticed is that mappings for fan on ZXT-600 and ZXT-120 IR extender for AC are incorrect, on reactor are as follows: 0-off, 1 - auto, 2 - continuous, 3 - periodic, 4 - low, 5 - medium, 6 - high, in zwavejs web console are 0 - Auto low, 1- Low, 3 - High, 5 - Medium
    V toggledbitsT 2 Replies Last reply
    • E eonnet
      V Offline
      V Offline
      @eonnet said in Who are my Home Assistant + ZWave-JS users?:
      As I mentionned earlier in this thread, I also had issues with the zwavejs2mqtt HA addon. The only option I found was to remove the addon and install it stand alone but still in Docker.
      I am just curious to know your setup and how you manage to make it work still using the HA addon.
      E 1 Reply Last reply
      • toggledbitsT Online
        toggledbitsT Online
        #42
        Expect LOTS of device mappings to be off, or very generic. Not all devices follow the Z-Wave spec recommendations, particularly legacy Z-Wave devices, and even some first-generation Plus devices. I imagine this is why the Gen 2 specs are a good bit tighter. Regardless, every oddity and exception has to be handled as what it is, which is why I collect data from the interface. I literally sit and spend hours picking through your devices. On every new release, check those devices that previously didn't seem right. If, after a release or two, things still look or behave oddly, do let me know (specific data, please; if you say "X doesn't work" and nothing else, I will ignore it).
        • V vezinpi
          E Offline
          E Offline
          eonnet
          @vezinpi in addon settings add 3000 port to the host.
          And than you can access the zwavejs2mqtt addon via ws://ip:3000
          • V Offline
            V Offline
            @eonnet are you using the supervised version with HAAS os ?
            • V vezinpi
              E Offline
              E Offline
              eonnet
              @vezinpi yes hassos
              • V Offline
                V Offline
                Many thanks
                • E eonnet
                  toggledbitsT Online
                  toggledbitsT Online
                  #47
                  Reactor has its own set of values for its capabilities. These are mapped (or not) into the ZWave standard values supported by the command class, and/or what the device actually supports. Reactor's list is not limited by what the device does, although choosing values the device doesn't support usually won't do anything (or cause a default to be chosen, device-dependent); this has always been true for all devices on all controllers in Reactor.
                  EDIT: I see where you are getting the numbers, and that's actually a bug (an ancient one, at that) in the Reaction editor, nothing to do with ZWaveController specifically. That is now fixed both for general release 22053 and zwavejs build 22053.
                    toggledbitsT Online
                    #48
                    Build 22053:
                    • Fixes in sync with general release build 22053 -- see BREAKING CHANGE notice there
                    • More small device tweaks
                    • The default for capturing the zwave-js logs is now false in config (i.e. it won't capture zwavejs log entries by default now).
                      toggledbitsT Online
                      Build 22054:
                      • Continued device improvements (lots of work on Aeotec devices among others)
                        toggledbitsT Online
                        Build 22058:
                        • And more device improvements.
                        • New "Rename" and "Delete" buttons for entities (in Entities list).
                        Please note that the Rename button may not modify the on-device name if the device does not support the Node Naming and Location command class. This is probably not terribly importent, as the zwave-js and Reactor device/entity databases keep track of user-set names as well. The Delete button does not exclude a Z-Wave device, it merely removes the device from Reactor's device list. If the device is still in the hub (i.e. its still a valid Z-Wave device), the entity will reappear on the next inventory of the Z-Wave controller. The purpose of this feature is primarily to help in the removal of dead devices (i.e. those excluded from the controller by the user).
                          toggledbitsT Online
                          Build 22067
                          • A few more device tweaks;
                          • Performance improvements;
                          • Update mechanism for data files, so that I can post device updates without having to publish a build.
                          This version is fully in sync with fixes and improvements in latest release 22067.
                            155.7k
