  4. Actionable notification question
Possible feature request?
Copying a global reaction
Time series documentation
Reset a delay
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
7 Posts 4 Posters 1.1k Views 4 Watching
    I'm running Home Assistant with MSR, and I do my automation strictly within MSR. I have some basic notifications set up, for instance, when my dishwasher has completed it's cycle, it'll send my iPhone a push notification via the x_haas.system.call_service --> notify.mobile_iphone action.
    I saw in the Home Assistant documentation that you can push Actionable Notifications. The example they use if there is motion detection, but no one is home, you can sound an alarm or silence an alarm.
    Can this be done from MSR and not directly in Home Assistant? I'd like to do something more of an acknowledgement, like if a door or window is left open, to have a way to get notified, but acknowledge that it is open, and not send any more notifications. If not acknowledged, the notification will continue every 5 or 10 minutes until the door or window is closed, or the notification is acknowledged. This would be useful in situations where I may have a slider door open for some fresh air, so it was deliberate, versus an entry door that didn't latch when entering or leaving the house.
      I haven't found a way to create actionable notifications in MSR because HA doesn't expose the mobile_app_notification_action event. The way I do it instead is create the actionable notification action in HA then have MSR trigger it.
        @Pabla I like this.
        I do something similar with my LIFX bulbs. For some yet-to-be-discovered reason two of them turn on during the day. My Hubitat integration were they live does not see it... but my HA integration does. So I created a ruleset in MSR that watches the HA version of the lights and fires an HA automation that turns them off.
        More than one way to get to the circus!
        *Hubitat C-7 2.4.3.173
        *HASS 2025.12.4, Core 2025.12.3
        MSR: latest-25328-b2ed1365
          @Pabla said in Actionable notification question:
          I'm not exactly sure what you mean or intend here, but I just ran a quick test using the service call HA provides in their documentation for Actionable Notifications (linked in the head post), and Reactor does see the mobile_app_notification_action event when a button is pressed on the mobile app notification (Android tested). Here's the service call I made:
          service: notify.mobile_app_sm_g996u
          data:
            message: "Something happened at home!"
            data:
              actions:
                - action: "ALARM"
                  title: "Sound Alarm"
                  icon: "sfsymbols:bell"
                - action: "SILENCE"
                  title: "Silence Alarm"
                  icon: "sfsymbols:bell.slash"
          When the Sound Alarm button on the notifications is pressed, Reactor gets this event:
              "type": "event",
              "event": {
                  "event_type": "mobile_app_notification_action",
                  "data": {
                      "action_2_title": "Silence Alarm",
                      "webhook_id": "2f7fba8991b3bfac3a5fb46ace19cd6d616becb829aecb5a8ae2a2ece759052f",
                      "message": "Something happened at home!",
                      "action_1_title": "Sound Alarm",
                      "action_1_key": "ALARM",
                      "action_2_key": "SILENCE",
                      "server_id": "1",
                      "action": "ALARM",
                      "device_id": "c8458cf66b182e07"
                  "origin": "REMOTE",
                  "time_fired": "2024-01-23T00:59:00.722438+00:00",
                  "context": {
                      "id": "01HMSX7RQJDJYFFQPJFWX8HEG8",
                      "parent_id": null,
                      "user_id": "459ddf6f84b14de98f4c65e2d2da2dc6"
              "id": 1705971523928
          So in Reactor, I can configure an event reaction (in reactor.yaml for a HassController instance):
            config:  # this line is for alignment only
              event_targets:
               notification_sound_alarm:
                  capabilities:
                  - binary_sensor
                  events:
                  - event:
                      event_type: mobile_app_notification_action
                      data:
                        device_id: "c8458cf66b182e07"
                        action: "ALARM"
                    response:
                      "binary_sensor.state":
                        expr: "! entity.attributes.binary_sensor.state"
          This trivial event handler just toggles the binary_sensor.state attribute in the associated virtual device it creates (having ID notification_sound_alarm), every time the event is received.
          Works a treat. Really cool actually. Actionable Notifications... TIL.
          Ref to docs for creating event handlers: https://reactor.toggledbits.com/docs/HassController/#handling-home-assistant-events
          PablaP T 2 Replies Last reply
            data:
              data:
                actions:
                  - action: "ALARM"
                  - action: "SILENCE"
                "type": "event",
                "event": {
                    "data": {
                        "server_id": "1",
                        "action": "ALARM",
                    "origin": "REMOTE",
                    "context": {
                        "parent_id": null,
                "id": 1705971523928
                event_targets:
                    capabilities:
                    - binary_sensor
                    events:
                    - event:
                        data:
                          action: "ALARM"
                      response:
            @toggledbits Every time I think I have Reactor figured out I always end up learning something new! Will defs be playing with this
              data:
                data:
                  actions:
                    - action: "ALARM"
                    - action: "SILENCE"
                  "type": "event",
                  "event": {
                      "data": {
                          "server_id": "1",
                          "action": "ALARM",
                      "origin": "REMOTE",
                      "context": {
                          "parent_id": null,
                  "id": 1705971523928
                  event_targets:
                      capabilities:
                      - binary_sensor
                      events:
                      - event:
                          data:
                            action: "ALARM"
                        response:
              @toggledbits, it's going to take soem time to wrap my head around everything you posted, but it's great to know it's possible!
                I realize the documentation on configuring event handlers isn't great. I've made some updates and will post them later today, but I still feel it needs work. Feel free to ask questions and make suggestions; then I'll know what holes to fill.
                • Possible feature request?
                • Copying a global reaction
                • Time series documentation
                • Tuya Wifi to Tasmota flashing
                • Reset a delay
                • Single protocol?
