  4. [Solved] VirtualEntityController setup
3 Posts 2 Posters 881 Views 2 Watching
    I started kicking around the VEC last evening, was cut short, and dug in a bit more this morning.
    My reactor.yaml:
    I verified the yaml is good at https://yamlchecker.com/
    What I'm seeing in MSR:
    I believe I have followed all steps (standard disclaimers apply).
    Anyone else started to tinker with this newness and, if so, what were your results?
    *Hubitat C-7 2.5.1.142
    Core 2026.7.4
    MSR: latest-26193-8dd8f854
      Sorry, that's a doc error. Your entities should lie withing config like this:
      controllers:  # do not copy this line
        - id: virtual
          implementation: VirtualEntityController
          enabled: true
            entities:
      Also, any post where it seems likely there was an error somewhere should be accompanied by an examination of the logs and a post of what's found (with context — see the posting guidelines for explanation of what that entails if in doubt).
          - id: virtual
            enabled: true
              entities:
        @toggledbits my bad on the logs. I didn't necessarily think of this as "error" as much as "what did I miss??"
        Adjustment made and all looks happy.
        Core 2026.7.4
          145.2k
