  4. Auto evaluation of time based global expressions
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
6 Posts 2 Posters 1.2k Views 2 Watching
    Am I missing something (which is what I'd expect) but is there no way to autoupdate time based expressions such as
    strftime("%H", time()) ?
    I guess there's an issue about how often you'd want to update and I can work out another way to do what I want to achieve (which is effectively make available a variable that I can pass to 'stuff' as morning / afternoon or evening.
    So just thought I'd check there's no 'interval' kind of thing I can attach?
    Cheers
    • toggledbitsT Online
      toggledbitsT Online
      That's exactly what the Interval condition in a rule is meant for.
        headdesk
        FFS I can be so stupid! So adding the interval on rule that uses the expression will force the global expression to be evaluated.
          toggledbitsT Online
          Almost... time expressions are still an exception. There's tension between various behaviors and optimizations, and compromises must be made. In your case, you'll want an expression-less global variable to store the time, and use the Set reaction in the rule (that uses an Interval condition) to set the global variable's value (Set Variable to %{{ time() }}.
            @toggledbits Thanks. I was about to post back that I was still wrong. I shall examine this avenue 🙂
              As ever, works like a charm. Thanks!
                164.2k
