  4. [Solved] Arm for Eastern Standard Time/Daylight Saving Time
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
7 Posts 3 Posters 927 Views 3 Watching
    Where are our latching experts?
    Daylight Saving Time here in the States has begun. I'd like to create a couple "Arm for" rules for potential referencing for iblinds rules.
    • DST starts the second Sunday in March at 02:00 ET.
    • EST starts the first Sunday in November at 02:00 ET.
    Here's what I have so far:
    4cf3307d-d5ff-4407-a932-8885628c487d-image.png And the latching:
    I've done the trick with changing the test date discussed in another thread here that allows for time travel back to when the latch should start. It took a few attempts and I finally had it do the 03:00 ET hour because, technically, the 02:00 ET doesn't exist during the transition to DST.
    Current status:
    Anyone with experience with this feel free to heckle my work with the goal being to beat this thing into submission 🙂
    *Hubitat C-7 2.4.3.177
    Core 2026.1.1
    MSR: latest-26011-c621bbc7
      Alan_F
      I tried to follow your example but I'm confused. Shouldn't the "and the rest" rule start on April 1st instead of March 1st? I'm definitely not a latching expert, so maybe I'm the wrong person to try to understand what you've done.
      Not being competent with latching, the approach I would probably take would be to create an expression 'is_dst' and have a rule that sets it to true on the second Sunday of March at 0300 and sets it to false on the first Sunday in November at 01:59:59. Initially set it to the correct value and then just refer to the expression whenever a rule needs to know if DST is in effect. Seems simpler to me and I think it would work just as well.
      My state legislature is considering a bill to stay on DST permanently. It would require federal approval, so it's probably not going to happen anytime soon, but there's another way to solve the problem. 😁
      • A Alan_F
        @alan_f Are you doing this as two sep rules or building the start/end Sunday dates into a single rule?
        And if you vote for ME as POTUS in 2024 I'll make every effort to get DST to be Daylight Standard Time and not Daylight Saving Time! 😉
        Core 2026.1.1
          Alan_F
          @gwp1 I'm not actually doing this, that was just my thoughts on how it could be done (= untested speculation 😁). I think it would have to be two rules. That way each rule is firing at one specific date and time and you wouldn't be trying to create a rule that is active at all dates and times between DST start and DST end, which I think leads you down the OP's path using latching. If you have one rule with a reset action there's no need for the expression, you could just use the rule state to tell if it's DST.
          • A Alan_F
            @alan_f I gave it some thought last night and came to the same conclusion: two rules, each essentially recording the variable at the designated trigger time/s.
            Using the Test Date functionality in reactor.yaml I was able to trigger the DST start successfully.
            That's the joy of MSR: more than one way to the end game.
            Core 2026.1.1
              Current status:
              @gwp1 I thought I'd chime in on this. The latest release includes a dst flag in the Sun Information entity as a simplification, but here's my version using conditions, because I think it's useful to have more examples with latching to ponder:
              The first subgroup, named "Start", detects the start of DST (here in the US, second Sunday in March). at (or after) 2am. This group is the latching element, so the group itself has the latched option enabled. Once it goes true, it remains latched true until its peer group, named "End", goes false.
              The second subgroup, "End", detects the end of DST (the first Sunday in November for US). It is a NOT AND group, meaning it is true except after 2am on the change date. At that time, it goes false, and this allows the latched "Start" group to reset.
              The key thing to remember is that a latched condition (either a single condition or a group) must be paired in an AND group with at least one other non-latched condition that can reset it. Since the "Start" and "End" groups are contained in the rule's enclosing AND group, that serves the function.
              S. 623 was passed by the US Senate on March 15 and is on its way to the House. If it passes, then at least here in the US, we may soon not need to worry about any of this.
                @toggledbits I saw your release notes and immediately dropped 22080 in place and went straight to the variable rules I'd built from @Alan_F's comment and disabled them in favor of the system's SunInfo dst flag. I didn't delete the others - I really want to fully grasp latching.
                I'm not holding my breath on the possible law - it was written back in 2021 and the House keeps putting it in committee.
                Fingers crossed!
                Core 2026.1.1
                • Next Release?
