  4. Restart router when it's gone offline?
12 Posts 4 Posters 2.8k Views 4 Watching
  • F Offline
    wrote on last edited by Fanan
    Hi!
    Once a month or so, my internet access is lost, and I have to cut the power to the router, to restart it. When I'm away this become a problem, so I thought that if I got a zigbee switch (in Home Assistant), problem is solved. But how do I (MSR) know if it's offline?
    1. What's the easiest and most effective way to make this work? Do I ping a few websites every ten minutes or so, or is there a better approch?
    2. If I'm going to ping, what URL is recommended?
    For information, I have a set up with Asus routers, Home Assistent with zigbee-, z-wave and wifi devices (a total of appr. 150) and every of my 60-70 automation is done by MSR.
    I run MSR ver. 22080-ae7212f (docker on my Home Assistant blue). HA ver 2022.4.6.
    Thanks in advance.
    Take care, you all!
    /Fanan
      Yes, much better, thanks. There is a script to drive a boolean attribute on the Reactor system entity to track the up-down state of Internet access (bare metal users can find that in the tools subdirectory), but I can't guide you on how to get that running under Home Assistant Blue.
      Here's a thread that may help you get the equivalent running in Hass, which you would then be able to see as a binary sensor in Reactor: https://community.home-assistant.io/t/home-assistant-checking-if-internet-connection-is-online/313324
        Attention to the posting guidelines, please: need to know your host platform information, Reactor version number, etc.
        F 1 Reply Last reply
          @toggledbits my bad. I've added some info in my first post. Hopefully it's enough.
          /Fanan
              @toggledbits How does one make use of that script within MSR?
              *Hubitat C-7 2.5.1.142
              Core 2026.7.4
              MSR: latest-26193-8dd8f854
                The script header contains the simple instructions to get it up and running. From there, you just test the value of the Reactor System entity's attribute reactor_system.internet_ok
                G 2 Replies Last reply
                  @toggledbits When I review the readme in the config directory it says:
                  These are the distribution (original) versions of the Reactor configuration
                  files. You may keep them as a reference, or delete them (and this sub-
                  directory). The configuration files used in runtime are in the 'config'
                  subdirectory.
                  When I review the readme in the dist-config directory it says the same thing. Which one is the actual config directory (I'm betting config).
                  Core 2026.7.4
                    @toggledbits So digging thru the script/s a bit I went with config directory as the location.
                    Attempting to run the script ./reactor_inet_check.sh results in this:
                    Just for clarify, this is my config directory:
                    and I'm running MSR on RPi4 bare metal Model B 2GBs latest-22080-ae7212f.
                    Core 2026.7.4
                    • F Fanan has marked this topic as solved on
                      You have to run the script from the Reactor home directory.
                      cd /path/to/reactor
                      tools/reactor_inet_check.sh
                      wmarcolinW 1 Reply Last reply
                        Got this working brilliantly - thanks to @Fanan for the idea!
                        Core 2026.7.4
                          cd /path/to/reactor
                          @toggledbits hi!
                          To execute this command in windows? how would the script be triggered?
                            The included script only runs on Linux systems. A version of the script for Windows would make a great community contribution.
                            • F Fanan referenced this topic on
                              139.9k
