  4. Auto evaluation of time based global expressions
6 Posts 2 Posters 1.1k Views 2 Watching
    Am I missing something (which is what I'd expect) but is there no way to autoupdate time based expressions such as
    strftime("%H", time()) ?
    I guess there's an issue about how often you'd want to update and I can work out another way to do what I want to achieve (which is effectively make available a variable that I can pass to 'stuff' as morning / afternoon or evening.
    So just thought I'd check there's no 'interval' kind of thing I can attach?
    Cheers
      That's exactly what the Interval condition in a rule is meant for.
        headdesk
        FFS I can be so stupid! So adding the interval on rule that uses the expression will force the global expression to be evaluated.
          Almost... time expressions are still an exception. There's tension between various behaviors and optimizations, and compromises must be made. In your case, you'll want an expression-less global variable to store the time, and use the Set reaction in the rule (that uses an Interval condition) to set the global variable's value (Set Variable to %{{ time() }}.
            @toggledbits Thanks. I was about to post back that I was still wrong. I shall examine this avenue 🙂
              As ever, works like a charm. Thanks!
                151.7k
