x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Hey @toggledbits
I'm currently on version 26011. I understand that the aarch64 image is no longer supported. So, I therefore need to update to the ARM64 image. Can anyone possibly suggest how I update my docker compose.yaml file (see below). Ideally I'd like to keep my existing reactions etc. rather than start from scratch.
# Multi-System Reactor template docker-compose.yml (version 22160)
# Change the lines indicated by "DO"...
services:
reactor:
container_name: reactor
environment:
TZ: GB
restart: "always"
expose:
- 8111
ports:
- 8111:8111
volumes:
- /home/pi/docker/reactor:/var/reactor
tmpfs: /tmp
Deleting widgets
Hopefully a trivial question, but how do you delete widgets in a status page? Using build 22266
@tunnus Drag the widget off to the left side and it will disappear.
@sweetgenius thanks!
M mgvra referenced this topic on
As of build 24343, widget deletion is accomplished by dragging the widget to the top navigation bar (only). Dragging to the left margin no longer deletes the widget.
