  4. Is this possible? Store data from Asus Router ajax .asp page for Temperature data.
77 Posts 3 Posters 41.3k Views 2 Watching
    #54
    OK. In RouterMemoryFree expression remove all of the (\\d+) strings so that the middle/second argument to match() is just "Mem:" by itself (no spaces or other data). Restart and hard refresh. Then re-check.
      Like this ?
      match( RouterMemoryResponse, "Mem:")
        Yes, that's fine.
          #57
          It now says -
          Last value: (string) "Mem:"
          And the test rule trigger -
            OK. So your pattern isn't matching, it seems is actually the problem. You may have some special characters or strange spacing in your pattern that I cannot see in the screen shots. There could also be a tab or other non-space character that looks like a space coming back in the shell command output.
            Try using this expression for RouterMemoryFree:
            match( RouterMemoryResponse, "Mem: (\\d+) (\\d+) (\\d+)", 3 )
              #59
              It appeared to evaluate as it flashed green, Value is null however.
              This is what is in the "RouterMemoryResponse"
              Last value: (string) " total used free shared buffers cached\nMem: 426020 330068 95952 3488 0 37716\n-/+ buffers/cache: 292352 133668\nSwap: 0 0 0\n"
                #60
                OK. Try changing all of the spaces to \\s* like this:
                match( RouterMemoryResponse, "Mem:\\s*(\\d+)\\s*(\\d+)\\s*(\\d+)", 3 )
                  @toggledbits That seems to work.
                    OK. So your router must be returning some space-looking character that isn't space in the string somewhere. That's fine... the \\s means match anything that looks like a space. That's your path forward.
                      Great thanks. I just need to know how to use a Global Expression in my rule now?
                      As using a value like ${{ RouterMemoryFree }} only seems to work if the expression is a local expression within the rule.
                        The Global Expressions look like this now. I have the used and free memory values OK.
                          Seems I can just do them as Local Expressions after all instead of Global ones.
                            If you are only going to push them out in the same Reaction to other places, that's fine. You don't be able to use them in conditions, though.
                              Yes that's right, info only
                              The routers CPU temp and WIFI chip temps however I am using those in another rules trigger to warn me if its getting hot. so those had to be Global Expressions.
                                #68
                                Oh... wait though... rule-based expressions evaluate a bit differently from global.
                                As global expressions, when "Response" changes, it triggers an immediate update/re-evaluation of Free and Used, as was happening in our troubleshooting.
                                When you move them to rule-based however, expressions in rules are only evaluated when the rule's trigger conditions are checked. That means the interval will cause Response to get fetched and updated, but Free and Used as local variables will not be updated immediately after... they will not update until the next time the interval triggers an evaluation of the rule, so each response will not have its new values posted until the interval period lapses. Do you understand what I'm on about here? I think you should be able to observe this behavior in the rule status.
                                  Yes I understand what you just said.
                                  But back to my other question then, is it possible to use a Global Expression value in a rules action with a value like ${{ RouterMemoryFree }} but for the Global Expression rather than any local one.
                                    Sure, use it just like you've shown. As long as there is not a local variable with the same name, it will find/choose the global variable.
                                      OK cool I didn't know you could do that and it was that simple !
                                        #72
                                        Also FYI, I fixed the initialization so a function like match() returning a null initial result won't leave the "not yet evaluated" message stuck in the display, even though it has actually been evaluated. Next build.
                                          #73
                                          I am confused now. I deleted the local expressions in the rule. I then created the global ones again. When I run the actions of the rule e.g. run the shell command and populate the "RouterMemoryResponse" Global expression that works OK.
                                          However the other two global expressions were not automatically evaluated.
                                          I pressed the play button on one and that is why that one has a value now. but the other one does not have a value.
                                          Running the rules actions again and its the same.
                                          Looking in a test trigger in a rule the value is null for "RouterMemoryUsed".
                                          So I am still not convinced these global expressions are auto evaluating.
                                          EDIT: Ignore this I forgot to restart MSR, seems I have to do that first ?
                                          Now when I run the rules actions all three Global Expressions flash green.
                                            161.0k
