  4. MSR Set Reaction not working anymore
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
6 Posts 2 Posters 1.1k Views 2 Watching
  • B Offline
    B Offline
    basai
    Iron: QNAP NAS
    Running MSR and HAAS on Docker (QNAP Container Station)
    Reactor (Multi-hub) stable-22203-81a2f3cc
    Home Assistant Core 2022.6.7
    Vera 1.7.5186 (7.31)
    Config files are stored in shared volumes on the NAS.
    Office light in example is joined to Vera-Plus
    Hello all,
    I decided to upgrade MSR to latest-amd64. It wasn’t until afterwards that I noticed all rulesets broken. So unfortunately I’m not sure if this was already broken before or I broke it after upgrading. Yes poor judgement on my part for being complacent.
    Never the less, this is broken globally across all rulesets, even though I can see the triggers change to “True” (Turn green).
    For this example, I have a boolean helper toggle in HAAS called “TV MODE HAAS SW”.
    When toggled ‘on’, MSR should turn my Vera office light OFF and it doesn’t, but if I manually select the play button to the right of the line in the Set Reaction, it executes properly and turns off the Vera office light.
    The MSR Rule does not have any Constraints set.
    I can see in MSR it recognizes the state changes yet doesn’t execute the “Set Reaction”.
    Any help greatly appreciated.
    Log files from reactor.log and screen shots to follow:
    Reactor.log when toggling the haas helper, Set Reaction doesn’t execute.
    [stable-22203]2022-10-02T21:21:34.799Z <Rule:INFO> TV MODE ON (Rule#rule-l2hvuz8r) starting evaluation; because entity-changed Entity#hass>input_boolean_tv_mode
    [stable-22203]2022-10-02T21:21:34.800Z <Rule:INFO> TV MODE ON (Rule#rule-l2hvuz8r) evaluated; rule state transition from RESET to SET!
    [stable-22203]2022-10-02T21:21:34.819Z <Rule:INFO> TV MODE ON (Rule#rule-l2hvuz8r) evaluation complete
    [stable-22203]2022-10-02T21:21:34.820Z <Engine:INFO> Enqueueing "TV MODE ON<SET>" (rule-l2hvuz8r:S)
    [stable-22203]2022-10-02T21:21:34.835Z <Engine:NOTICE> Starting reaction TV MODE ON<SET> (rule-l2hvuz8r:S)
    [stable-22203]2022-10-02T21:21:34.835Z <Engine:INFO> TV MODE ON<SET> all actions completed.
    Reactor.log when manually triggering the Set Reaction with the play button which correctly turns off the light
    [stable-22203]2022-10-02T21:23:25.035Z <HassController:null> HassController#hass: sending payload for power_switch.off on Entity#hass>light_office_86 action: [Object]{ "type": "call_service", "service_data": { "entity_id": "light.office_86" }, "domain": "homeassistant", "service": "turn_off" }
    When toggled ON
    Rule config screen
      I'm seeing a lot of conflicting information in your report. 22203 is not latest, it's the older stable (and your log entries confirm this as well). Your office light being turned off in the SET reaction you show is on Hass, not on Vera.
      I would upgrade to the true latest 22274 for starters; I won't really spend time troubleshooting on anything but the current (latest development build) version (i.e. if you're having a problem, make sure you test on the latest version before seeking help -- see the posting guidelines).
      B 1 Reply Last reply
        B Offline
        B Offline
        basai
        Apologies for the confusion.
        I was trying to indicate, although poorly, that I did install 'latest' at first which didn't correct the problem and then opted to go with 'stable' thinking that was the better choice.
        As far as the MSR Set Reaction using haas vs vera per my report, I was testing both and neither worked when the rule is triggered, however the light does turn off when I manually select the play button next to the Set Reaction Rule for either the set haas or vera case. Unfortunately I neglected to reflect that correctly in my report and hence the mismatch / confusion
        HTH
        -bh
          There are quite a few people on latest, including myself on three systems. If there was a problem with reactions, I think there would be more than one report. Please try reinstalling latest, restart, and then confirm in the log entries that you have the correct version running (as of this weekend that would be latest-22274). I suspect your attempted upgrade didn't go as planned.
          • B Offline
            B Offline
            basai
            Howdy, Honestly I didn’t really think this was an MSR Set Reaction pandemic and was more than likely a locally induced error of some sort.
            This is fixed now based on something you said in your last reply suspecting an update problem which pulled me out of a loop and put me on the right path.
            Summary: Upgrading to latest-22274 fixed the problem but QNAP’s Container Station using the Docker Hub Tab would only download and install latest-22179. Not sure if this is a QNAP bug or feature.
            Detail: For the benefit of any QNAP NAS users out there I’ll explain.
            Using QNAP NAS’s Container Station, searching for “reactor” in the “Docker Hub” tab I would select "latest-amd64”, but it would only install latest-22179 and not the actual latest-22274. Picking up the NAS and shaking it a few times, turning it off and on again, or putting more quarters in it didn't help.
            In the past I didn’t find a need to do the following since I believe Container Station should be doing this all by self, and if not, user error on my part.
            So to fix this I ssh’d to the QNAP NAS CLI and ran.
            docker pull toggledbits/reactor:latest-amd64
            Which returned the following, I was feeling optimistic seeing the "pull completes' "
            [basai@basai ~]$ docker pull toggledbits/reactor:latest-amd64
            latest-amd64: Pulling from toggledbits/reactor
            8663204ce13b: Already exists
            8c392e9e905c: Already exists
            36ce72f2f129: Already exists
            2e8529c47e46: Already exists
            26c2865d7fe4: Pull complete
            b45a2cf2a065: Pull complete
            ac02d13d40de: Pull complete
            2bd82a6d3d8c: Pull complete
            Digest: sha256:a192e403200a62664cec40f40f61499218ac9a0cae3b8ed8390f87679505105d
            Status: Downloaded newer image for toggledbits/reactor:latest-amd64
            docker.io/toggledbits/reactor:latest-amd64
            [basai@basai ~]$
            After this completed, now when I went to create a new docker by going into container station, searching for “reactor” in the “Docker Hub Tab” and selected “latest-amd64” it correctly installed latest-22274 and also pre-populated the NODE_PATH variable correctly which wasn’t happening before.
            Problem solved and MSR is working as expected again.
            Thanks you for your help, MSR Rocks!
            -bh
            • B basai
              [basai@basai ~]$
              -bh
              @basai said in MSR Set Reaction not working anymore:
              LOL! That inflation is hitting everything, isn't it?
              Glad it worked out!
              • Next Release?
                1.0k
