  4. Can I use Dynamic Group Control for Triggers and Reactions?
19 Posts 3 Posters 4.6k Views 3 Watching
    @tamorgen That sounds vaguely familiar!
    @gwp1 said in Can I use Dynamic Group Control for Triggers and Reactions?:
    Low and behold iBlinds support finally got back with me, and they actually acknowledged the original problem I was seeing was actually a problem.
    Hi Timothy,
    Very sorry for the delayed response, we have been getting more reports of this issue and have been building up to a solution. We have determined this to be a driver issue within Home Assistant that will need to be addressed for each hub.
    We have never really sent battery report until battery level drops to the low battery alert threshold and this feature is required by zwave certification.  We always had the hub poll the battery level since some hubs opted for polling the device independently of the device sending a report. ​We will need to add polling to the HA driver and other drivers of the same issue.
    Thank you for your patience.
    Thanks,
    Chance H.
    The iBlinds Team
    and
    Hi Timothy,
    To add to this, the polling will update the position as well as the battery to address your issue specifically.
    Thanks,
    Chance H.
    The iBlinds Team
    Feeling some vindication, after their original emails were all to the tone of "you're doing it wrong, you need to exclude and pair your devices. You need beaming repeaters (I guess the 55 other devices that aren't battery powered and are beaming don't count)."
      I've split this topic. This thread remains for discussion specific to iBlinds only; if you have further comments on your issue getting ZWaveJSController running, please make those in the new thread where that specific discussion takes place.
        @toggledbits said in Can I use Dynamic Group Control for Triggers and Reactions?:
        Thanks Patrick, that's fine. I knew it was going off on a bit of a tangent and asked you to fork it a bit ago. 🙂
        Back to the original subject, now that I'm have ZWaveJSController working and I can use the refresh command, I still want to set up a rule based upon a state changing to poll the entity and force that refresh.
        I set up the Dynamic Groups in my reactor.yaml using the zwavejs entities. I have three ones set up. One for the switch state, one for the position state, and one for the cover state. This way, I can run refresh if anyone of them changes. If there is a better way, please let me know.
                "iblinds_switch":
                    - include_entity:
                      - 'zwavejs>63-0'
                      - 'zwavejs>62-0'
                      - 'zwavejs>64-0'
                      - 'zwavejs>65-0'
                      - 'zwavejs>79-0'
                      - 'zwavejs>77-0'
                      - 'zwavejs>78-0'
                      - 'zwavejs>206-0'
                      - 'zwavejs>205-0'
                      - 'zwavejs>75-0'
                      - 'zwavejs>74-0'
                      - 'zwavejs>71-0'
                      - 'zwavejs>16-0'
                      - 'zwavejs>61-0'
                  filter_expression: >
                    entity.power_switch.state
                "iblinds_position":
                    - include_entity:
                      - 'zwavejs>63-0'
                      - 'zwavejs>62-0'
                      - 'zwavejs>64-0'
                      - 'zwavejs>65-0'
                      - 'zwavejs>79-0'
                      - 'zwavejs>77-0'
                      - 'zwavejs>78-0'
                      - 'zwavejs>206-0'
                      - 'zwavejs>205-0'
                      - 'zwavejs>75-0'
                      - 'zwavejs>74-0'
                      - 'zwavejs>71-0'
                      - 'zwavejs>16-0'
                      - 'zwavejs>61-0'
                    entity.cover.position.value
                "iblinds_cover":
                    - include_entity:
                      - 'zwavejs>63-0'
                      - 'zwavejs>62-0'
                      - 'zwavejs>64-0'
                      - 'zwavejs>65-0'
                      - 'zwavejs>79-0'
                      - 'zwavejs>77-0'
                      - 'zwavejs>78-0'
                      - 'zwavejs>206-0'
                      - 'zwavejs>205-0'
                      - 'zwavejs>75-0'
                      - 'zwavejs>74-0'
                      - 'zwavejs>71-0'
                      - 'zwavejs>16-0'
                      - 'zwavejs>61-0'
                    entity.cover.state
        The rule I'm trying to set up is to look for any change on those switches (on to off or off to on), and then set a reaction to refresh the cover (zwave_device.refresh)
        In the set reaction, it doesn't appear to let my dig down any further once I put the group in. What do I need to do to make this work, if it's even possible.
        • T tamorgen
                  "iblinds_switch":
                      - include_entity:
                        - 'zwavejs>63-0'
                        - 'zwavejs>62-0'
                        - 'zwavejs>64-0'
                        - 'zwavejs>65-0'
                        - 'zwavejs>79-0'
                        - 'zwavejs>77-0'
                        - 'zwavejs>78-0'
                        - 'zwavejs>206-0'
                        - 'zwavejs>205-0'
                        - 'zwavejs>75-0'
                        - 'zwavejs>74-0'
                        - 'zwavejs>71-0'
                        - 'zwavejs>16-0'
                        - 'zwavejs>61-0'
                  "iblinds_position":
                      - include_entity:
                        - 'zwavejs>63-0'
                        - 'zwavejs>62-0'
                        - 'zwavejs>64-0'
                        - 'zwavejs>65-0'
                        - 'zwavejs>79-0'
                        - 'zwavejs>77-0'
                        - 'zwavejs>78-0'
                        - 'zwavejs>206-0'
                        - 'zwavejs>205-0'
                        - 'zwavejs>75-0'
                        - 'zwavejs>74-0'
                        - 'zwavejs>71-0'
                        - 'zwavejs>16-0'
                        - 'zwavejs>61-0'
                  "iblinds_cover":
                      - include_entity:
                        - 'zwavejs>63-0'
                        - 'zwavejs>62-0'
                        - 'zwavejs>64-0'
                        - 'zwavejs>65-0'
                        - 'zwavejs>79-0'
                        - 'zwavejs>77-0'
                        - 'zwavejs>78-0'
                        - 'zwavejs>206-0'
                        - 'zwavejs>205-0'
                        - 'zwavejs>75-0'
                        - 'zwavejs>74-0'
                        - 'zwavejs>71-0'
                        - 'zwavejs>16-0'
                        - 'zwavejs>61-0'
                      entity.cover.state
          @tamorgen said in Can I use Dynamic Group Control for Triggers and Reactions?:
          Experimental, undocumented feature: add group_actions: true to your group's configuration:
              "iblinds_switch":
                  - include_entity:
                    - 'zwavejs>63-0'
                    - 'zwavejs>61-0'
                filter_expression: "entity.power_switch.state"
                group_actions: true
          T 2 Replies Last reply
                "iblinds_switch":
                    - include_entity:
                      - 'zwavejs>63-0'
                      - 'zwavejs>61-0'
                  group_actions: true
                "iblinds_switch":
                    - include_entity:
                      - 'zwavejs>63-0'
                      - 'zwavejs>61-0'
                  group_actions: true
            Thanks Patrick. I'll give that a try.
                  "iblinds_switch":
                      - include_entity:
                        - 'zwavejs>63-0'
                        - 'zwavejs>61-0'
                    group_actions: true
                  "iblinds_switch":
                      - include_entity:
                        - 'zwavejs>63-0'
                        - 'zwavejs>61-0'
                    group_actions: true
              You said it was unsupported 🙂
              Reactor doesn't seem to like my filter.
              [latest-23078]2023-04-03T18:19:59.724Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Light#zwavejs>63-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
              These are the values when I look at the Entities tab for one of the blind controllers.
                Well that has nothing to do with group actions. It's specifically complaining about your filter. Hass is famous for giving null state when a device is unreachable or still initializing. If the DGC comes up faster than Hass, you get those messages. They usually don't stick.
                And please remember the posting guidelines. When posting an error, don't just post the error message; you need to post several dozen lines from before it, for context.
                  Understood, however, the system has been back up for white a while, and it just keeps repeating those errors. The lines I'm seeing before are unrelated and appear to be just normal reactions in my system.
                  [latest-23078]2023-04-03T18:44:11.461Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>63-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.462Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>62-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.462Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>64-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.462Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>65-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.462Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>79-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.462Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>77-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.462Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>78-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.462Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Cover#zwavejs>206-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.463Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Cover#zwavejs>205-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.463Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>75-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.463Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>74-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.463Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>71-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.463Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>16-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  [latest-23078]2023-04-03T18:44:11.463Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.cover.state error with Light#zwavejs>61-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                  • T tamorgen
                    I restarted Reactor to see if I could see anything coming back up.
                    latest-23078]2023-04-03T19:06:05.925Z <Structure:INFO> Structure#1 stopping DynamicGroupController#groups
                    [latest-23078]2023-04-03T19:06:05.926Z <DynamicGroupController:null> DynamicGroupController#groups stopping
                    [latest-23078]2023-04-03T19:06:05.926Z <Controller:NOTICE> DynamicGroupController#groups stopping
                    [latest-23078]2023-04-03T19:06:05.927Z <Controller:ERR> Controller DynamicGroupController#groups is off-line!
                    [latest-23078]2023-04-03T19:06:09.706Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                    [latest-23078]2023-04-03T19:06:09.710Z <DynamicGroupController:null> Module DynamicGroupController v22313
                    [latest-23078]2023-04-03T19:06:09.746Z <Structure:INFO> Starting controller DynamicGroupController#groups
                    [latest-23078]2023-04-03T19:06:09.750Z <Controller:NOTICE> Controller DynamicGroupController#groups is now online.
                    [latest-23078]2023-04-03T19:06:14.711Z <DynamicGroupController:INFO> All controllers ready, setting up dynamic groups
                    [latest-23078]2023-04-03T19:06:14.728Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Light#zwavejs>63-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                    [latest-23078]2023-04-03T19:06:14.728Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Light#zwavejs>62-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                    [latest-23078]2023-04-03T19:06:14.728Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Light#zwavejs>64-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                    [latest-23078]2023-04-03T19:06:14.728Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Light#zwavejs>65-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                    [latest-23078]2023-04-03T19:06:14.728Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Light#zwavejs>79-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                    [latest-23078]2023-04-03T19:06:14.729Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Light#zwavejs>77-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                    [latest-23078]2023-04-03T19:06:14.729Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Light#zwavejs>78-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                    [latest-23078]2023-04-03T19:06:14.729Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Cover#zwavejs>206-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                    [latest-23078]2023-04-03T19:06:14.729Z <DynamicGroupController:ERR> DynamicGroupController#groups filter expression entity.power_switch.state error with Cover#zwavejs>205-0: [ReferenceError] Invalid scope in reference to member state of (object)null [-]
                      OK. Two things:
                      1. When I made the example for group_actions above, I abbreviated the select and filter expressions, which I didn't expect you to copy verbatim; I just put it there for alignment/indenting. Use the select and filter expressions you had previously.
                      2. Update to the 23093 version of ZWaveJSController I just released, which fixes another small iBlinds issue.
                        OK. Two things:
                        OK. Two things:
                        Thanks. I thought the filter expressions format had changed for with the group_actions flag, so I changed it to your example.
                        I also updated to the latest ZWaveJSController.
                        I still eppar to be getting those same errors, even with changing back to:
                            "iblinds_switch":
                                          - include_entity:
                                            - 'zwavejs>63-0'
                                            - 'zwavejs>62-0'
                                            - 'zwavejs>64-0'
                                            - 'zwavejs>65-0'
                                            - 'zwavejs>79-0'
                                            - 'zwavejs>77-0'
                                            - 'zwavejs>78-0'
                                            - 'zwavejs>206-0'
                                            - 'zwavejs>205-0'
                                            - 'zwavejs>75-0'
                                            - 'zwavejs>74-0'
                                            - 'zwavejs>71-0'
                                            - 'zwavejs>16-0'
                                            - 'zwavejs>61-0'
                                        group_actions: true
                                      "iblinds_position":
                                          - include_entity:
                                            - 'zwavejs>63-0'
                                            - 'zwavejs>62-0'
                                            - 'zwavejs>64-0'
                                            - 'zwavejs>65-0'
                                            - 'zwavejs>79-0'
                                            - 'zwavejs>77-0'
                                            - 'zwavejs>78-0'
                                            - 'zwavejs>206-0'
                                            - 'zwavejs>205-0'
                                            - 'zwavejs>75-0'
                                            - 'zwavejs>74-0'
                                            - 'zwavejs>71-0'
                                            - 'zwavejs>16-0'
                                            - 'zwavejs>61-0'
                                        group_actions: true
                          entity.attributes.power_switch.state and the same change for the others, like you had originally.
                            Thanks, that did the trick. Do I need to use the local expressions when using this approach? I'm guessing no.
                              That would depend on what you're using them for. The only one I see above is to make a list of entity names from a group's members, presumably to use it in a message or something else not yet completed?
                                160.4k
