  4. Actionable notification question
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
7 Posts 4 Posters 1.5k Views 4 Watching
    I'm running Home Assistant with MSR, and I do my automation strictly within MSR. I have some basic notifications set up, for instance, when my dishwasher has completed it's cycle, it'll send my iPhone a push notification via the x_haas.system.call_service --> notify.mobile_iphone action.
    I saw in the Home Assistant documentation that you can push Actionable Notifications. The example they use if there is motion detection, but no one is home, you can sound an alarm or silence an alarm.
    Can this be done from MSR and not directly in Home Assistant? I'd like to do something more of an acknowledgement, like if a door or window is left open, to have a way to get notified, but acknowledge that it is open, and not send any more notifications. If not acknowledged, the notification will continue every 5 or 10 minutes until the door or window is closed, or the notification is acknowledged. This would be useful in situations where I may have a slider door open for some fresh air, so it was deliberate, versus an entry door that didn't latch when entering or leaving the house.
      I haven't found a way to create actionable notifications in MSR because HA doesn't expose the mobile_app_notification_action event. The way I do it instead is create the actionable notification action in HA then have MSR trigger it.
        @Pabla I like this.
        I do something similar with my LIFX bulbs. For some yet-to-be-discovered reason two of them turn on during the day. My Hubitat integration were they live does not see it... but my HA integration does. So I created a ruleset in MSR that watches the HA version of the lights and fires an HA automation that turns them off.
        More than one way to get to the circus!
        *Hubitat C-7 2.5.0.135
        Core 2026.5.0
        MSR: latest-26127-726206dd
          @Pabla said in Actionable notification question:
          I'm not exactly sure what you mean or intend here, but I just ran a quick test using the service call HA provides in their documentation for Actionable Notifications (linked in the head post), and Reactor does see the mobile_app_notification_action event when a button is pressed on the mobile app notification (Android tested). Here's the service call I made:
          service: notify.mobile_app_sm_g996u
          data:
            message: "Something happened at home!"
            data:
              actions:
                - action: "ALARM"
                  title: "Sound Alarm"
                  icon: "sfsymbols:bell"
                - action: "SILENCE"
                  title: "Silence Alarm"
                  icon: "sfsymbols:bell.slash"
          When the Sound Alarm button on the notifications is pressed, Reactor gets this event:
              "type": "event",
              "event": {
                  "event_type": "mobile_app_notification_action",
                  "data": {
                      "action_2_title": "Silence Alarm",
                      "webhook_id": "2f7fba8991b3bfac3a5fb46ace19cd6d616becb829aecb5a8ae2a2ece759052f",
                      "message": "Something happened at home!",
                      "action_1_title": "Sound Alarm",
                      "action_1_key": "ALARM",
                      "action_2_key": "SILENCE",
                      "server_id": "1",
                      "action": "ALARM",
                      "device_id": "c8458cf66b182e07"
                  "origin": "REMOTE",
                  "time_fired": "2024-01-23T00:59:00.722438+00:00",
                  "context": {
                      "id": "01HMSX7RQJDJYFFQPJFWX8HEG8",
                      "parent_id": null,
                      "user_id": "459ddf6f84b14de98f4c65e2d2da2dc6"
              "id": 1705971523928
          So in Reactor, I can configure an event reaction (in reactor.yaml for a HassController instance):
            config:  # this line is for alignment only
              event_targets:
               notification_sound_alarm:
                  capabilities:
                  - binary_sensor
                  events:
                  - event:
                      event_type: mobile_app_notification_action
                      data:
                        device_id: "c8458cf66b182e07"
                        action: "ALARM"
                    response:
                      "binary_sensor.state":
                        expr: "! entity.attributes.binary_sensor.state"
          This trivial event handler just toggles the binary_sensor.state attribute in the associated virtual device it creates (having ID notification_sound_alarm), every time the event is received.
          Works a treat. Really cool actually. Actionable Notifications... TIL.
          Ref to docs for creating event handlers: https://reactor.toggledbits.com/docs/HassController/#handling-home-assistant-events
          PablaP T 2 Replies Last reply
            data:
              data:
                actions:
                  - action: "ALARM"
                  - action: "SILENCE"
                "type": "event",
                "event": {
                    "data": {
                        "server_id": "1",
                        "action": "ALARM",
                    "origin": "REMOTE",
                    "context": {
                        "parent_id": null,
                "id": 1705971523928
                event_targets:
                    capabilities:
                    - binary_sensor
                    events:
                    - event:
                        data:
                          action: "ALARM"
                      response:
            @toggledbits Every time I think I have Reactor figured out I always end up learning something new! Will defs be playing with this
              data:
                data:
                  actions:
                    - action: "ALARM"
                    - action: "SILENCE"
                  "type": "event",
                  "event": {
                      "data": {
                          "server_id": "1",
                          "action": "ALARM",
                      "origin": "REMOTE",
                      "context": {
                          "parent_id": null,
                  "id": 1705971523928
                  event_targets:
                      capabilities:
                      - binary_sensor
                      events:
                      - event:
                          data:
                            action: "ALARM"
                        response:
              @toggledbits, it's going to take soem time to wrap my head around everything you posted, but it's great to know it's possible!
                I realize the documentation on configuring event handlers isn't great. I've made some updates and will post them later today, but I still feel it needs work. Feel free to ask questions and make suggestions; then I'll know what holes to fill.
                  101.3k
                • Next Release?
