  4. pattern match or find expression? I am stuck again
4 Posts 2 Posters 856 Views 2 Watching
    I am stuck trying to extract the "SignalLevel" value which is the WIFI Signal Strength off my Foscam via a http request. The request returns this, which isn't Json formatted data I don't think.
    <CGI_Result>
        <result>0</result>
        <SignalLevel>52</SignalLevel>
    </CGI_Result>
    I created a rule that saves the http response into a Global Expression
    But I am struggling to work out what is the correct expression code to extract the value?
    Can anyone more knowledgeable please help?
    Thank you.
      Does the text of your pattern really match the string in the data you want to find? Look closely.
        You mean the <> brackets ? I did try without the brackets around SignalLevel.
        Oh the : should not be there.
        This works
        match( Cam1103Response, "<SignalLevel>(\\d+)", 1 )
          Well done!
            148.8k
