  4. Add Ability to Limit Amount of Time a Condition Pulses
14 Posts 4 Posters 2.1k Views 4 Watching
    @toggledbits I felt the same way @gwp1 did too, I almost swore it existed at one point lol! Will keep an eye out for the new release
    @pabla You can always count on @toggledbits to TEST your sanity and then CONFIRM it 😉
    I sometimes wonder if he does these things on purpose to see what functionality we're REALLY using lol
    *Hubitat C-7 2.5.1.142
    Core 2026.7.4
    MSR: latest-26193-8dd8f854
    PablaP toggledbitsT 2 Replies Last reply
      @gwp1 On the bright side it forces me to double check then triple check then check the manual before posting. Saves a lot of false alarms which I am guilty of doing a lot 😁
        @gwp1 said in Add Ability to Limit Amount of Time a Condition Pulses:
        At least you have it to test. 🙂
        That's an embarrassing miss, but honestly, it's hard to test GUI stuff, because it defies automation, at least, without a lot of really complex (and expensive) software. Sometimes all you can do is bang away at it, and sometimes, you won't see something you should...
        PablaP 1 Reply Last reply
          @toggledbits Hmm unless I did something wrong, none of the new changes/features are showing up. My build shows as 22256 on the top right but still don't see the ability to limit the amount of times a condition can pulse. Neither can I see any metedata info for my entities either.
          Retried the whole upgrade process and no change. Hard refreshed too.
          S 1 Reply Last reply
            @pabla Did you get any warnings about newly created entities as listed in the release notes? I did not receive any alerts and I also can't see the ability to limit the amount of times a condition can pulse.
            v latest-22256-65e94b36
            Synology Docker
            • S SweetGenius
              Synology Docker
              @sweetgenius nope didn't get any alerts either
                Sigh. Sorry guys, forgot to update the build tag. Pull the new package or docker image, same build number (22256).
                      Upgraded successfully and the limit for Pulse is back!
                        142.5k
