  4. Update from 22240 to 22310 failed. New Install also failed. (Windows)
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 3 Posters 941 Views 3 Watching
    Andr
    wrote on last edited by Andr
    So it was time to update MSR (and then HA but I got stuck here)
    Can't figure out what I have missed.
    My installed version of MSR was 22240.
    Node.js is version 16.15.1
    First I tried to update, following online manual.
    ||Download a Reactor distribution ZIP from https://reactor.toggledbits.com/download/ and place it in the folder above your existing reactor (runtime) directory.
    Stop and remove any existing Reactor service:
    cd \path\to\reactor
    node tools\install_reactor_windows_service.js -u .
    Remove any existing package-lock.json file from your Reactor directory.
    Unzip the archive file and copy its contents over the contents of your existing Reactor install directory.
    From the Reactor install directory, re-install/upgrade all package dependencies:
    npm install --no-save --omit dev
    If you are running Reactor as a Windows service, repeat those steps above.
    Restart Reactor (restart the service).
    Hard-refresh all browsers that are displaying Reactor content.||
    I found several (maybe it was 3) package-lock.json and I deleted all I could search in reactor folder.
    Unzip the new version and replaced old existing files.
    Install the reactor service again by instructions.
    ||In a command prompt window, running as Administrator, change directory to your Reactor install directory.
    Install the node-windows package as a global package (it must be global or the service will not work, and you must install the specific version provided by the command below):
    npm uninstall node-windows
    npm uninstall -g node-windows
    npm install -g node-windows@1.0.0-beta.6
    npm link node-windows
    Run the script to install:
    node tools\install_reactor_windows_service.js -i .||
    So this failed. Service wont start.
    Tried again.
    Then deleted everything exept my config folder and did a new install.
    Also downloaded 22310 again, but from "latest" build instead of "stable"
    When running node app.js in command promt i get some kind of error message:
    c:\reactor>node app.js
    Reactor latest-22310-a6da8097 app 22310 configuration from c:\reactor\config
    NODE_PATH C:\reactor
    [latest-22310]2022-11-23T22:18:43.030Z <app:null> Reactor build latest-22310-a6da8097 starting on v16.15.1
    c:\reactor\app.js:277
    log['always'](a0_0x3d42be(0x26a), BUILD_VERSION, process['version']), log['always']('Process\x20ID\x20%1\x20user/group\x20%2/%3;\x20%4;\x20platform\x20%5/%6\x20%7;\x20locale\x20%8', process['pid'], process[a0_0x3d42be(0x269)](), process[a0_0x3d42be(0x278)](), is_docker ? 'docker' : a0_0x3d42be(0x288), process[a0_0x3d42be(0x287)], process['arch'], os[a0_0x3d42be(0x263)](), sys_locale), log[a0_0x3d42be(0x28c)]('Basedir\x20%1;\x20data\x20in\x20%2', c[a0_0x3d42be(0x1f8)], c[a0_0x3d42be(0x27b)]), log[a0_0x3d42be(0x28c)](a0_0x3d42be(0x21b), process['env'][a0_0x3d42be(0x291)]);
    TypeError: process[a0_0x3d42be(...)] is not a function
        at Object.<anonymous> (c:\reactor\app.js:277:226)
        at Module._compile (node:internal/modules/cjs/loader:1105:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
        at Module.load (node:internal/modules/cjs/loader:981:32)
        at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
        at node:internal/main/run_main_module:17:47
    But I can't figure out what TypeError means?
    Also, before I tried a new install, there apperd an warning when installing reactor service.
    c:\reactor>npm install -g node-windows@1.0.0-beta.6
    npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
    added 5 packages, and audited 6 packages in 3s
    2 vulnerabilities (1 moderate, 1 critical)
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    Running npm audit fix --force seems to broke something, because I could not install service after that.
    c:\reactor>npm audit fix --force
    npm WARN using --force Recommended protections disabled.
    up to date, audited 89 packages in 826ms
    12 packages are looking for funding
      run `npm fund` for details
    found 0 vulnerabilities
    c:\reactor>node tools\install_reactor_windows_service.js -i .
    node:internal/modules/cjs/loader:936
      throw err;
    Error: Cannot find module 'node-windows'
    Require stack:
    - c:\reactor\tools\install_reactor_windows_service.js
    ←[90m    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)←[39m
    ←[90m    at Function.Module._load (node:internal/modules/cjs/loader:778:27)←[39m
    ←[90m    at Module.require (node:internal/modules/cjs/loader:1005:19)←[39m
    ←[90m    at require (node:internal/modules/cjs/helpers:102:18)←[39m
        at Object.<anonymous> (c:\reactor\tools\install_reactor_windows_service.js:102:15)
    ←[90m    at Module._compile (node:internal/modules/cjs/loader:1105:14)←[39m
    ←[90m    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)←[39m
    ←[90m    at Module.load (node:internal/modules/cjs/loader:981:32)←[39m
    ←[90m    at Function.Module._load (node:internal/modules/cjs/loader:822:12)←[39m
    ←[90m    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)←[39m {
      code: ←[32m'MODULE_NOT_FOUND'←[39m,
      requireStack: [ ←[32m'c:\\reactor\\tools\\install_reactor_windows_service.js'←[39m ]
    • toggledbitsT Online
      toggledbitsT Online
      I built a bare-metal only build 22238; download that and try it. Follow the instructions exactly. Do not run npm audit on Windows, you'll break the node-windows package and the service will not be installed. You must use exactly the version specified in the installation instructions right now.
        Andr
        @toggledbits said in Update from 22240 to 22310 failed. New Install also failed. (Windows):
        Yes, that fixed it!
        Awesome support as always!
          @toggledbits, 22310 release notes are missing from the announcements?
            165.3k
