  4. The Home Remote with MSR
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
6 Posts 5 Posters 1.9k Views 5 Watching
  • MikeReadingtonM Offline
    MikeReadington
    Did anyone do/start any work on a full integration with The Home Remote application yet?
      Not sure what would integrate between MSR and THR unless I'm missing something.
        @MikeReadington, MSR is merely an automation machine that uses entities from other systems, so i guess its more natural to integrate the mentioned systems with THR, and not MSR?
        What would you want to do from THR?
        • PerHP PerH
          @perh said in The Home Remote with MSR:
          While this is generally true, it also presents unified API and expression of entities across all of those platforms, and that in itself can be significantly useful in integration.
            Home Remote does not support Ezlo hubs. and I am not sure if support for them will ever be added. I guess if somehow Home Remote integrated with MSR it might be possible to then import Ezlo devices into the Home Remote Designer / Dashboard app ?
              MikeReadington
              @cw-kid I was thinking along these lines myself when I asked that question. Any device brought into MSR could then be brought into Home Remote regardless of Home Remote's native support.
              Unless I am not understanding something correctly, MSR could be brought in essentially as a hub. If MSR could talk to it, Home Remote could talk to it. More importantly, for something I would like to do, I would like a specific triggered Home Remote function to interact with MSR. (I think you had done this already if I remember correctly)
              I think this would open lots of additional automation avenues.
                162.9k
