  4. Widgets and filtering
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
10 Posts 4 Posters 1.3k Views 4 Watching
      @tunnus I'd encourage some discussion here before opening a PR. The more specific you can be in defining the problem and, ideally, what you think the solution should look like, the more likely it will be to bubble up on the wish list.
        @toggledbits so e.g. in Reaction History widget I have a lot of repeating rules firing (by design):
        These just make it harder to spot & follow more "rare" rules/events. Filtering would help, if you could specify strings that are filtered out. E.g. "SiteSensor" or "uplink" in my case.
          Alan_F
          I can think of several kinds of filtering that could be useful here:
          Show only matching rules: So I can see the history of when a certain rule ran
          Filter out matching rules: As requested above, to remove rules with 'site sensor' or in my case 'poll' from the list
          Filter out rules by their characteristics: For example, do not show any rules that run based on time events. This would let me see only things that had 'happened'. I have a rule acting as a SiteSensor that runs every 60 seconds, but I really don't need to see that on the list.
          I think ideally the filtering would be done right in the widget, and not in the config file, but it's probably easier to do more complicated filtering in the config file.
          • A Alan_F
            @alan_f in my opinion filtering in the widget itself would be better than in a separate config. Would be faster/easier to change, configs need MSR restarts. Also, not a fan of yaml files...
              Alan_F
              @tunnus I agree in general, but if you wanted really granular filtering like a specific list of rules that should be filtered out, rather than just keywords, it would make sense to put those in a config file. Also if you always wanted them filtered out the config would make more sense. If you wanted to change filters based on whatever you wanted to see right now, then a config file and Reactor restart would be a pain.
              Just thinking through the user interface... what if there were a drop-down box at the top of the widget. When the box opens up it would have all the rules listed, each with a check box next to it that would allow the user to select/unselect it?
              That might get ugly on a system with hundreds of rules, so in a perfect world there would then be a text filter within the drop-down box. Click the drop-down to show all rules, then type "sitesensor" to show only the Sitesensor rules in the drop-down. Then the user could check/uncheck various Sitesensor rules. The user could then type "HVAC" to see only the HVAC rules and then check/uncheck various HVAC rules.
                One of the many irons I have in the fire on this project is an editor for settings in the GUI/Tools page. Challenging, tons of fun, but a lot of work and miles to go before I sleep.
                • wmarcolinW Offline
                  Hi @toggledbits
                  Is the wish list still open? Is this information that appears in widgets stored in some attribute/element that we can access to use in rules? Or even demonstrate for example in a dashboard in Hubitat?
                    Everything that is shown in widgets are attributes of entities. All attributes of entities are accessible in rules. Does that answer the question?
                    The wish list is always open.
                    wmarcolinW 1 Reply Last reply
                      @toggledbits I was thinking of the list of running tasks as "Set Rules", a simple way of having this query.
                        3.5k
                        3.1k
                        371
                      • Self test
