  4. Have reactor shut off a light with no motion unless I turned it on manually
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
4 Posts 4 Posters 757 Views 4 Watching
    sethlampman
    So I have a strange one here and I don't know if there is a way to do this or not. I have blue iris triggering a vera virtual switch when AI detects motion on my front porch. Reactor then triggers the light, this works perfect. I want to shut the light off when there is no motion, this also works perfect. What I am having am issue with is when someone turns on the light manually I don't want it to turn off after motion is detected. Example: we are expecting a pizza so we turn on the porch light. 5 min later amazon delivers a package, trips motion. 10 min later Reactor is going to turn off the light. If I manually turn on the light before motion is detected I do not want reactor to turn it off. For the life of me I cannot figure the logic out. Does anyone have any ideas?
    S 1 Reply Last reply
      Please re-read the posting guidelines. You're welcome to ask questions like this, but unless you show the work you've done so far, you're leaving us with "how long is a piece of string?" as a starting point.
        Whatever rule you are using for a motion triggered light, you could just add a condition (or constraint) where you check that light is off?
        • S sethlampman
          @sethlampman I use multiple rules and a global expression to hold the current state of the light that I set when different events happen. When motion triggers the light I set the global expression to “auto”. When the light comes on with no motion then it must of been turned on manually so that rule sets the expression to “man” I then have rules to to shut the light off for when motion happend and another rule for when it was turned on manually with different delays. When the light is off I set the global expression to idle. Does this give you any ideas for your situation?
          Screenshot 2023-12-05 at 7.07.05 PM.png Screenshot 2023-12-05 at 7.07.31 PM.png Screenshot 2023-12-05 at 7.07.58 PM.png Screenshot 2023-12-05 at 7.08.21 PM.png Screenshot 2023-12-05 at 7.10.59 PM.png
          • Next Release?
            1.0k
