  4. Long-running task in MSR
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
5 Posts 3 Posters 674 Views 3 Watching
    I have a rule that's driving my pool heater to match the solar excess. In the previous iteration, I checked for the status every minute, but I wanted something different and smarter. The logic is basically:
    • run continuously from 9:15 to 18:15
    • check for conditions, and
      • if there's solar excess, use the power to turn on the heater, then wait 1 minute to check again
      • turn off the heater, then wait 5 minutes to prevent frequent on/off cycles
    I thought that this could be very similar to Reactor-Ex machina's logic, so I crafted a rule that's basically doing the same: an infinite loop from 9:15 to 18:15 that's checking for status and has a delay based on the heater's condition.
    All went well, but after a couple of hours, I got this:
    Reaction task "49683" failed due to an exception. Please see the log.
    rule-liy7z3gf:S (Pool-Heater-Solar) step 0: Error: Task has run too much! Runaway?
    and the rule was reset (and the heater was left on). Is that by design and I should adopt another strategy? What are others doing when they have a state machine?
    With the EV charger I did two groups of condition, each triggering every x minutes based on the charger status, but this seems less smarter and very rudimental. Any suggestion is appreciated. Thanks.
      You could utilize pulse with repeat to control your heater. Not sure why you would want to run continuously, or do you assume there’s always excess during that time?
      ”Delay reset / sustained for” are good tools to increase hysteresis, to avoid too frequent changes
      • CrilleC Online
        CrilleC Online
        I'm combining global expressions and a rule to handle my pool heater. I monitor my electric meter and get real time values every 8-10 seconds.
        I'm allowing it to run a little bit even on bought electricity and have an expression triggered by MQTT to manually override the rule with another rule.
        Global Expressions:
        Rule:
        I use Sustained for and Delay reset to prevent flapping. I also handle manual and automatic triggers different. Automatic with sustained/delayed and manual no delays. The Set reaction starts the heater, sets the poolHeatTrigger to "auto" and sends a notification (if automatic start), the Reset reaction turns it off (with notification if started by auto logic).
        That's my approach, hope it gives you some new ideas.
          @tunnus said in Long-running task in MSR:
          Yes, I mostly have solar excess during the day, unless I'm charging the car. I have an 8.2kWp system, soon to be expanded to 12kWp. House is fully electric, but all is new, so consumption is moderate.
          That's what I'm doing with my EV charger rule. Two groups, one to check for charging, the other for idle, with different timeouts. I was searching for something more sequentially, maybe. I don't know.
          @Crille said in Long-running task in MSR:
          yep, I have a virtual device with modes. It's selectable from a dashboard (and via our bot), and you'd choose from:
          • solar
          • always on
          • always off
          Solar mode has conditions for pump, temperature threshold based on hour, rain, and exporting power, to give the EV charger the space to still charge the car at minimum, if necessary.
          Thanks for the head-ups. Back to the drawing board 🙂
            I ended up using the same approach as in my rule for solar mode of the EV charger:
            I left 4 seconds for the rule to reset, so it could "pulse" again in 4 secs and re-evaluate the conditions.
            • Next Release?
              1.0k
