  4. Changes to iblinds showing in HASS but not in zwavejs
HA 2025.9.4 Supported Yet?
Rule Set UI bug - RESOLVED
[Reactor] Copy&Paste of Rules
Expose MSR entities
Comment in Globa Expressions
Tom_DT
Gradually turn on lights.
Tom_DT
Can't customize home page
Error After Upgrade
14 Posts 2 Posters 904 Views 2 Watching
    RogerO
    Hello Patrick,
    Currently running zwavejs-220080. and 2022.3.7 of HA.
    Was moving my MSR script to use zwave JS directly on my iblinds instead of HA. Once I switched the reaction, they stopped working. Doing some digging I see that while monitoring values in entities, the blinds under HASS update while the blinds under zwavejs do not see the changes. Let me know what info you need. Are you seeing anything in the logs you download?
    Thanks,
    Roger
    • R RogerO
      Hello Patrick,
      Thanks,
      Roger
      @rogero said in Changes to iblinds showing in HASS but not in zwavejs:
      Can you be more specific here? What attributes are you looking at that you expect to change but do not? Do any attributes change?
        RogerO
        None of them change. And action only work when performed from HA.
          OK. The last snapshot I have from your ZWaveJSController is dated yesterday, and zwavejs had not initialized the blinds device at that time, so I have no data for it. I need you to restart Reactor only -- do not restart zwavejs. It should send me that data. Let me know when you've done the restart.
            RogerO
            It has been restarted.
              I'm on it...
                If you delete the entity (delete button in the Entites page detail for it) and then restart Reactor, refresh browser, does the entity come back, or does it vanish?
                  RogerO
                  Not home for a bit. Will get back to you.
                    It's OK. It's just a verification of what I think I'm seeing here. I'm pretty sure I have it. Will spin a new release momentarily...
                    Release 22083 (zwavejs branch) is up. Give it a try when you can.
                      RogerO
                      Looks like it is working now. Thanks
                        RogerO
                        Hi Patrick,
                        So, done some testing and while the changes are mirrored in entities correctly changing the position value in zwavejs does not respect the value input. If I put in .88 it closes facing down to the stop and if I but in .44 it closes facing up to the stop. Setting the same parameter with HASS behaves as it should.
                          Try downloading this ZIP file and dropping it in your config directory (do not UNZIP it, just put the ZIP file in there directly). Restart Reactor and try again.
                          https://reactor.toggledbits.com/download/zwavejs/zwavejs_data.zip
                            RogerO
                            I think it is working better now. Golfing this morning so not able to spend much time testing. Will look at it over the weekend.
                              Awesome! Enjoy your round.
                                7.9k
                              • Shelly Wall Display XL
                                9.1k
                              • HA 2025.9.4 Supported Yet?
                              • Rule Set UI bug - RESOLVED
