  4. Issue with yellow triangles next to rules
4 Posts 3 Posters 991 Views 3 Watching
    sethlampman
    So I upgraded to the latest docker version of Reactor. Now I notice that some of my rules have a yellow triangle before them. I hovered over it but I don't see any explanation as to why. I searched the docs and the forum but I can't figure out why it is showing. If I go into the rule I don't see any errors. Any ideas?
    wmarcolinW PablaP 2 Replies Last reply
    • S sethlampman
      @sethlampman
      When it happens in my case, it has been in two situations:
      a. some rule device has disappeared;
      b. most recently, I changed a device using the HE feature for switching, and the new device does not have the same attributes. For example, I had a water sensor that behaved like a contact, and the new device's attribute is liquid detector, so the warning went out.
      • S sethlampman
        @sethlampman try expanding the rule and making sure all devices are still available. I ran into this issue too the other day bc I had a mistype in one of the config files and made my whole HA service unavailable
          sethlampman
          Here is the crazy thing. The sensor values were stale, I changed a value in the rule and then saved it. Now there isn't an exclamation point and the sensor value is updating as well. Almost like it was stuck after the upgrade?
            147.4k
