  4. MSR thinks all my Ezlo Controller devices no longer exist, they do !
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
7 Posts 5 Posters 1.1k Views 5 Watching
    Today in MSR alerts I see 100 alerts saying that the devices on my Ezlo controllers no longer exist.
    They do still exist. I checked some of these devices in the Ezlo Online API Tool doing a hub.devices.list query.
    I then checked that the ID numbers were the same for the devices and they are the same device ID's still.
    So my devices do still exist with the same device ID's it seems.
    So not sure why MSR has over 100 alerts saying otherwise.
    I then looked in Entities selected my Ezlo Plus controller and it listed all my devices OK I think and nothing looked out of place.
      Have you made any changes to MSR or your Ezlo config?
      <edit> I missed the bit where they were all back!
        It's Ezlo. Anything is possible. Most likely, a momentary hiccup in either the hub (did it self-update?) or their cloud caused the inventory report to come back empty, maybe the hub (or their cloud) wasn't fully ready at the moment of the query. In fact, this kind of behavior is one of reasons MSR doesn't instantly delete a device that is no longer reported in the hub's inventory — all interfaces now have a grace period wherein a device can be restored. Anyway, if the Entities list shows all the devices now, clear the warnings and soldier on.
        Also please make sure you've looked at (and preferably captured/saved) the log files when asking questions like this (and of course, posting any potentially relevant findings). IMO, any post that doesn't say you've looked at the logs isn't meeting the posting guidelines/doing the homework.
        Oh, and I'll take this moment to acknowledge that in a couple of days the Vera community will mark five years since Ezlo announced that it acquired Vera.
        PablaP 1 Reply Last reply
          Are they out of beta, yet?
            @toggledbits said in MSR thinks all my Ezlo Controller devices no longer exist, they do !:
            I am so happy I jumped ship from Ezlo/Vera to Home Assistant. Ezlo is soooooo many years behind its an absolute joke
              I am quite amazed by HA. Although in some measure disturbed that my printer is broadcasting ink levels (for example). Plus there are some odd things that it detects (Linn Home) where I have no Linn gear at all.
              But otherwise loving it! Especially with MSR
                @CatmanV2 HA has matured nicely over the past couple years.
                *Hubitat C-7 2.4.3.177
                Core 2026.1.1
                MSR: latest-26011-c621bbc7
                  97.1k
                • Next Release?
