  4. Variable Missing but working
2 Posts 1 Posters 556 Views 1 Watching
    latest-22080 Synology Docker
    Looking at a rule I created early on I noticed a problem with some variables. This rule references a variable set in another rule. The rule still works and the variable changes but it shows it missing. No errors in the logs that I can see. I know there has been changes with expressions along the way which might be why. I would expect an error or the variables not to work. I assume I need to use a global expression to be used as a variable in multiple rules.
    Suggestions on the proper way to set and retrieve a value to use in multiple rules?
    Screen Shot 2022-03-30 at 6.44.37 PM.png Screen Shot 2022-03-30 at 7.20.40 PM.png Screen Shot 2022-03-30 at 7.09.20 PM.png
      I found a thread where it was stated this was a MSR bug that allowed you to select variable from other rules. I assume these rules were created before build 21267. I have read the docs and understand that this method is not possible. I will change to use global expressions. Strange the rules still work as is.
        151.6k
