  4. Restart router when it's gone offline?
As there are statements about compatibility for home assistant versions in MSR new version announcements (e.g. "HassController: Bless Hass to 2025.7.3"), I thought it would be good idea to track other controllers as well. As an example, I can confirm that build "latest-25208-c53e8513" works with Hubitat Elevation C-8 platform version 2.4.2.134 using Maker API.
Gradually turn on lights.
Tom_DT
Can't customize home page
Error After Upgrade
Links to MSR from HA
Tom_DT
Set Reaction > Script Action
I'm running MSR build 25139 on Docker, using MQTT controller 24293, and everything working as expected. But if I try to upgrade to MQTTController build 25139, I'm getting the following errors on MSR UI: An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.god Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.green Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.red Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto run" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.pump Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa watchdog" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.status Last 11:20:37 My MQTT configuration (local_mqtt_devices.yaml) for the related entity is: layzspa_message: type: ValueSensor capabilities: ["temperature_sensor", "value_sensor", "power_sensor"] primary_attribute: power_sensor.value events: "layzspa/message": "power_sensor.value": json_payload: true if_expr: '! isnull( payload?.PWR )' expr: "float(payload.PWR)" "value_sensor.air": json_payload: true if_expr: '! isnull( payload?.AIR )' expr: "float(payload.AIR)" "value_sensor.pump": json_payload: true if_expr: '! isnull( payload?.FLT )' expr: "float(payload.FLT)" "value_sensor.god": json_payload: true if_expr: '! isnull( payload?.GOD )' expr: "float(payload.GOD)" "value_sensor.lock": json_payload: true if_expr: '! isnull( payload?.LCK )' expr: "float(payload.LCK)" "value_sensor.unit": json_payload: true if_expr: '! isnull( payload?.UNT )' expr: "float(payload.UNT)" "value_sensor.error": json_payload: true if_expr: '! isnull( payload?.ERR )' expr: "float(payload.ERR)" "temperature_sensor.green": json_payload: true if_expr: '! isnull( payload?.GRN )' expr: "float(payload.GRN)" "temperature_sensor.red": json_payload: true if_expr: '! isnull( payload?.RED )' expr: "float(payload.RED)" "temperature_sensor.target": json_payload: true if_expr: '! isnull( payload?.TGT )' expr: "float(payload.TGT)" "temperature_sensor.value": json_payload: true if_expr: '! isnull( payload?.TMP )' expr: "float(payload.TMP)" "temperature_sensor.virtual": json_payload: true if_expr: '! isnull( payload?.VTM )' expr: "round(float(payload.VTM), 1)" "temperature_sensor.ambient": json_payload: true if_expr: '! isnull( payload?.AMB )' expr: "float(payload.AMB)" "layzspa/Status": "value_sensor.status": if_expr: '! isnull( payload )' expr: "payload" "layzspa/button": "value_sensor.button": if_expr: '! isnull( payload )' expr: "payload" and in reactor.yaml I have: "layzspa_states": name: "Lay-Z-Spa States" friendly_name: 'Lay-Z-Spa States' include: layzspa_message I realize my MQTT configuration might be a bit unorthodox, but could there still be something unintentional in the latest MQTTController build? If needed, I can provide detailed logs.
Tom_DT
12 Posts 4 Posters 1.0k Views 4 Watching
  • F Offline
    wrote on last edited by Fanan
    Hi!
    Once a month or so, my internet access is lost, and I have to cut the power to the router, to restart it. When I'm away this become a problem, so I thought that if I got a zigbee switch (in Home Assistant), problem is solved. But how do I (MSR) know if it's offline?
    1. What's the easiest and most effective way to make this work? Do I ping a few websites every ten minutes or so, or is there a better approch?
    2. If I'm going to ping, what URL is recommended?
    For information, I have a set up with Asus routers, Home Assistent with zigbee-, z-wave and wifi devices (a total of appr. 150) and every of my 60-70 automation is done by MSR.
    I run MSR ver. 22080-ae7212f (docker on my Home Assistant blue). HA ver 2022.4.6.
    Thanks in advance.
    Take care, you all!
    /Fanan
    • toggledbitsT Away
      toggledbitsT Away
      Yes, much better, thanks. There is a script to drive a boolean attribute on the Reactor system entity to track the up-down state of Internet access (bare metal users can find that in the tools subdirectory), but I can't guide you on how to get that running under Home Assistant Blue.
      Here's a thread that may help you get the equivalent running in Hass, which you would then be able to see as a binary sensor in Reactor: https://community.home-assistant.io/t/home-assistant-checking-if-internet-connection-is-online/313324
      • toggledbitsT Away
        toggledbitsT Away
        Attention to the posting guidelines, please: need to know your host platform information, Reactor version number, etc.
        F 1 Reply Last reply
          @toggledbits my bad. I've added some info in my first post. Hopefully it's enough.
          /Fanan
          • toggledbitsT Away
            toggledbitsT Away
              @toggledbits How does one make use of that script within MSR?
              *Hubitat C-7 2.4.2.129
              *HASS 2025.7.2
              w/ ZST10-700 fw 7.18.3
              MSR: latest-25139-fbd67abc
              • toggledbitsT Away
                toggledbitsT Away
                The script header contains the simple instructions to get it up and running. From there, you just test the value of the Reactor System entity's attribute reactor_system.internet_ok
                G 2 Replies Last reply
                  @toggledbits When I review the readme in the config directory it says:
                  These are the distribution (original) versions of the Reactor configuration
                  files. You may keep them as a reference, or delete them (and this sub-
                  directory). The configuration files used in runtime are in the 'config'
                  subdirectory.
                  When I review the readme in the dist-config directory it says the same thing. Which one is the actual config directory (I'm betting config).
                  *HASS 2025.7.2
                    @toggledbits So digging thru the script/s a bit I went with config directory as the location.
                    Attempting to run the script ./reactor_inet_check.sh results in this:
                    Just for clarify, this is my config directory:
                    and I'm running MSR on RPi4 bare metal Model B 2GBs latest-22080-ae7212f.
                    *HASS 2025.7.2
                    • F Fanan has marked this topic as solved on
                    • toggledbitsT Away
                      toggledbitsT Away
                      You have to run the script from the Reactor home directory.
                      cd /path/to/reactor
                      tools/reactor_inet_check.sh
                      wmarcolinW 1 Reply Last reply
                        Got this working brilliantly - thanks to @Fanan for the idea!
                        *HASS 2025.7.2
                          cd /path/to/reactor
                          @toggledbits hi!
                          To execute this command in windows? how would the script be triggered?
                          • toggledbitsT Away
                            toggledbitsT Away
                            The included script only runs on Linux systems. A version of the script for Windows would make a great community contribution.
                            • F Fanan referenced this topic on
                              292
                            • Little Bobby tables...
                              644
                            • Gradually turn on lights.
                              912
                              55.7k
                            • Can't customize home page
                              233
                            • Error After Upgrade
                              RHCPNG
