  4. Create Expression to call out Entity ID of Tripped Binary Sensor
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
18 Posts 3 Posters 2.2k Views 3 Watching
    Hello all, on Reactor Vera I had a few expressions built (with the help of some of you guys) that basically listed all security sensors and then from that list, another expression listed the sensors that were tripped. Attached is a screenshot of that.
    I want to recreate those same expressions and have really only gotten as far as being able to list all the sensors as an array and since MSR expressions are not like Vera Reactors expressions I am a bit stuck. I basically need help creating an expression that will check the binary_sensor.state and if its true create spit out its entity name, and if false null. After that I think I should be able to create a message expression in similar fashion to the Vera expression.
      This thread.is a pretty good starting point. It covers a straight line approach to what you want to do. There are some enhancements available since that thread (like DynamicGroupController), but those are more advanced topics, so for this first step, stick to the basic way described in the post, which is pretty much the same as R4V, just with the updated syntax.
      Also, be sure to check out the Expression documentation for some additional clarity on the updated expression syntax. I think the bulk of the changes are not in the language itself (but there are adjustments, for sure), but mostly in the function library.
        Perfect was basically able to copy paste your solution and tweak it a bit to work. Attached is the screenshot for anyone's future reference! Screenshot 2022-09-06 125702.png
          wrote on last edited by Pabla
          Final question, can I use an expression variable in the a HA service call? I have tried this in the past but can't get it to work. The TTS is saying 'tripped_zone_names' and not the actual names of the tripped zones.
          Here is the data in the service call if the screenshot isn't clear enough
              "entity_id": "media_player.living_room",
              "message": "ALERT the ${{ tripped_zone_names }} have been opened",
              "cache": true
            You can't do it in x_hass_system.call_service (specifically and uniquely) because the data is an object field in that action, and the substitution doesn't work in object types, only in strings. You need to use the actions available in x_hass_tts. If your media_player.living_room does not natively have x_hass_tts actions listed, you'll need to add them by copy-pasting this to a file called local_hass_devices.yaml in your config directory (and restart Reactor):
            entities:
              # This media player supports TTS
              "hass>media_player_living_room":
                services:
                  - tts
            Unfortunately the Hass API doesn't expose enough info for Reactor to know that device supports the service, so it has to be done manually.
            PablaP toggledbitsT 2 Replies Last reply
              entities:
                  services:
                    - tts
              @toggledbits said in Create Expression to call out Entity ID of Tripped Binary Sensor:
              Crap this throws a wrench in a lot of my automation plans. I tried to add the TTS functionality way back and never got it working will try again.
                Having some issues with the expression that determines what zones are true. It was working when I originally created the expression but I made a few tweaks to expression names and now it doesn't work. Here is a snippet of the logs. Also a screenshot of the expression 6b193d6f-8e18-447e-a032-ef5e5e4b9e18-image.png
                [latest-22248]2022-09-06T23:41:57.638Z <Rule:INFO> Zone Open ALERT (Rule#rule-grpot1ehov) evaluation complete
                [latest-22248]2022-09-06T23:41:57.639Z <Rule:INFO> Babay/Papa Windows (Rule#rule-l7jasakd) starting evaluation; because entity-changed Entity#hass>binary_sensor_babay_papa_windows
                [latest-22248]2022-09-06T23:41:57.639Z <Rule:INFO> Zone Open ALERT (Rule#rule-grpot1ehov) starting evaluation; because entity-changed Entity#hass>binary_sensor_babay_papa_windows
                [latest-22248]2022-09-06T23:41:57.640Z <Rule:INFO> Babay/Papa Windows (Rule#rule-l7jasakd) evaluated; trigger state unchanged (false); rule state remains RESET
                [latest-22248]2022-09-06T23:41:57.640Z <Rule:INFO> Zone Open ALERT (Rule#rule-grpot1ehov) evaluated; trigger state unchanged (false); rule state remains RESET
                [latest-22248]2022-09-06T23:41:57.640Z <Rule:INFO> Babay/Papa Windows (Rule#rule-l7jasakd) evaluation complete
                [latest-22248]2022-09-06T23:41:57.641Z <Rule:INFO> Zone Open ALERT (Rule#rule-grpot1ehov) evaluation complete
                [latest-22248]2022-09-06T23:41:57.641Z <Engine:ERR> [Engine]Engine#1: error evaluating expression tripped_zones: [ReferenceError]ReferenceError: Invalid scope in reference to member binary_sensor of (object)null
                [latest-22248]2022-09-06T23:41:57.642Z <Engine:ERR> [Engine]Engine#1: expression: each id in zones_list: getEntity(id).attribute.binary_sensor.state == "true" ? id : null
                [latest-22248]2022-09-06T23:41:57.642Z <Engine:CRIT> ReferenceError: Invalid scope in reference to member binary_sensor of (object)null
                    at _run (/home/armans2/reactor/common/lexp.js:1490:31)
                    at _run (/home/armans2/reactor/common/lexp.js:1484:33)
                    at _run (/home/armans2/reactor/common/lexp.js:1334:34)
                    at _run (/home/armans2/reactor/common/lexp.js:1502:32)
                    at _run (/home/armans2/reactor/common/lexp.js:1594:41)
                    at /home/armans2/reactor/common/lexp.js:1324:29
                    at _run (/home/armans2/reactor/common/lexp.js:1323:28)
                    at run (/home/armans2/reactor/common/lexp.js:1704:22)
                    at Object.evaluate (/home/armans2/reactor/common/lexp.js:1740:20)
                  Interestingly enough I am using almost the exact same expression elsewhere just fine Screenshot 2022-09-06 170412.png
                  wmarcolinW 1 Reply Last reply
                    You're right... it is almost the exact same expression... almost. (I'm teaching here... look closely at the one the works, and the one that doesn't).
                    PablaP 2 Replies Last reply
                      Hi @Pabla
                      I'm sorry if I'm saying something wrong and out of the context of this discussion, but I'll put what I have that seems to be what you are looking for, using DynamicGroupController, which was an excellent feature that @toggledbits implemented.
                      config > reactor.yaml
                        - id: groups
                          enable: true
                            groups:
                              "dgc_low_battery":
                                name: DGC Low Battery
                                  - include_capability:
                                    - battery_power
                                filter_expression: >
                                  entity.attributes.battery_power.level < 0.3
                              "dgc_tripped":
                                    - door_sensor
                                    - motion_sensor
                                    - co_detector
                                    - smoke_detector
                                    - leak_detector
                                  entity.attributes?.door_sensor?.state == true or
                                  entity.attributes?.motion_sensor?.state == true or
                                  entity.attributes?.co_detector?.state == true or
                                  entity.attributes?.smoke_detector?.state == true or
                                  entity.attributes?.leak_detector?.state == true
                              "dgc_internal_motion":
                                name: DGC Internal Motion
                                  - include_entity:
                                    - "hubitat>40"
                                    - "hubitat>41"
                                    - "hubitat>43"
                                    - "hubitat>73"
                      When I then have the information loaded, it is easy to handle in many situations.
                      In the example below, I put in the array HouseSECURITY which devices I want to monitor, according to the way the house is, and then I crosscheck with what comes from DynamicGroup, and display messages, take actions, etc..
                      At the moment, the house is in Day mode, so there is nothing, at night I load in this variable the list of doors and windows; when it is travel, I add movement.
                      I don't know if I helped or hindered.
                      PablaP 1 Reply Last reply
                        It would be my preference that Pabla find his error, since the way he's doing it will work... worked before, and he said that, he just changed something that made it not work, and some troubleshooting is necessary. In this case, a "code review" is sufficient (a review of the failing expression, perhaps in conjunction with a careful comparison to the working similar expression).
                          Had a feeling it was a typo mistake, gonna take a look with some fresh eyes later today.
                          • wmarcolinW wmarcolin
                            Hi @Pabla
                              - id: groups
                                enable: true
                                  groups:
                                    "dgc_low_battery":
                                          - battery_power
                                    "dgc_tripped":
                                          - door_sensor
                                          - motion_sensor
                                          - co_detector
                                          - smoke_detector
                                          - leak_detector
                                        - include_entity:
                                          - "hubitat>40"
                                          - "hubitat>41"
                                          - "hubitat>43"
                                          - "hubitat>73"
                            @wmarcolin that’s my next plan! I want to get comfortable with some basic expressions first then dive into the dynamicgroupcontroller
                              @pabla said in Create Expression to call out Entity ID of Tripped Binary Sensor:
                              I highly recommend taking the time to use DynamicGroupController, before I had huge global variables, complexity to monitor and create array, when this feature was implemented it made these group management actions by characteristics much easier. Good luck!
                                okay so I checked and noticed that I wrote attribute singular and in the working one made it attributes plural. Still no success.. I even got someone else to check the syntax and they weren't able to find a difference between the working and non-working expression.
                                I fear I am overlooking something super basic which I thought I fixed but I have yet to find the error
                                Edit: I had a typo in my array of entities all is well
                                  Did the behavior change? If so, what does the new behavior look like? If not, what is in the logs?
                                    @toggledbits it works as expected now, I had a typo in one of my entities in the array.
                                      entities:
                                          services:
                                            - tts
                                      This restriction has been lifted in build 22251. The data will now be stored as a string rather than an object, so that substitution can occur. This requires that any use of call_service be edited, so that the stored data is updated to the new form. You'll get alerts for actions that need to be edited. See the announcement for build 22251 for more info.
                                        1.0k
                                        2.0k
                                        3.8k
                                        3.3k
