  4. Update from 22240 to 22310 failed. New Install also failed. (Windows)
4 Posts 3 Posters 883 Views 3 Watching
    Andr
    wrote on last edited by Andr
    So it was time to update MSR (and then HA but I got stuck here)
    Can't figure out what I have missed.
    My installed version of MSR was 22240.
    Node.js is version 16.15.1
    First I tried to update, following online manual.
    ||Download a Reactor distribution ZIP from https://reactor.toggledbits.com/download/ and place it in the folder above your existing reactor (runtime) directory.
    Stop and remove any existing Reactor service:
    cd \path\to\reactor
    node tools\install_reactor_windows_service.js -u .
    Remove any existing package-lock.json file from your Reactor directory.
    Unzip the archive file and copy its contents over the contents of your existing Reactor install directory.
    From the Reactor install directory, re-install/upgrade all package dependencies:
    npm install --no-save --omit dev
    If you are running Reactor as a Windows service, repeat those steps above.
    Restart Reactor (restart the service).
    Hard-refresh all browsers that are displaying Reactor content.||
    I found several (maybe it was 3) package-lock.json and I deleted all I could search in reactor folder.
    Unzip the new version and replaced old existing files.
    Install the reactor service again by instructions.
    ||In a command prompt window, running as Administrator, change directory to your Reactor install directory.
    Install the node-windows package as a global package (it must be global or the service will not work, and you must install the specific version provided by the command below):
    npm uninstall node-windows
    npm uninstall -g node-windows
    npm install -g node-windows@1.0.0-beta.6
    npm link node-windows
    Run the script to install:
    node tools\install_reactor_windows_service.js -i .||
    So this failed. Service wont start.
    Tried again.
    Then deleted everything exept my config folder and did a new install.
    Also downloaded 22310 again, but from "latest" build instead of "stable"
    When running node app.js in command promt i get some kind of error message:
    c:\reactor>node app.js
    Reactor latest-22310-a6da8097 app 22310 configuration from c:\reactor\config
    NODE_PATH C:\reactor
    [latest-22310]2022-11-23T22:18:43.030Z <app:null> Reactor build latest-22310-a6da8097 starting on v16.15.1
    c:\reactor\app.js:277
    log['always'](a0_0x3d42be(0x26a), BUILD_VERSION, process['version']), log['always']('Process\x20ID\x20%1\x20user/group\x20%2/%3;\x20%4;\x20platform\x20%5/%6\x20%7;\x20locale\x20%8', process['pid'], process[a0_0x3d42be(0x269)](), process[a0_0x3d42be(0x278)](), is_docker ? 'docker' : a0_0x3d42be(0x288), process[a0_0x3d42be(0x287)], process['arch'], os[a0_0x3d42be(0x263)](), sys_locale), log[a0_0x3d42be(0x28c)]('Basedir\x20%1;\x20data\x20in\x20%2', c[a0_0x3d42be(0x1f8)], c[a0_0x3d42be(0x27b)]), log[a0_0x3d42be(0x28c)](a0_0x3d42be(0x21b), process['env'][a0_0x3d42be(0x291)]);
    TypeError: process[a0_0x3d42be(...)] is not a function
        at Object.<anonymous> (c:\reactor\app.js:277:226)
        at Module._compile (node:internal/modules/cjs/loader:1105:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
        at node:internal/main/run_main_module:17:47
    But I can't figure out what TypeError means?
    Also, before I tried a new install, there apperd an warning when installing reactor service.
    c:\reactor>npm install -g node-windows@1.0.0-beta.6
    npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
    added 5 packages, and audited 6 packages in 3s
    2 vulnerabilities (1 moderate, 1 critical)
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    Running npm audit fix --force seems to broke something, because I could not install service after that.
    c:\reactor>npm audit fix --force
    npm WARN using --force Recommended protections disabled.
    up to date, audited 89 packages in 826ms
    12 packages are looking for funding
      run `npm fund` for details
    found 0 vulnerabilities
    c:\reactor>node tools\install_reactor_windows_service.js -i .
    node:internal/modules/cjs/loader:936
      throw err;
    Error: Cannot find module 'node-windows'
    Require stack:
    - c:\reactor\tools\install_reactor_windows_service.js
    ←[90m    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)←[39m
    ←[90m    at Function.Module._load (node:internal/modules/cjs/loader:778:27)←[39m
    ←[90m    at Module.require (node:internal/modules/cjs/loader:1005:19)←[39m
    ←[90m    at require (node:internal/modules/cjs/helpers:102:18)←[39m
        at Object.<anonymous> (c:\reactor\tools\install_reactor_windows_service.js:102:15)
    ←[90m    at Module._compile (node:internal/modules/cjs/loader:1105:14)←[39m
    ←[90m    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)←[39m
    ←[90m    at Module.load (node:internal/modules/cjs/loader:981:32)←[39m
    ←[90m    at Function.Module._load (node:internal/modules/cjs/loader:822:12)←[39m
    ←[90m    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)←[39m {
      code: ←[32m'MODULE_NOT_FOUND'←[39m,
      requireStack: [ ←[32m'c:\\reactor\\tools\\install_reactor_windows_service.js'←[39m ]
      I built a bare-metal only build 22238; download that and try it. Follow the instructions exactly. Do not run npm audit on Windows, you'll break the node-windows package and the service will not be installed. You must use exactly the version specified in the installation instructions right now.
        Andr
        @toggledbits said in Update from 22240 to 22310 failed. New Install also failed. (Windows):
        Yes, that fixed it!
        Awesome support as always!
        • tunnusT Online
          tunnusT Online
          @toggledbits, 22310 release notes are missing from the announcements?
            154.9k
