  4. Can't Restart Reactor - Corrupted SD Card?
Gradually turn on lights.
Tom_DT
Error After Upgrade
Links to MSR from HA
Tom_DT
Set Reaction > Script Action
I'm running MSR build 25139 on Docker, using MQTT controller 24293, and everything working as expected. But if I try to upgrade to MQTTController build 25139, I'm getting the following errors on MSR UI: An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.god Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.green Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.red Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto run" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.pump Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa watchdog" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.status Last 11:20:37 My MQTT configuration (local_mqtt_devices.yaml) for the related entity is: layzspa_message: type: ValueSensor capabilities: ["temperature_sensor", "value_sensor", "power_sensor"] primary_attribute: power_sensor.value events: "layzspa/message": "power_sensor.value": json_payload: true if_expr: '! isnull( payload?.PWR )' expr: "float(payload.PWR)" "value_sensor.air": json_payload: true if_expr: '! isnull( payload?.AIR )' expr: "float(payload.AIR)" "value_sensor.pump": json_payload: true if_expr: '! isnull( payload?.FLT )' expr: "float(payload.FLT)" "value_sensor.god": json_payload: true if_expr: '! isnull( payload?.GOD )' expr: "float(payload.GOD)" "value_sensor.lock": json_payload: true if_expr: '! isnull( payload?.LCK )' expr: "float(payload.LCK)" "value_sensor.unit": json_payload: true if_expr: '! isnull( payload?.UNT )' expr: "float(payload.UNT)" "value_sensor.error": json_payload: true if_expr: '! isnull( payload?.ERR )' expr: "float(payload.ERR)" "temperature_sensor.green": json_payload: true if_expr: '! isnull( payload?.GRN )' expr: "float(payload.GRN)" "temperature_sensor.red": json_payload: true if_expr: '! isnull( payload?.RED )' expr: "float(payload.RED)" "temperature_sensor.target": json_payload: true if_expr: '! isnull( payload?.TGT )' expr: "float(payload.TGT)" "temperature_sensor.value": json_payload: true if_expr: '! isnull( payload?.TMP )' expr: "float(payload.TMP)" "temperature_sensor.virtual": json_payload: true if_expr: '! isnull( payload?.VTM )' expr: "round(float(payload.VTM), 1)" "temperature_sensor.ambient": json_payload: true if_expr: '! isnull( payload?.AMB )' expr: "float(payload.AMB)" "layzspa/Status": "value_sensor.status": if_expr: '! isnull( payload )' expr: "payload" "layzspa/button": "value_sensor.button": if_expr: '! isnull( payload )' expr: "payload" and in reactor.yaml I have: "layzspa_states": name: "Lay-Z-Spa States" friendly_name: 'Lay-Z-Spa States' include: layzspa_message I realize my MQTT configuration might be a bit unorthodox, but could there still be something unintentional in the latest MQTTController build? If needed, I can provide detailed logs.
Tom_DT
Need help reducing false positive notifications
Deleting widgets
Hopefully a trivial question, but how do you delete widgets in a status page? Using build 22266
MQTT configuration question
I have the following yaml configuration in local_mqtt_devices file x_mqtt_device: set_speed: arguments: speed: type: str topic: "command/%friendly_name%" payload: type: json expr: '{ "fan": parameters.speed }' While this works fine, I'm wondering how this could be changed to "fixed" parameters, as in this case "fan" only accepts "A", "Q" or a numeric value of 1-5?
7 Posts 2 Posters 746 Views 2 Watching
    wrote on last edited by Pabla
    2024-04-15T18:06:22.077587-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.077788-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.077950-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.078100-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.078258-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.078416-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.078580-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.078727-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.078865-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.079010-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.079158-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.080399-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.080Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.080755-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.080962-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.081128-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.081279-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.081432-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.081589-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.081743-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.081934-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.082077-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.082219-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.082398-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.083768-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.083Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.084179-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.084393-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.084559-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.084710-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.084863-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.085020-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.085177-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.085328-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.085466-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.085607-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.085756-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.086975-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.086Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.087274-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.087460-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.087619-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.087767-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.087920-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.088080-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.088239-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.088387-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.088525-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.088668-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.088855-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.090050-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.089Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.090402-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.090604-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.090766-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.090917-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.091072-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.091229-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.091386-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.091538-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.091676-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.091821-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.091970-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.093138-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.092Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.093521-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.093795-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.093976-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.094130-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.094290-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.094448-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.094607-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.094757-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.094896-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.095038-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.095184-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.096390-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.096Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.096721-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.096926-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.097092-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.097261-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.097435-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.097593-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.097749-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.097895-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.098034-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.098177-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.098321-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.099477-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.099Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.099986-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.100210-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.100376-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.100536-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.100693-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.100847-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.100993-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.101134-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.101280-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.101426-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.101576-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.102597-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.102Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.102928-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.103196-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.103423-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.103636-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.103826-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.103990-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.104146-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.104293-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.104433-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.104575-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.104719-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.105897-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.105Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.106218-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.106419-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.106578-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.106729-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.106884-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.107041-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.107200-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.107353-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.107537-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.107688-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.107835-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.108945-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.108Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.109303-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.109504-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.109668-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.109882-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.110050-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.110214-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.110369-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.110513-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.110651-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.110794-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.110940-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.112050-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.111Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.112332-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.112525-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.112684-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.112838-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.113024-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.113262-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.113461-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.113657-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.113803-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.113954-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.114102-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.115323-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.114Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.115652-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.115852-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.116013-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.116165-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.116320-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.116476-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.116631-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.116777-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.116914-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.117058-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.117204-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.118359-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.118Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.118646-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.118838-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.118999-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.119157-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.119317-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.119477-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.119636-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.119954-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.120116-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.120268-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.120421-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.121491-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.121Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.121775-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.121967-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.122128-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.122277-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.122430-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.122584-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.122741-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.122891-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.123045-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.123226-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.123407-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.124708-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.124Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.125034-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.125234-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.125400-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.125550-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.125700-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.125853-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.126009-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.126159-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.126300-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.126439-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.126583-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.127825-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.127Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.128177-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.128381-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.128544-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.128696-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.128852-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.129016-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.129181-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.129380-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.129547-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.129752-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.129934-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.218665-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.218Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.219103-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.219321-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.219495-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.219664-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.219884-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.220048-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.220194-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.220340-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.220483-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.220632-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.220785-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-15T18:06:22.221868-07:00 raspberrypi node[3744]: [latest-24057]2024-04-16T01:06:22.221Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
    2024-04-15T18:06:22.222302-07:00 raspberrypi node[3744]: TypeError: Cannot read properties of null (reading 'min')
    2024-04-15T18:06:22.222522-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
    2024-04-15T18:06:22.222685-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.222845-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
    2024-04-15T18:06:22.223040-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.223275-07:00 raspberrypi node[3744]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
    2024-04-15T18:06:22.223481-07:00 raspberrypi node[3744]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
    2024-04-15T18:06:22.223682-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
    2024-04-15T18:06:22.223852-07:00 raspberrypi node[3744]:     at Array.forEach (<anonymous>)
    2024-04-15T18:06:22.224014-07:00 raspberrypi node[3744]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
    2024-04-15T18:06:22.224163-07:00 raspberrypi node[3744]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    • PablaP Pabla deleted this topic on
    • PablaP Pabla restored this topic on
      This may be another change in Hass 2024.4, which is not yet officially supported. Can you check your hass_services.json log file and see if you find this:
              "selector": {
                  "number": null    <--- search for this
      If you find an example of these three lines together, capture that file. I'm going to ask you to send it to me.
      Also, can you post just ONE of the messages above, with the 20 lines or so before that I always ask for. I'd rather see one copy with context than 20 copies of the same thing without it.
      PablaP 1 Reply Last reply
                "selector": {
        @toggledbits said in Can't Restart Reactor - Corrupted SD Card?:
                "selector": {
        Searched and nothing came up in the hass_services.json
        2024-04-15T14:12:03.340678-07:00 raspberrypi node[531]: [latest-24057]2024-04-15T21:12:03.339Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
        2024-04-15T14:12:03.341046-07:00 raspberrypi node[531]: TypeError: Cannot read properties of null (reading 'min')
        2024-04-15T14:12:03.341211-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
        2024-04-15T14:12:03.341362-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.341511-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
        2024-04-15T14:12:03.341659-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.341809-07:00 raspberrypi node[531]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
        2024-04-15T14:12:03.341961-07:00 raspberrypi node[531]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
        2024-04-15T14:12:03.342110-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
        2024-04-15T14:12:03.342258-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.342407-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
        2024-04-15T14:12:03.342557-07:00 raspberrypi node[531]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        2024-04-15T14:12:03.351442-07:00 raspberrypi node[531]: [latest-24057]2024-04-15T21:12:03.350Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
        2024-04-15T14:12:03.351839-07:00 raspberrypi node[531]: TypeError: Cannot read properties of null (reading 'min')
        2024-04-15T14:12:03.352002-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
        2024-04-15T14:12:03.352151-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.352302-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
        2024-04-15T14:12:03.352450-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.352601-07:00 raspberrypi node[531]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
        2024-04-15T14:12:03.352757-07:00 raspberrypi node[531]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
        2024-04-15T14:12:03.352907-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
        2024-04-15T14:12:03.353055-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.353204-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
        2024-04-15T14:12:03.353354-07:00 raspberrypi node[531]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        2024-04-15T14:12:03.361968-07:00 raspberrypi node[531]: [latest-24057]2024-04-15T21:12:03.361Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
        2024-04-15T14:12:03.362323-07:00 raspberrypi node[531]: TypeError: Cannot read properties of null (reading 'min')
        2024-04-15T14:12:03.362482-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
        2024-04-15T14:12:03.362631-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.362780-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
        2024-04-15T14:12:03.362930-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.363079-07:00 raspberrypi node[531]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
        2024-04-15T14:12:03.363230-07:00 raspberrypi node[531]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
        2024-04-15T14:12:03.363379-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
        2024-04-15T14:12:03.363526-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.363674-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
        2024-04-15T14:12:03.363823-07:00 raspberrypi node[531]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        2024-04-15T14:12:03.371382-07:00 raspberrypi node[531]: [latest-24057]2024-04-15T21:12:03.370Z <HassController:CRIT> TypeError: Cannot read properties of null (reading 'min') [-]
        2024-04-15T14:12:03.371778-07:00 raspberrypi node[531]: TypeError: Cannot read properties of null (reading 'min')
        2024-04-15T14:12:03.371938-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1067:207
        2024-04-15T14:12:03.372087-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.372236-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1044:279
        2024-04-15T14:12:03.372383-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.372532-07:00 raspberrypi node[531]:     at HassController._register_service (/home/arman/Documents/reactor/server/lib/HassController.js:1037:60)
        2024-04-15T14:12:03.372683-07:00 raspberrypi node[531]:     at HassController._update_entity (/home/arman/Documents/reactor/server/lib/HassController.js:873:43)
        2024-04-15T14:12:03.372834-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1196:67
        2024-04-15T14:12:03.372982-07:00 raspberrypi node[531]:     at Array.forEach (<anonymous>)
        2024-04-15T14:12:03.373131-07:00 raspberrypi node[531]:     at /home/arman/Documents/reactor/server/lib/HassController.js:1191:247
        2024-04-15T14:12:03.373281-07:00 raspberrypi node[531]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                  "selector": {
          @Pabla said in Can't Restart Reactor - Corrupted SD Card?:
          OK, not finding the search string and the sequence and type of messages suggests to me that (a) it's not a Hass change at fault, and (b) there's corruption, may or may not be SD, could be RAM. That message should be accompanied by another, and not logged the way you Pi is logging it. I can prove that on my own systems. If you can't find that null in the data, it also suggests that the place that's throwing the error should not be throwing an error, because the error can only occur if that data is null. Lots to unpack.
          Odd, random problems with Pi's can indeed be caused by SD failure, but the fact that it appears we have an in-memory data corruption suggests RAM. Other culprits in RPi slowdowns are overheating (you may need a heat sink, at least, on your CPU, and possibly a fan; if you're overclocking it, don't), but perhaps more commonly, a failing power supply. If the PS can't deliver stable voltage at the current the Pi demands, it will slow the clock for sure, but all kinds of other strange things can happen as well. It can be very quiet and subtle, and random with increasing frequency at the start. Voltage warnings show in the desktop UI but can be very hard to detect/confirm if you don't have that open all the time to see it. If you're using a "wall wart" power supply, swap it out for something newer/better and see if the system improves. Make sure it's rated for the Pi's full power (3B+ is 5V/2.5A so a 15W or higher PS is recommended). If you're using a USB cable connection for power, also change out the cable; make sure the new one is rated for the power.
          If you log in to your Pi, you should be able to run sudo vcgencmd get_throttled. If there has been any power or heat event since the Pi last rebooted, there will be a non-zero value reported.
          Generally speaking, the 3B+ isn't the best choice these days. While I have tested Reactor on a 3B+ and it runs, it's under-powered and light on RAM, so if you're trying to run much else with it (Mosquitto, ZWaveJS, etc), you're asking for trouble. It's also holding you back on an aging OS. The fact that you're still running on an SD card is playing with fire; there are only two kinds of MicroSD cards: those that have failed, and those that are about to. Even if a PS swap fixes your issue, I'd make a plan to replace/upgrade that unit some day soon to a modern Pi, or one of the alternative units. I'm still a big fan of the Raspberri Pi Compute Module 4 with eMMC (like on-board SSD but better) mounted on the RPi CM4 I/O Board; I even made a 3D-printable case for it. It's one of the easiest ways to get to a non-MicroSD Pi configuration. You could also go to Pi 5 with an M.2 HAT and M.2 SSD. But in any case, I'd start planning an upgrade for the long-term.
            The response i got throttled=0x80000 means soft temp throttle. I did notice that the unit was running really hot recently too.
            Either way I know I was playing with fire with running a 3+ with a SD card. Thankfully I do backup the Reactor directory every day so if I did lose the Pi it wouldn't be catastrophic.
            I do however have an Odroid N2+ handy which will be more than enough to run MSR and anything else with a lot of power to spare. I will likely run it with a SSD though since that currently uses a SD card as well. It does however have 64gb of Emmc storage, not sure if that is is suitable for MSR.
                To close this thread out, it wasn't a Reactor issue. My Rpi 3B+ was simply overheating and throttling processes. Moved to an Odroid N2+ with a heatsync running Ubuntu and everything is running smoothly!
                • Gradually turn on lights.
                • Error After Upgrade
                  RHCPNG
                  939
                • Links to MSR from HA
                  Tom_DT
                  Tom_D
                • 🎉 My very first MSR controller: OpenSprinkler
                  923
