  4. Create Expression to call out Entity ID of Tripped Binary Sensor
18 Posts 3 Posters 3.5k Views 3 Watching
    wrote on last edited by Pabla
    Final question, can I use an expression variable in the a HA service call? I have tried this in the past but can't get it to work. The TTS is saying 'tripped_zone_names' and not the actual names of the tripped zones.
    Here is the data in the service call if the screenshot isn't clear enough
        "entity_id": "media_player.living_room",
        "message": "ALERT the ${{ tripped_zone_names }} have been opened",
        "cache": true
    • toggledbitsT Online
      toggledbitsT Online
      You can't do it in x_hass_system.call_service (specifically and uniquely) because the data is an object field in that action, and the substitution doesn't work in object types, only in strings. You need to use the actions available in x_hass_tts. If your media_player.living_room does not natively have x_hass_tts actions listed, you'll need to add them by copy-pasting this to a file called local_hass_devices.yaml in your config directory (and restart Reactor):
      entities:
        # This media player supports TTS
        "hass>media_player_living_room":
          services:
            - tts
      Unfortunately the Hass API doesn't expose enough info for Reactor to know that device supports the service, so it has to be done manually.
      PablaP toggledbitsT 2 Replies Last reply
        entities:
            services:
              - tts
        @toggledbits said in Create Expression to call out Entity ID of Tripped Binary Sensor:
        Crap this throws a wrench in a lot of my automation plans. I tried to add the TTS functionality way back and never got it working will try again.
          Having some issues with the expression that determines what zones are true. It was working when I originally created the expression but I made a few tweaks to expression names and now it doesn't work. Here is a snippet of the logs. Also a screenshot of the expression 6b193d6f-8e18-447e-a032-ef5e5e4b9e18-image.png
          [latest-22248]2022-09-06T23:41:57.638Z <Rule:INFO> Zone Open ALERT (Rule#rule-grpot1ehov) evaluation complete
          [latest-22248]2022-09-06T23:41:57.639Z <Rule:INFO> Babay/Papa Windows (Rule#rule-l7jasakd) starting evaluation; because entity-changed Entity#hass>binary_sensor_babay_papa_windows
          [latest-22248]2022-09-06T23:41:57.639Z <Rule:INFO> Zone Open ALERT (Rule#rule-grpot1ehov) starting evaluation; because entity-changed Entity#hass>binary_sensor_babay_papa_windows
          [latest-22248]2022-09-06T23:41:57.640Z <Rule:INFO> Babay/Papa Windows (Rule#rule-l7jasakd) evaluated; trigger state unchanged (false); rule state remains RESET
          [latest-22248]2022-09-06T23:41:57.640Z <Rule:INFO> Zone Open ALERT (Rule#rule-grpot1ehov) evaluated; trigger state unchanged (false); rule state remains RESET
          [latest-22248]2022-09-06T23:41:57.640Z <Rule:INFO> Babay/Papa Windows (Rule#rule-l7jasakd) evaluation complete
          [latest-22248]2022-09-06T23:41:57.641Z <Rule:INFO> Zone Open ALERT (Rule#rule-grpot1ehov) evaluation complete
          [latest-22248]2022-09-06T23:41:57.641Z <Engine:ERR> [Engine]Engine#1: error evaluating expression tripped_zones: [ReferenceError]ReferenceError: Invalid scope in reference to member binary_sensor of (object)null
          [latest-22248]2022-09-06T23:41:57.642Z <Engine:ERR> [Engine]Engine#1: expression: each id in zones_list: getEntity(id).attribute.binary_sensor.state == "true" ? id : null
          [latest-22248]2022-09-06T23:41:57.642Z <Engine:CRIT> ReferenceError: Invalid scope in reference to member binary_sensor of (object)null
              at _run (/home/armans2/reactor/common/lexp.js:1490:31)
              at _run (/home/armans2/reactor/common/lexp.js:1484:33)
              at _run (/home/armans2/reactor/common/lexp.js:1334:34)
              at _run (/home/armans2/reactor/common/lexp.js:1502:32)
              at _run (/home/armans2/reactor/common/lexp.js:1594:41)
              at /home/armans2/reactor/common/lexp.js:1324:29
              at _run (/home/armans2/reactor/common/lexp.js:1323:28)
              at run (/home/armans2/reactor/common/lexp.js:1704:22)
              at Object.evaluate (/home/armans2/reactor/common/lexp.js:1740:20)
            Interestingly enough I am using almost the exact same expression elsewhere just fine Screenshot 2022-09-06 170412.png
            wmarcolinW 1 Reply Last reply
              toggledbitsT Online
              You're right... it is almost the exact same expression... almost. (I'm teaching here... look closely at the one the works, and the one that doesn't).
              PablaP 2 Replies Last reply
                Hi @Pabla
                I'm sorry if I'm saying something wrong and out of the context of this discussion, but I'll put what I have that seems to be what you are looking for, using DynamicGroupController, which was an excellent feature that @toggledbits implemented.
                config > reactor.yaml
                  - id: groups
                    enable: true
                      groups:
                        "dgc_low_battery":
                          name: DGC Low Battery
                            - include_capability:
                              - battery_power
                          filter_expression: >
                            entity.attributes.battery_power.level < 0.3
                        "dgc_tripped":
                              - door_sensor
                              - motion_sensor
                              - co_detector
                              - smoke_detector
                              - leak_detector
                            entity.attributes?.door_sensor?.state == true or
                            entity.attributes?.motion_sensor?.state == true or
                            entity.attributes?.co_detector?.state == true or
                            entity.attributes?.smoke_detector?.state == true or
                            entity.attributes?.leak_detector?.state == true
                        "dgc_internal_motion":
                          name: DGC Internal Motion
                            - include_entity:
                              - "hubitat>40"
                              - "hubitat>41"
                              - "hubitat>43"
                              - "hubitat>73"
                When I then have the information loaded, it is easy to handle in many situations.
                In the example below, I put in the array HouseSECURITY which devices I want to monitor, according to the way the house is, and then I crosscheck with what comes from DynamicGroup, and display messages, take actions, etc..
                At the moment, the house is in Day mode, so there is nothing, at night I load in this variable the list of doors and windows; when it is travel, I add movement.
                I don't know if I helped or hindered.
                PablaP 1 Reply Last reply
                  toggledbitsT Online
                  It would be my preference that Pabla find his error, since the way he's doing it will work... worked before, and he said that, he just changed something that made it not work, and some troubleshooting is necessary. In this case, a "code review" is sufficient (a review of the failing expression, perhaps in conjunction with a careful comparison to the working similar expression).
                    Had a feeling it was a typo mistake, gonna take a look with some fresh eyes later today.
                    • wmarcolinW wmarcolin
                      Hi @Pabla
                        - id: groups
                          enable: true
                            groups:
                              "dgc_low_battery":
                                    - battery_power
                              "dgc_tripped":
                                    - door_sensor
                                    - motion_sensor
                                    - co_detector
                                    - smoke_detector
                                    - leak_detector
                                  - include_entity:
                                    - "hubitat>40"
                                    - "hubitat>41"
                                    - "hubitat>43"
                                    - "hubitat>73"
                      @wmarcolin that’s my next plan! I want to get comfortable with some basic expressions first then dive into the dynamicgroupcontroller
                        @pabla said in Create Expression to call out Entity ID of Tripped Binary Sensor:
                        I highly recommend taking the time to use DynamicGroupController, before I had huge global variables, complexity to monitor and create array, when this feature was implemented it made these group management actions by characteristics much easier. Good luck!
                          okay so I checked and noticed that I wrote attribute singular and in the working one made it attributes plural. Still no success.. I even got someone else to check the syntax and they weren't able to find a difference between the working and non-working expression.
                          I fear I am overlooking something super basic which I thought I fixed but I have yet to find the error
                          Edit: I had a typo in my array of entities all is well
                            toggledbitsT Online
                            Did the behavior change? If so, what does the new behavior look like? If not, what is in the logs?
                              @toggledbits it works as expected now, I had a typo in one of my entities in the array.
                                entities:
                                    services:
                                      - tts
                                toggledbitsT Online
                                toggledbitsT Online
                                This restriction has been lifted in build 22251. The data will now be stored as a string rather than an object, so that substitution can occur. This requires that any use of call_service be edited, so that the stored data is updated to the new form. You'll get alerts for actions that need to be edited. See the announcement for build 22251 for more info.
                                  149.8k
