  4. MSR's "rgb_color.set" isn't correctly sending RGB values to bulb in Home Assistant
4 Posts 3 Posters 1.2k Views 3 Watching
    apocalypsehobby
    • 'rgb_color.set_rgb' works successfully, which seems strange. You'd think they would both be affected
    • I've tried a couple different formats, like adding quotes, adding/removing spaces between the RGB values, nothing has fixed it.
    EXAMPLES:
    f0f4befc-a642-428e-8923-e5f856ca7e2b-image.png 0af0a4f8-50b9-4100-b1e8-52a0de4cbcbb-image.png
    • Bulb is LZW42 by Inovelli
    • MSR version: stable-23242-5ee8e1d4
    HA DETAILS
    • Core 2024.2.5
    • Supervisor 2024.02.1
    • Operating System 12.0
      To better assist, please post some logs of when you trigger the action to see what HA response is and if MSR is logging any errors
        apocalypsehobby
        Good call
        From MSR's reactor.log file:
        [stable-23242]2024-03-10T21:17:49.485Z <HassController:INFO> HassController#hass action rgb_color.set([Object]{ "value": "75,0,255" }) on Light#hass>light_garage_light_l succeeded
        I need to grab logs from HA as well
        Also - I noticed that when I save the rule in MSR, it doesn't save everything. Instead of saving as '75, 0, 255' it just saves as '75'.
        • A apocalypsehobby
          Good call
          @apocalypsehobby please read the posting guidelines, a pinned post in this category. There are some specific requests for log files and snippets.
          Also rgbcolor.set takes a hex color code or decimal equivalent. It's probably not what you want to be using. set_rgb is more common.
            160.3k
