  4. [Solved] MSR actions aren't running anymore-- can't find what's broken
7 Posts 5 Posters 1.6k Views 5 Watching
  • E Offline
    E Offline
    Edwin1972
    Suddenly my MSR actions aren't running anymore. I've had this before, but with an update to a new version it was fixed. see also
    https://smarthome.community/topic/987/msr-actions-aren-t-running-anymore-can-t-find-what-s-broken/3?_=1674661492589
    But an update from version 22240 to 22256 gave this time no result.
    The reactions aren't running correctly. Most of my MSR automations are use turn lights on/off, and time based automations nothing worked where MSR does his magic.
    I've also tested a bunch of things to see what's broken, here's what I've observed:
    -I can successfully flip lights on/off manually within Vera
    -I can successfully flip lights on/off manually within MSR's Entities section
    -the sensors are correctly reporting to Vera and MSR (I can see when they're switch on/off)
    -the rules within MSR are working correctly, I can see when they flip to 'true' of 'false' '
    But I cannot successfully run the "Set Reaction" and "Reset Reaction" within MSR (by hitting the 'play' button)
    But the play buttons on the entitiy action in the "Set Reaction" and in "Reset Reaction" they work well.
    Can someone help me to get MSR working again
    MSR is running bare metal on Rpi4
    PablaP therealdbT toggledbitsT 3 Replies Last reply
    • E Edwin1972
      @Edwin1972 have a look at the reactor logs and paste them here whenever the issues occur
      • E Edwin1972
        @Edwin1972 please be more specific. Do you have actions in groups? And/or/not? Any constraints?
        Also, logs are really the starting point to look at, as suggested by @Pabla
        • E Edwin1972
          @Edwin1972 I'm wondering why you would upgrade from a very out of date version to an only-slightly-less out of date version?
          Current is 23010.
          • E Offline
            E Offline
            Edwin1972
            Thanks for quick response. I'm not handy with log files yet. I'll try in the weekend. first I will upgrade to the latest version.
            • E Offline
              E Offline
              Edwin1972
              I updated my pi4 with commande sudo apt upgrade and then updated MSR to 23010 and everything works fine.
              Thanks you all for your response.
              • E Edwin1972
                @Edwin1972 Please update the topic to have [Solved] at the beginning.
                Glad everything worked out!
                  151.9k
