  4. [Solved] latest-22328 restart fails
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
27 Posts 4 Posters 4.6k Views 4 Watching
  • CrilleC Online
    CrilleC Online
    Solution: An update to openLuups MQTT implementation on handling acknowledge packets for QoS > 0 solved this issue.
    EDIT: Seems related to any restart without any configuration changes. If I revert to 22310 I can restart Reactor from UI and with systemd within seconds, but with 22328 it fails to restart., both from UI and systemd. I have to stop the service and then start again.
    I tested to comment out my http (not https) baseurl in the config on my bare metal Ubuntu install latest-22328 and triggered a restart from the UI but Reactor would not start after that.
    If I uncomment the key and restart the service, Reactor comes back to life.
    Is my setup an exceptional circumstance or is this only applicable on new installs
      It's working for me, and I've done some fresh installs of 22328 while testing alternatives to Raspberry Pi (a couple of promising boards so far). I hate to say it, but your post is right on the line of "I tried X and it didn't work for me," so without more detail, I can't really guide you.
        CrilleC Online
        CrilleC Online
        @toggledbits said in latest-22328 and baseurl [EDIT]: restarts fail:
        It's working for me
        This is at first all I wanted to know, if anyone else was having the same issue or it's just my setup.
        Sorry for the lack of details, I did not know what else to provide as the log is dead silent after shutting down...
        I will debug further.
          Working fine for me on bare metal Debian Bullseye as well
          • CrilleC Online
            CrilleC Online
            Looks like it's related to openLuups MQTT server. The shutdown process hangs after sending LWT to openLuup (MQTTController#mqtt in log).
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.775Z <app:NOTICE> Closing Structure...
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.776Z <Structure:INFO> Structure#1 Stopping controllers...
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.776Z <Controller:NOTICE> VeraController#vera stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.778Z <Controller:ERR> Controller VeraController#vera is off-line!
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.799Z <EzloController:NOTICE> EzloController#ezlo stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.800Z <wsapi:WARN> client close from unknown connection? "192.168.1.2#5"
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.800Z <wsapi:WARN> client close from unknown connection? "192.168.1.238#4"
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.800Z <wsapi:WARN> client close from unknown connection? "192.168.1.238#3"
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.800Z <wsapi:WARN> client close from unknown connection? "192.168.1.238#2"
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.800Z <wsapi:WARN> client close from unknown connection? "192.168.1.2#1"
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.802Z <EzloController:NOTICE> EzloController#ezlo connection closed: 1000 closing
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.804Z <Controller:ERR> Controller EzloController#ezlo is off-line!
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.804Z <Controller:NOTICE> EzloController#ezlo stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.806Z <DynamicGroupController:null> DynamicGroupController#groups stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.806Z <Controller:NOTICE> DynamicGroupController#groups stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.808Z <Controller:ERR> Controller DynamicGroupController#groups is off-line!
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.809Z <HassController:NOTICE> HassController#hass stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.810Z <HassController:NOTICE> HassController#hass websocket closing, 1000
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.810Z <Controller:NOTICE> HassController#hass stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.811Z <Controller:ERR> Controller HassController#hass is off-line!
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.823Z <Controller:NOTICE> OWMWeatherController#weather stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.824Z <Controller:ERR> Controller OWMWeatherController#weather is off-line!
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.825Z <Controller:NOTICE> SystemController#reactor_system stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.826Z <Controller:ERR> Controller SystemController#reactor_system is off-line!
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.827Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt stopping, sending LWT
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.870Z <MQTTController:NOTICE> LWT sent; closing broker connection
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.870Z <Controller:NOTICE> MQTTController#mosquitto-mqtt stopping
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.871Z <Controller:ERR> Controller MQTTController#mosquitto-mqtt is off-line!
            Nov 26 10:45:58 homebridge node[686832]: [latest-22328]2022-11-26T09:45:58.874Z <MQTTController:NOTICE> MQTTController#mqtt stopping, sending LWT
            Nov 26 10:46:03 homebridge node[686832]: [latest-22328]2022-11-26T09:46:03.452Z <httpapi:INFO> HTTP server closed.
            If I disable that controller Reactor restarts fine as usual.
            @toggledbits Is this the moment openLuup MQTT support ends in Reactor or can I change something to make it work again?
            @akbooer I've updated openLuup from 22.9.3 to 22.11.22 but no success to this issue.
            The thing is it's running great when it finally comes up again after a long wait of a forced restart with systemd but it doesn't feel right to force kill the process even though the shutdown process is almost finished.
              @crille said in latest-22328 restart fails:
              I think we've seen an issue like that previously. I don't think I see that line in the log you posted?
              There may be a problem with retained messages (ie. LWT) and wildcard subscriptions in the openLuup server... I'd have to check.
                CrilleC Online
                CrilleC Online
                @akbooer Yes, that was when openLuup reloaded and Reactor would reconnect but Patrick did a fix for that. This is when shutting down Reactor, could be the related though.
                  I use a popular package to handle the MQTT broker connection, so I can't see the innards of communications and confirm, but from the rhythm of the log output, it appears that the broker is not sending an ACK to the publish of the LWT; the publish() call appears to be sitting there waiting for it.
                    CrilleC Online
                    CrilleC Online
                    Does this mean 22328 require an ACK but 22310 does not? or has something else changed?
                      22310 still required an ACK, in a sense. It didn't wait for it. But because the ACK never arrived, the task in the mqtt package also never cleared (they don't have a time-out mechanism), so it just stayed in the queue forever... as did every other topic sent with a non-zero QoS. This actually causes a memory leak that could lead to exhaustion and a crash, because the ACK never comes so the task is never removed from the queue, and those tasks remain and proliferate in the queue.
                      IMO, I think it's fine if @akbooer doesn't truly support QoS levels 1 and 2 in his MQTT implementation just for basic use, but not sending an ACK regardless isn't the right choice, in my view, and it's going to cause problems for a lot of clients that may not be immediately evident (like memory leaks/exhaustion).
                        @toggledbits said in latest-22328 restart fails:
                        It only supports QoS 0 .
                        Nevertheless, the protocol should be respected. AFAIK all PUBLISH requests receive an ACK unless the connection goes down in between times.
                          This is the end of parse.PUBLISH():
                            -- ACKNOWLEDGEMENT
                            -- The receiver of a PUBLISH Packet MUST respond according to Table 3.4 - Expected Publish Packet
                            --   response as determined by the QoS in the PUBLISH packet [MQTT-3.3.4-1]
                                  Table 3.4 - Expected Publish Packet response
                                  QoS Level Expected Response
                                  QoS 0 None
                                  QoS 1 PUBACK Packet
                                  QoS 2 PUBREC Packet
                            local ack    -- None, because we only handle QoS 0
                            return ack, nil, TopicName, ApplicationMessage, RETAIN
                          Comments to the contrary, it appears it returns ack, which is declared but nil... so... no ACK?
                            Ah yes. It's been a while. So that's right, then.
                                -- ACKNOWLEDGEMENT
                                      QoS 0 None
                                      QoS 1 PUBACK Packet
                                      QoS 2 PUBREC Packet
                              CrilleC Online
                              CrilleC Online
                              @toggledbits does Reactor publish it's LWT message with QoS > 0 even though the MQTTController config is at qos: 0? otherwise the expected response would be none.
                                Yes, it uses QoS 1 (and retain true) because it's a "vital" message. The qos you can set in config is for the echo/entity publish functionality; it does not affect other messages. Still, this only requires that the broker acknowledge its receipt (3.3.4), not any delivery, and does not even enforce that QoS on subscribers (3.8.3)
                                • CrilleC Online
                                  CrilleC Online
                                  "The receiver of a PUBLISH Packet MUST respond according to Table 3.4 - Expected Publish Packet response as determined by the QoS in the PUBLISH Packet."
                                  So even though the server only supports QoS 0 it's obligated to send a PUBACK on a QoS 1 level packet as described in table 3.4, correct?
                                    Yes, PUBACK for QoS 1, and PUBREC for QoS 2. I don't think that would be a big problem for @akbooer when he gets the time, because all of the information contained in the response can be sourced from the request (i.e. topic, packet identifier, etc.). And otherwise the treatment of the PUBLISH packet can be the same (no further changes beyond sending those ACKs). Not actually having guaranteed delivery behind that is, in my view, an acceptable variance. On the sending side (repeat to subscribers), even though a subscriber may request QoS 1 or 2 for packets from the broker, it still must accept QoS 0 packets (because the requested QoS is a maximum, not an absolute), so everything outbound at QoS 0 isn't likely going to cause problems, especially in this world.
                                    To summarize: if he just provides the PUBACK and PUBREC responses to fix that layer of the protocol, that's good enough. No further actions required above that layer. Not fully compliant (no guaranteed delivery), but at that point, few if any would ever notice.
                                    The other question I don't have an answer for (or I've forgotten; and haven't dug through code to figure out)... @akbooer, does it support retain? If so, what's the storage mechanism, and is it persistent?
                                      Well, I must be reading the MQTT 3.1.1 spec all wrong.
                                      When I read:
                                      "The SUBACK Packet sent by the Server to the Client MUST contain a return code for each Topic Filter/QoS pair. This return code MUST either show the maximum QoS that was granted for that Subscription or indicate that the subscription failed [MQTT-3.8.4-5]. The Server might grant a lower maximum QoS than the subscriber requested. The QoS of Payload Messages sent in response to a Subscription MUST be the minimum of the QoS of the originally published message and the maximum QoS granted by the Server. The server is permitted to send duplicate copies of a message to a subscriber in the case where the original message was published with QoS 1 and the maximum QoS granted was QoS 0 [MQTT-3.8.4-6]."
                                      ...I understood it to mean that, since I only ever grant QoS 0, then no message would require a PUBACK or a PUBREC.
                                      I realise that this is my bad for writing my own MQTT broker, but it made sense in the context of openLuup, especially in support of Shelly devices which was the reason I did it in the first place. I apologise if this has led to some difficulties, and I'm starting to look at an MQTT validation suite to check out my implementation further. I also realize that Mosquitto is the de-facto standard, but it turns out that having an internal server confers some significant benefits in terms of the internal openLuup architecture.
                                      However, if anyone can clarify the about QoS response issue further, I'm very happy to comply. If a simple fix is to send PUBACK or PUBREC, then I'll do it, but I want to know the reason why. I do understand that the original CONNECT request contains a LWT QoS, per this paragraph:
                                      3.1.2.6 Will QoS
                                      "Position: bits 4 and 3 of the Connect Flags."
                                      "These two bits specify the QoS level to be used when publishing the Will Message."
                                      "If the Will Flag is set to 0, then the Will QoS MUST be set to 0 (0x00) [MQTT-3.1.2-13]."
                                      "If the Will Flag is set to 1, the value of Will QoS can be 0 (0x00), 1 (0x01), or 2 (0x02). It MUST NOT be 3 (0x03) [MQTT-3.1.2-14]."
                                      ...but I had assumed that QoS to be overridden by the actual level established in SUBSCRIBE / SUBACK. However, now that I write that, it seems the LWT actually may have a separate life from standard messages?
                                        Yes, it supports retained messages.
                                        Is it persistent? Not across openLuup restarts.
                                        The openLuup console page: openLuupIP:3480/console?page=mqtt shows all current subscriptions and also (at the bottom) retained messages.
                                          When I read:
                                          3.1.2.6 Will QoS
                                          @akbooer said in latest-22328 restart fails:
                                          This section is about your response to a SUBSCRIBE (SUBACK)and what QoS you use to PUBLISH. If you only grant QoS 0 on subscribe, then you will never expect a PUBACK or PUBREC because you never publish anything to a subscriber other than QoS 0.
                                          It in no way limits what a client may publish to the broker, which could include any QoS.
                                          • Oh the joy of pairing
                                          • HDMI oddness
                                            668
                                            sethlampman
                                          • Date/time condition
